查看: 1514|回复: 0
[分享] 力值、硬度计量名词术语及定义
发表于 2007-1-22 11:47:57 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
目录  ~4 @5 Q' `; ?& G( B1 Q/ t* @- E
1力基(标/校)准机 ( )8 n* _+ G+ G0 A1 s& n' U0 D
1.1 力 ( Force) ( )3 N0 J9 H) R$ n8 p6 A; M8 `
1.2 万有引力 (Universal gravitation) ( )
9 k' ?5 y! J3 \- T/ h9 [: R0 q1.3 重力 (gravity) ( )% ^" C' R$ A1 e& \5 U
1.4 弹性力 (elastica) ( )
2 Y! V8 n1 r5 M1 t. u( y! Q( q  E1.5 重力加速度 (gravity acceleration) ( )6 a) ^, C3 X6 F3 n) q' X) L
1.6 牛顿 (Newton) ( )* p: W! Y& b% K+ `$ N8 L
1.7 力标准机 (force standard machine) ( )
+ _7 T4 F8 q* ~0 ]$ F: n1.8 力基准机 (primary force standard machine) ( )' O: a% C" D/ B' Q9 P
1.9 力校准机 (force calibration machine) ( )  |: B0 x9 ?5 r, k, ?5 Q* u
1.10 静重式力标准机 (deadweight force standard machine - DWM) ( )6 R2 i8 ^5 `% T; E" o+ L
1.11 杠杆式力标准机 (lever-amplification force standard machine - LM) ( )3 P; {0 p" I2 }
1.12 液压式力标准机 (hydraulic-amplification force standard machine-HM) ( )
8 `. Y" X5 F; Y! I1.13 叠加式力标准机 (build-up force standard machine-BM) ( )
% l* o: A1 a# ]  a1.14 力比较机 (force comparator-FC) ( )5 G; ?4 i' P0 P! {
1.15 扭矩基准机 (primary standard torquer) ( )$ Y  `4 z1 E  d, h, o9 i; ?
1.16 扭矩校准机 (torque calibration machine) ( )
$ q) S/ @- o1 b1.17 静重式扭矩标准机 (deadweight torque standard machine - DTM) ( )1 v2 `" F8 C8 K+ K, d0 T
1.18 杠杆式扭矩标准机 (lever-amplification torque standard machine - LTM) ( )  c" [% E" g! B$ M# L
1.19 串接式扭矩标准机 (serial-connection torquer -SCT) ( )
4 `, e2 D/ S5 ~% v1.20 测力式扭矩标准机 (torquer by mean of measuring force-TMF) ( )  q5 \( H2 o+ l
1.21 扭矩校准杠杆(torque-calibration lever) ( )
1 N$ G7 w  n* C: s$ d6 O1.22 摆锤式冲击标准机 (pendulum impact standard machine) ( )
7 D1 p  q9 Q, r% t5 _5 ]$ R4 Z& U4 q3 o1.23 摆锤式冲击基准机 (pendulum impact primary standard machine) ( )
6 f% i8 S8 O  L9 S8 U1.24 力值不确定度 (force uncertainty) ( )7 o! v; p/ \9 P$ d
PDF created with pdfFactory trial version www.pdffactory.com+ G3 {* O3 J4 N: c
3& Q5 w7 e' c$ @! Y  }# _1 R* u
1.25 力值重复性 (force repeatability) ( )
8 s, s: h9 O# k; I) h" n/ m1.26 力值示偏差(force indication deviation) ( )3 y3 H! m# }2 }) ?
1.27 力值范围 (force range) ( )
. f+ F9 u4 z! k* E7 i; ~8 ~1.28 力级 (force step) ( )7 `: k5 V7 f2 z! ^+ y
1.29 灵敏阈 (sensitivity threshold) ( )
; s9 Q. ]" G7 l% t% D1.30 寄生分量 (parasitic components) ( ): d$ A4 ~, `% R) f/ p8 f% h4 t5 z
1.31 旋转效应 (rotation effect) ( )- _; L% O9 ]* o5 m; o
1.32 重叠效应 (overlapping effect) ( ). {* ?+ ^, t1 [! ~3 E
1.33 力值直线度 (linearity of force) ( )( W, F0 Q: D5 F2 s# ?1 t) v$ }
1.34 附加滞后 (additional hysteresis) ( )
5 r4 k: E2 L. ^+ z+ p4 }( n' d1.35 递增负荷 (increasing force) ( )
. I/ U) Y( t  J# f1.36 递减负荷 (decreasing force) ( )# \2 J5 N$ Z0 s, C; q: N: y2 r
1.37 逆负荷现象 (counter-force phenomenon) ( )
6 }2 R3 ?& B, t% F' b+ A1 N1.38 加荷时间 (period for loading) ( )
2 f/ u) ~' F3 a1.39 加荷速率 (loading rate) ( )4 _' A$ B! S3 h# ?( X  C- r
1.40 卸荷时间 (period for unloading) ( )
, x9 P8 w3 q% H% X1.41 卸荷速率 (unloading rate) ( ). x! V& a9 S, `# l; V
1.42 砝码 (weight) ( )
1 q" `5 J- \! J! I1 Y3 Z4 u1.43 机架 (fixed framework) ( )9 e7 u1 O- {1 @. W8 H1 w
1.44 负荷机架 (loading frame) ( )
4 h5 ~  L8 {# \$ b# o% O6 J( T! I1.45 压力试台 (Platform for loading) ( )' X* L9 ?- G# T% Q
1.46 提升架 (lifting frame) ( )
+ g; B% P. }' z: w! `$ n9 w1.47 加荷横梁 (beam for loading) ( )
. Q3 L  l6 J1 ]$ b1.48 压缩空间 (room for compression device) ( )
3 m* o7 y$ `  \& y, {8 }8 o! |' f1.49 拉伸空间 (room for tension device) ( )6 f2 e3 H! A& @1 y
1.50 反向器 (reverser) ( )' S0 d( s9 b0 o9 L2 r
PDF created with pdfFactory trial version www.pdffactory.com9 e4 \' d( f0 T, ^# K! k) ~
4
; l  q) `& q. W! H8 [. @& l( I1.51 杠杆 (lever) ( )
, T8 |1 z) C+ W9 [( }0 w1.52 支点刀 (supporting-knife) ( )
) n4 |3 |. n& t) j1.53 重点刀 (weight-knife) ( )8 q# X7 J- M5 ?8 k0 u- _: ^( I
1.54 力点刀 (force-knife) ( )' Z! L# R/ k+ G' [7 ?- j/ k7 C2 I
1.54 杠杆有效长度 (effective length of lever) ( )
3 m: T3 {- l  l' {; k& e* w" [  a1.55 杠杆比 (Lever amplification-ratio) ( )7 [$ x1 D2 i" G8 k# b
1.56 直接加荷部分 (directly loading unit) ( )
: Q! j: y) V: k1.57 负荷放大部分 (main unit) ( )2 h/ |  T& P2 r& M0 c3 g
1.58 比例活塞 (proportional piston) ( )
& }# I' ?5 _* w) P  j+ d6 s$ D1.59 比例油缸 (proportional cylinder) ( )$ L' b0 U0 U# o7 o2 {2 q- R
1.60 加荷活塞 (loading piston) ( )
. V; y, O3 A: w& m( Z, G9 U1.61 加荷油缸 (loading cylinder) ( )
# p) s+ Q1 O# S0 u- O1.62 放大比 (Amplification ratio) ( )
3 B: H( z4 r8 {3 \- B+ w: ^2 H1.63 活塞有效面积 (effective cross-area of piston) ( )
" z/ @. S9 h& H0 F# [* n1.64 油缸转速 (turn-speed of cylinder) ( )  i4 R. i, W9 H8 Q, q
1.65 油缸旋转线速度 (speed of cylinder) ( )
2 U8 G/ d: u0 p9 I. A2 [1.66 导向活塞 (guide-piston ( )
" H/ T0 X: z+ V: W1.67 最大压力 (maximum pressure) ( )
& p: u1 p( b5 T/ X) L$ Y& b1.68 负荷转换活塞 (piston for load relieving & pressure transmitting) ( )
/ l+ N/ P' S, q/ h& f% T1.69 负荷转换油缸 (cylinder for load relieving & pressure transmitting) ( )6 p8 L/ P2 |1 i: o+ A/ L! r* v  h
1.70 同轴度 (coaxality) ( )
5 V  }$ g5 T& _1.71 几何同轴度 (geometric coaxality) ( )+ M/ G- X4 [* k; c. r
1.72 受力同轴度 (coaxality with load) ( )
9 i' d6 H+ @; {; ~% e1 ?2 测力仪 ( )
9 ^0 R/ H2 w, {: K7 @2.1 测力仪 (dynamometer) ( )
1 y+ w9 q9 y8 N( f( p& q3 G2.2 标准测力仪 (standard dynamometer) ( )
" M  K" d: s+ p* i/ hPDF created with pdfFactory trial version www.pdffactory.com
' [1 [  l0 L& b4 A6 }5
% ?, a7 d6 U1 P# m* Y2.3 弹性体 (elastic element) ( )
6 q% }9 i- T- q( e2.4 变形测量装置 (indicator of deflection) ( )4 f+ p# ?' _( M7 X1 W3 A
2.5 变形 (deformation) ( )
. t4 G" X& @$ T2.6 额定变形 (deflection under rated load) ( )0 J( E8 s  Z  _9 P  }
2.7 读数值 (reading) ( )$ W8 h1 {! c1 t) o$ R. G2 @
2.8 变形示值 (indication of deflection) ( )
6 j, k" j7 [0 z2.9 测力环 (proving ring) ( )
/ n/ d) E/ r' \2.10 压向测力仪 (compression dynamometer) ( )
- H  ?9 \" z/ W; u2.11 拉向测力仪 (tension dynamometer) ( )6 J: F6 v! P6 h
2.12 双向测力仪 (tension & compression dynamometer) ( )& Q0 D: J9 @; F
2.13 负荷 (load) ( )1 l1 Y. Z4 ^! k- ?8 e
2.14 静负荷 (static load) ( )
1 O$ t1 |1 O# }0 ~2.15 动负荷 (dynamic load) ( )$ }6 Z+ n7 E1 D' J0 |  s
2.16 循环负荷 (cycle load) ( )
& R, b' R4 c3 _* k0 Z0 ~2.17 随机负荷 (random load) ( )
- Q8 A; t/ J3 E) V. j+ K# b2.18 冲击负荷 (impact load) ( )
- }3 V* e1 K6 ^8 S6 B+ \2.19 额定负荷 (rated load) ( )9 y( w% w( i" {
2.20 最小负荷 (minimum load) ( )' c# S; `" k2 h. Y$ {
2.21 负荷范围 (load range) ( )7 c! w( S. y* @9 i- U9 g: b
2.22 预负荷 (preload) ( )
5 _' n6 F+ M) F5 R& R( X8 v$ G2.23 检定 (verification) ( )
+ |+ B% ?) `" \, v6 T: _- e2.24 定度 (calibration) ( )$ u( b! y0 _5 f8 |
2.25 进程定度 (increasing calibration) ( )
' e. b) m6 {' n5 H/ ^* P. O2.26 回程定度 (decreasing calibration) ( )
5 j5 ^9 m! k2 p5 [* n2 M8 H: ]4 @2.27 分度值 (division) ( )
; h" c8 N3 G8 J2.28 重复性 (repeatability) ( )
4 R: h  w5 h! m$ e- B2 }4 F4 l+ ?PDF created with pdfFactory trial version www.pdffactory.com
, V4 e! d# c) A/ D6
# `$ I0 Z# M+ H- j" w2.29 滞后 (hysteresis) ( ); j1 a  D7 n& l/ V3 v
2.30 稳定度 (Long-term stability) ( )# P! R4 c! E1 \7 a
2.31 温度修正系数 (coefficient for temperature correction) ( )
) w4 p* _! O: P, j1 Y% p0 a2.32 校准方程 (calibration equation) ( )# Q9 g1 w' Q4 G
2.33 管形测力仪 (cylindric dynamometer) ( )
4 _& s3 ?) h1 ~, w& |7 u( j' U2.34 扭矩仪 (torque-meter) ( )' K6 z. f6 N9 N, |3 P
2.35 标准扭矩仪 (standard torque-meter) ( ); H# F2 Z/ o. W  J  }
2.36 扭矩扳子 (Torque wrench) ( ): h+ }5 X5 {) E; N, q9 S
2.37 扭矩扳子检定/校准仪(Calibrator of torque wrench) ( )
1 Y' s+ n  j3 O+ \& \2.38 扭矩改锥 (Torque driver) ( ); [( E$ O3 W( {0 K0 P2 z7 D4 R
2.39 扭矩改锥检定/校准仪(Calibrator of torque driver) ( )
. Y  i$ N  w" O! F6 E/ A2.40 测功机(Machine measuring power) ( )
) i" a6 e! c6 y0 R2.41 摆锤式冲击机检定标准装置 (standard equipment for calibration of pendulum: @, o4 l6 I6 A" C
impact machine)
. ~9 O' m* G6 ]# I4 V( )
0 W& ]+ l6 E2 C2 h" X' O! m2.42 标准冲击块 (standard impact blocks) ( )1 B# E0 l9 a7 N% Q
3 负荷传感器 ( )
& y; Y! B' q9 b4 z: x$ |3 ?. P3.1 环境条件 (ambient conditions) ( )
; G6 [' L) N" p3 |3.2 环境温度 (ambient temperature) ( )
7 j: ^; D6 o) J* M! E3.3 使用环境条件 (ambient condition,operating) ( )
2 H- `% @; V0 B1 \% S& U/ V8 S- }' Z3.4 室内条件 (room condition) ( )
2 \) |: \+ I9 W) Q8 B' g1 K8 Z3.5 标准试验条件 (standard test condition) ( )
1 E0 V* I) S: i& m. |3.6 负荷传感器 (load cell) ( )0 Z9 Y7 W9 n2 N
3.7 测力传感器 (Force transducer) ( )2 x1 U( h5 c" o2 f4 f' m( {4 L/ R
3.9 扭矩传感器(Torque transducer) ( )
1 y8 ^. [, w$ k5 e3 V# a3.10 多分量传感器(Multi-component transducer) ( )
* y3 l+ k& R9 j, W6 u$ j3.11 参考传感器(组)(Reference transducer(s)) ( ), _2 M% K' R; O; N- D
3.12 多分量校准系统(Calibration system for multi-component transducer) ( ); h6 H; g' k6 O# ?, p6 e
3.13 应变式负荷传感器 (strain gauge load cell) ( )# ^4 K9 S8 V% E4 @
PDF created with pdfFactory trial version www.pdffactory.com7 n& ?- k$ e: ?
7
7 l; n; U! Z! \8 E* ^2 H3.14 压电式负荷传感器 (piezoelectric load cell) ( )5 w6 N* q& y- Q, C3 h& \( l5 I
3.15 压磁式负荷传感器 (magneto-elastic load cell) ( )
; }/ q5 m& q9 |( Z  d3.16 电感式负荷传感器 (inductive load cell) ( )
- O( m4 L/ P3 Y3.17 电容式负荷传感器 (capacitive load cell) ( )& z/ X2 C2 _* U  W6 j( y2 T9 x
3.18 压阻式负荷传感器 (piezoresistive load cell) ( )/ Y9 a" ^! X; G" V) ~
3.19 敏感元件 (sensing element) ( )
% T1 J0 L/ ]! @! [% U: R3.20 主轴线 (primary axis) ( )* y. [- e" x# i; s7 L) X
3.21 轴向负荷 (axial load) ( )) F  V; l. v. d5 }& s" l
3.22 安全过负荷 (overload, safe) ( ); D3 S1 v" x1 e  M! w5 u. j9 F2 U
3.23 极限过负荷 (0verload, ultimate) ( )
  \) ]/ d5 R- h: C% a  r' a% S0 r  c3.24 侧向负荷 (side load) ( )! n- i2 D9 K/ K# N
3.25 偏心负荷 (eccentric load) ( )
% X; n+ s$ O8 |; f3.26 同心倾斜负荷 (angular load,concentric) ( )
) W# [; I+ U3 t5 ?/ @) v" e% r3.27 偏心倾斜负荷 (angular load,eccentric) ( )4 M* E% J& e0 V9 {) y7 c0 O
3.28 输出 (output) ( )
# I' o8 s# L) p% O& p3.29 额定输出 (rated output) ( )
8 g+ s+ T. i9 ?2 s3.30 零点输出 (zero output) ( )
/ ?; T" w  W/ u9 v3.31 过冲 (overshoot) ( )
+ a% J3 U" h7 U0 W4 X% l4 X+ ~; y3.32 校准 (calibration) ( )
% `' e9 }! W; z3.33 静态校准 (static calibration) ( )
& i3 {  L& w5 n: A* C8 {' E3.34 校准曲线 (calibration curve) ( )5 v! T( v0 p* m& y$ R/ C" X
3.35 工作直线 (operating line) ( )
8 R8 z& h5 ?- b; f$ ^3.36 端点直线 (end-point line) ( )
. ^( ?* `8 X- R3.37 端点平移直线 (end-point line,translation) ( )/ M  e- Y: D+ P5 G& W1 j
3.38 最小二乘法直线 (least-squares line) ( )0 A- ^8 t; l6 E9 P
3.39 灵敏度 (sensitivity) ( )6 t( {$ N: e  H( y4 J
3.40 灵敏度允差 (tolerance,sensitivity) ( )
4 E) Q8 p9 j  u9 `6 Y: y3.41 不对称度 (un-symmetry) ( )% M- I) ~5 u0 f
3.42 直线度 (linearity) ( )3 X& P- O& ?5 r! @4 d" d4 B
PDF created with pdfFactory trial version www.pdffactory.com9 |% k6 z' K1 L
8) z  ?1 p$ S9 k* X' U
3.43 综合误差 (combined error) ( ): g& _* w. `3 X- g" w( G: N9 \
3.44 蠕变 (creep) ( )
5 h$ t: J, r# F: u8 D6 E3.45 蠕变恢复 (creep recovery) ( )0 Z! u9 ]+ t! ^. r
3.46 输入电阻 (input resistance) ( )  S( C5 T$ z+ }; P( i
3.47 输出电阻 (output resistance) ( )+ s' z  n- F9 G7 X' Q+ \2 {* n) }
3.48 绝缘电阻 (insulation resistance) ( )
* o$ A9 I3 g+ z  A7 z" z3.49 激励 (excitation) ( )
& W1 Y8 {: V4 b  r4 S2 j$ y3.50 最大激励 (maximum excitation) ( )2 g; h- }+ ]& F$ c; P  B
3.51 补偿 (compensation) ( )
9 v1 I, X/ [4 W" j' O5 L6 R3.52 安全温度范围 (temperature range, safe) ( )* \+ i8 C$ x% o2 ^
3.53 额定输出温度影响 (temperature effect on rated output) ( )
! ^5 c; B# ?; m- n0 M3.54 零点输出温度影响 (temperature effect on zero output) ( )
7 G2 w6 G2 m6 _! x; J) _0 x3.55 温度补偿范围 (Temperature range,compensation) ( )8 `. N( G1 G' S3 O2 i/ W
3.56 预热时间 (warm-up period) ( )
( R  D+ i- R/ K3.57 稳定时间 (stabilization period) ( )
  p8 ^# |- ^3 u3.58 额定输出环境影响 (span instability) ( )9 M2 \" M9 v0 z6 A7 D
3.59 漂移 (drift) ( )
9 O  a  e. l: c6 N# ]3.60 灵敏度漂移 (sensitivity drift) ( )
+ ]9 x5 l( z+ U: {; }3.61 零点漂移 (zero drift) ( )! `/ A8 B/ O) |2 C: b' ^* w
3.62 零点永久漂移 (Zero drift,permanent) ( )
2 R& u4 R5 C# o3.63 零点恢复 (zero return) ( )
( Z! l  n  q8 R3.64 零点环境影响 (zero instability) ( )/ v$ H  x* V1 v$ j' m
3.65 零点移动 (zero float) ( )1 T$ K: D: k# r  F
3.66 使用寿命 (Life,operating) ( )
5 h* ]1 t1 m# d- t# }/ |6 Y3.67 循环寿命 (Life,cycling) ( )* f' }4 i# A+ K( f( b: S! J/ D6 Q5 q
3.68 固有频率 (natural frequency) ( )( u) [! A7 q) v1 ~  y7 U! ?
3.69 动态特性 (dynamic characteristics) ( )
* w: c2 ]  X7 x" g8 Y% j3.70 频率响应 (frequency response) ( )
力度、硬度计量名词术语及定义.pdf
524.8 KB, 下载次数: 14
