查看: 3785|回复: 4
[分享] solidworks sp3.0 先知道
发表于 2007-1-25 20:53:55 | 显示全部楼层 |阅读模式 来自: 中国重庆
DescriptionProduct
Need PageSetup object to support 'High Quality' toggle settingAPI
Cannot select through transparency in this assemblySolidWorks
Can't apply datum feature symbol to silhouette edges in this drawing.'
Drawing logo is exported in dwg file when 'display sheet format' option is off'
Edge fillet fails in this part; face fillet works'
Dimension goes dangling when it is being changed and updated in this drawing'
Section view is incorrect, if section is created using the view display section tool in this assembly.'
Creating a custom elbow does not zoom to view that elbow anymoreRouting
When second/dual monitor is disconnected, SolidWorks should position dialogs back onto the primary monitor.SolidWorks appears to hang/freeze'
When a certain size fillet radius is used adjacent face becomes transparent and fillet fails at a slightly larger value'
Cannot select body in graphic area during Mirror command if Section view is active'
Features fail in 2007 that did not in 2006 starting with variable radius fillet'
BetaID: 20598: Hole table sequence is not correct, the last selected face is the first face which get the numbers.'
Fillet on CSWP 'Frame' part is transparent'
derived sketch does not update when a change is made to its parent sketch'
The preview of instances to skip and the preview of sketch element in a linear pattern are in opposite directions.'
FeatureWorks: no base flange detection of an open profile.'Office
Partial section fails in this assembly drawing where part contains a very large (350 x 250 meter) sketch'
Please don't forget, we need to use this kind of sketch conversion in a part that is repeated 10 to 20 times in an assembly with one configuration per part in this assembly.'
near/far side countersink is shown in the preview (and is created on ok) but the option is not checked in the PM when using tap drill'
Multiple mates Demo files, hide/show sketches not showing in pitch circles configurations.'
Software instability while doing a sketch linear pattern - when the end points coincide and number of instances are high.'
Incomplete import of STEP file.'
Unable to hide one layer on this DWG using DWGeditor 2007; was possible in 2006'
Entities shift (including Detail view label) when saving/exporting this drawing as DWG'
SolidWorks hangs creating a sketch offset'
Saving a route changes the units on saved routing componentsRouting
DWGeditor 2007 instability when opening this DWG file.'
The edge of a shell, the edge is divided after Extrude.'
Improper Color(95 instead of color 93) is displayed on saving the Drawing file as DXF/DWG with mapping enabled.'
Mate is not displayed in BOLD font in view mates or Property manager tab, when all componets involved in mate are selected.'
Unablke to open this drawing'
Component mates do not display in property manager'
Instability replacing component in this assembly when section view is enabled.'
Reset size does not work correctly in this drawing'
Freeform feature can't deform this face in this case'
Converting edges of imported body gives incorrect result in 2007'
Rebuild errors with specific part when opened in 2007 SP2 which were not present in 2006 SP4'
Copy and paste many entities in dwgeditor 2007 sp1 cause instability sp0 did not'
We need the same function for all equation, not only the last one.'API
check in of attached assembly fails with no errorPDMWorks
open dxf file as new solidworks drawing causes crash - file specific'
Bhatch command in DWGeditor causes crash when try to select area to hatch – file specific'
CommandManager::RemoveCommandGroup crashes SolidWorks'API
Note : This issue is very important for us because we use this axis to create a circular pattern in another assembly, and when we do that every thing becomes wrong.'
Assembly missing feature tree'
Cannot select a sketch that is outside of RouteAssy for Selections.Routing
When choose materials of a cover, color is reflected to a component.'
In-context configurations do not update correctly when open using 2007. Happens only with files created using 2006 SP4.1 or earlier'
Context menu created with CommandManager::AddContextMenu no longer shows icons'API
When we try to convert the face outline, we can't extrude the sketch.'
SolidWorks crashes if a feature is selected before suppressing a component.'API
The interactives what's new does not work in spanish'
The History/Notes section of the Document Infomation window does not refresh when changing file selectionPDMWorks
DWGeditor crash when use Extend command and choose extend all - file specific'
Error opening and rebuilding this part'
SW crash trying to move a dimension inside this drawing'
Error Invalid class found in file reopen file after save in 2007'
Save as DWG causes crash when export all sheets to one file option used and sheets named layout1, layout2, etc'
CORRUPT: Error message when opening this assembly "Invalid class found in file"'
Unable to create desired surface-sweep feature'
Corrupt sheet format'
Importing this IGES file as PointCloud; terminates SolidWorks without any warning.Reverse Engineering
Preview in DXF/DWG Import -Document Settings Window doesn't work - Import UI is broken'
section line letter shifts in export DWG file'
The addition of the 'Check1' check-box to the import options dialogue has damaged the dialogue's layout'
Installation manager upgarding from SW2007 Sp2EV to SP2.0 does not recognize need for Cosmos upgardes'
SW viewer crash when print drawing'
Abnormal program termination moving dimension in this drawing'
Notes in sheet format do not adhere to the layer they are in. Notes are visible even if layer is switched off.'
Conversion wizard: converted parts in assembly do not open as lightweight, and have constant rebuild lights.'
Unable to select column header and select "read from file"PDMWorks
Corrupt part'
Pipe tap hole does not refer the 'configure data' table for the countersink values.'
发表于 2007-1-25 21:29:40 | 显示全部楼层 来自: 中国福建福州
sw现在几乎1个月1个补丁。是不是准备更换内核?
发表于 2007-1-26 09:38:04 | 显示全部楼层 来自: 中国陕西西安
发表于 2007-1-26 09:46:14 | 显示全部楼层 来自: 中国广东中山
也太快了点儿吧!
发表于 2007-1-26 15:04:56 | 显示全部楼层 来自: 中国上海
3.0?怎么升的这么快,在坛里看到升级失败的的人不少,我看还是不要升的好,
