我原来装的CAD2002及2007,现在想装CAD2006,可是总是提示错误1402,无法打开主键:HKEY_LOCAL_MACHINE\software\Classes\STFFile\Default Icon。请确定您有足够的权限访问该主键,或者与支持人员联系。+ {2 P, s7 c+ | c" h0 W
后来我把2002和2007全部卸载了,现在什么版本都装不上了。
4 e6 S7 f. j7 @( `4 q$ s请各位帮忙看看是什么问题,不然我只有格系统了!
, T2 l- b& g* |6 E7 k. g; Y& C谢谢!- ]4 J. g! C+ D1 ~
AutoCAD 2006 Setup.log文件如下:
) t O7 _; T* r1 l[1/3/2007 08:42:26] === Installation started on GG by Owner ===
1 a2 a7 }6 m/ N0 D# z( |[1/3/2007 08:42:28] [Info] Windows Installer upgrade is not required. p4 M9 q H" s
[1/3/2007 08:42:28] System Version = 3.1.4000.2435
* e8 _* d% V g' s6 f R" b[1/3/2007 08:42:28] Installation skipped: MSI Runtime 3.0# ]9 I. o: G! G: T, ]' D
[1/3/2007 08:42:28] [Info] .NET Framework Runtime upgrade is not required1 _$ g' \: {- g9 v* q9 f: P$ @
[1/3/2007 08:42:28] System Version = 1.1.4322.2032
7 z8 G0 M+ T$ T1 M[1/3/2007 08:42:28] Installation skipped: .NET Framework Runtime 1.1
5 A2 y/ e+ P, U* r0 t! F[1/3/2007 08:42:28] Installation started: .NET Framework Runtime 1.1 Language Pack2 U& O6 R' I% s( ]1 W9 z
[1/3/2007 08:42:28] Command = "C:\DOCUME~1\Owner\LOCALS~1\Temp\Rar$EX00.578\Bin\AcadFEUI\support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
. T1 e% d8 E( R9 f* F0 _& L[1/3/2007 08:42:44] Installation succeeded: .NET Framework Runtime 1.1 Language Pack
/ Y8 |' y/ `: N9 L! b' e[1/3/2007 08:42:44] [Info] .NET Framework Runtime upgrade is not required
+ U# {; J m$ g7 M; {6 F' B[1/3/2007 08:42:44] System Version = 1.1.4322.2032
- [3 A" l# ?9 W3 B[1/3/2007 08:42:44] Installation skipped: .NET Framework Runtime 1.1 SP16 n* h/ u. P N# K. W. ~( s3 R. ~
[1/3/2007 08:42:45] [Info] MDAC upgrade is not required
: s: c6 w# d$ Y7 k- K, T- a& V4 f[1/3/2007 08:42:45] System Version = 2.81.1117.0- {1 Z6 Y3 q% a( _
[1/3/2007 08:42:45] Installation skipped: MDAC 2.7
' V; F- C; ~/ G[1/3/2007 08:42:45] Installation started: Autodesk DWF Viewer* K1 T6 D6 Y& n& f7 e6 ~
[1/3/2007 08:42:45] Command = "C:\DOCUME~1\Owner\LOCALS~1\Temp\Rar$EX00.578\Bin\AcadFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2+ x, b; N3 M m( h" J! v3 r
[1/3/2007 08:42:46] [Error: 11] 试图加载格式不正确的程序。
/ A% k/ i3 U& R3 Z7 N[1/3/2007 08:42:46] Installation failed: Autodesk DWF Viewer0 i8 _5 h d0 S$ P
[1/3/2007 08:42:46] [Info] Failure is ignored
5 a% \+ v$ Q7 [6 ~9 o[1/3/2007 08:42:46] Installation started: Flash
. L/ I! T+ V7 Z" V9 {[1/3/2007 08:42:46] Command = "C:\DOCUME~1\Owner\LOCALS~1\Temp\Rar$EX00.578\Bin\AcadFEUI\support\flash\Silent Install Flash Player 7 AX.exe" /q
2 {- [+ P. \( e4 R: ]. p[1/3/2007 08:42:51] [Error: 1] 函数不正确。
) |; Q3 v: S* U% ^) a, U6 O. t[1/3/2007 08:42:51] Installation failed: Flash0 s, E/ x5 O0 n: F; f
[1/3/2007 08:42:51] [Info] Failure is ignored7 Q% d: K3 j$ b
[1/3/2007 08:42:51] Installation started: AutoCAD 2006
$ @. B' a- b" x$ p, j[1/3/2007 08:42:51] Command = msiexec /i "C:\DOCUME~1\Owner\LOCALS~1\Temp\Rar$EX00.578\Bin\AcadFEUI\acad.msi" /L*v C:\DOCUME~1\Owner\LOCALS~1\Temp\AcadInstall.log
* ]: T5 O0 ^* M" a5 d* M" f1 C[1/3/2007 08:46:26] [Error: 1603] 安装时发生严重错误
- @4 r+ {8 L6 }& ~9 p* G- P: x7 Q[1/3/2007 08:46:26] Installation failed: AutoCAD 2006* \+ Z; X5 N0 J* B) l$ L( q1 v! h5 l1 q
[1/3/2007 08:46:26] Installation aborted
) ~+ a5 x& j# Z; }9 x% y9 |[1/3/2007 08:46:37] === Installation ended ===
5 T8 L) D/ v4 m9 u) @9 i- e% d" I. ^+ q4 b
[ 本帖最后由 llp 于 2007-1-3 09:12 编辑 ] |
