查看: 2305|回复: 3
[分享] 铝合金论文
发表于 2006-12-23 19:16:44 | 显示全部楼层 |阅读模式 来自: 中国浙江宁波
铝合金论文
. G; @# z( J/ N
: H" l8 G& p" ]1 K: h: F5 x* RIn¯uence of aging parameters on the mechanical& U0 I( j2 Z3 U2 S; H( N
properties of 6063 aluminium alloy5 s2 |/ v( ^  ]
Ra®q A. Siddiqui*, Hussein A. Abdullah, Khamis R. Al-Belushi
/ i, B3 E, @/ ^6 [/ mDepartment of Mechanical and Industrial Engineering, Sultan Qaboos University, PO Box 33, Muscat-123, Oman: H+ k4 ^, M9 p- \
Accepted 17 December 1999
铝合金论文.pdf
678.67 KB, 下载次数: 22
 楼主| 发表于 2006-12-23 19:17:36 | 显示全部楼层 来自: 中国浙江宁波
铝合金论文6013合金
Mapping of the rate-controlling steps for environment-assisted
( o! v, E% ^% |fatigue crack growth applied to the aluminium alloy 6013 T6/ q! S2 n) |( }+ x
F. Bergner *, H. Bersch, H. Worch, G. Zouhar
- n# L+ A  Q7 N/ i2 t! ZDresden University of Technology, Institute of Materials Science, D-01062 Dresden, Germany
( R; s! s: O8 v9 r: g# wReceived 16 July 2001; received in revised form 17 December 2001; accepted 20 December 2001
06022321364005809.pdf
142.35 KB, 下载次数: 9
 楼主| 发表于 2006-12-23 19:19:48 | 显示全部楼层 来自: 中国浙江宁波
铝合金论文7010合金
The application of advances in quench factor analysis property1 K& e7 q& H' X: @: H- f+ k
prediction to the heat treatment of 7010 aluminium alloy
% q. B  y8 y- M6 O% a: b# \Robert J. Flynn a,∗, J.S. Robinson b
, A: }( R% T& L8 I" h# Ha Materials Ireland Research Centre, University of Limerick, Limerick, Ireland
9 f) w# x0 N( c! A& G: vb Department of Materials Science and Technology, University of Limerick, Limerick, Ireland
06022412411814145.pdf
229.26 KB, 下载次数: 11
 楼主| 发表于 2006-12-23 19:21:37 | 显示全部楼层 来自: 中国浙江宁波
铝合金6063合金
Abstract
! d, I% a3 A  G9 ]" b; NWear behaviour of age-hardened 6063 aluminium alloy was evaluated under dry sliding conditions. A certain part of the  z# n  d- Z- @
aluminium samples was solution treated at 510 jC for 2, 4, 6 and 8 h, water-quenched then aged at 180 jC for 4 h, and the other
4 \+ A/ b; b. D8 o% `' _part was solution treated at 510 jC for 6 h, water-quenched then aged at 180 jC for 1, 2, 3, 4 and 5 h in a muffle furnace. The0 N6 T1 ~0 W0 g: m, }
as-cast and the aged samples were fully characterised before and after the wear testing using hardness, profilometer, scanning
8 o1 r9 X' l: B) o* h1 uelectron microscopy (SEM), optical microscopy, X-ray diffraction, and energy dispersive detector (EDS). The wear tests using
/ i' |! H, N6 W( ^1 Y* uon a pin-on-disc machine showed that the aging treatments improved the wear behaviour of AA 6063 alloy compared to as-cast
6 Y+ L2 y! C7 W3 u; ^' R% M% J" R# rsamples.; R) @% k' K" @7 }# ^
D 2003 Elsevier Science B.V. All rights reserved.
% [3 k, ]  O4 qKeywords: Artificial aging; Aluminium alloy; Wear; Pin-on-disk tribometer
hhh.pdf
1.02 MB, 下载次数: 16
