标准号
+ H6 m/ ?& C) ?* J: F+ T | 标准中文名称$ l5 m2 j& m4 ~6 m% A. h9 W
| 标准英文名称( [2 p7 L- G9 u. f
DIN 2510-1-1974 ) H5 e) ]0 {2 z
| 膨胀螺栓连接.一览表.应用范围和安装示例 5 d) [) a; J0 e3 u. V' Y. |
| (Bolted Connections with Reduced Shank; Survey, Range of Application and Examples of Installation) / T5 ^4 |# C9 @- I. S1 I* V
DIN 2510-3-1971
$ X" T* l# @4 i) K0 Q7 a) Z3 _ | 膨胀螺栓连接.全螺纹螺柱 7 j9 } d! a8 v9 D# e5 k
| (Bolted Connections with Reduced Shank; Stud-bolts) 8 f; T+ z" \0 r$ N U2 I, e% r
DIN 2510-4-1971
( n$ z: y$ { v& E/ y | 膨胀螺栓连接.双头螺栓
. s% G) A6 H/ D* R | (Bolted Connections with Reduced Shank; Studs) : ]2 H K0 p1 G3 F' p" \
DIN 2510-5-1971 ' N" C, T; G; V
| 膨胀螺栓连接.六角螺母
9 C* Q1 C& g3 W, J# J | (Bolted Connections with Reduced Shank; Hexagon Nuts)
$ A' y1 i- ~, F1 r! Z |
DIN 2510-6-1974 , A+ u: W8 f* X8 a7 x: i1 e# }
| 膨胀螺栓连接.盖螺帽 ! E- \) c9 n o8 S
| (Bolted Connections with Reduced Shank; Cap Nuts) # R2 h0 d/ h6 e* U5 X) o
DIN 2510-7-1971 2 e. Q$ E7 F( E: x) ~
| 膨胀螺栓连接.套管 8 D/ q4 j! Y& b: z. ^/ [2 J. B
| (Bolted Connections with Reduced Shank; Extension Sleeves) % |, e0 Y2 s) N6 N) |( T: \
DIN 2510-8-1971 + `' `8 ?: s! Q& b
| 膨胀螺栓连接;双头螺栓的旋入孔 ) B# F4 A, W7 |6 S2 c! R' v
| (Bolted Connections with Reduced Shank; Threaded Holes for Studs)
! T7 h' r3 `* U6 s- G |
