查看: 1958|回复: 4
[分享] SolidWorks Vista Beta 2
发表于 2007-2-17 07:37:08 | 显示全部楼层 |阅读模式 来自: 中国福建福州
已有SolidWorks Vista Beta 2,目前只有E版。SP2.2" k( G7 b: R" d/ c# t* i- i
Service Pack 2.2 is the beta 2 release of 32-bit SolidWorks 2007 on the Microsoft® VISTA operating system.
/ S  k4 n. O3 @' f! v3 @/ _/ g5 Z7 ]# h0 {VISTA ImplementationActivationIf you activate a SolidWorks product manually via e-mail, you receive a response file that you store on your computer. When you rerun the SolidWorks Product Activation Wizard and use Open Dialog box to browse to the location of the file, the file is not visible. ! k7 g1 J& V2 C9 y! t
To load the file, use an Explorer Window to browse to the file. Copy the file name into the File name: field of the Open dialog box and click Open.4 g2 r1 c7 [+ L" P* o+ I  ^
Language SupportEnglish only.
1 |4 u6 C' C) C  x# gGraphics PerformanceGraphics performance in SolidWorks may be noticeably slower under Vista. 4 E6 H. e" B! Z' @$ J- R
Hardware accelerated OpenGL drivers are not yet available from major graphics card vendors such as NVIDIA and ATI. The SolidWorks beta implementation supports software-mode OpenGL drivers supplied through the Microsoft Vista install.
; i! L7 }" n+ o( T6 b$ D8 }, ENon-supported FeaturesThe following SolidWorks features and products are not supported for SolidWorks with Vista:! k) H/ t8 Z! s! o
* u+ R/ H+ t: ^7 {" L7 t
    MoldflowXpress
  • MDT translator
Access to Content FilesYou may receive a file access warning message (Invalid or not writable) when opening content files such as hole wizard or materials. Select OK to continue normally or select a different folder that is writable.
' u, t; M* H5 b2 G6 tToolbox data is now installed in a hidden folder in the ProgramData folder. Set the Show Hidden Folders option in Microsoft Explorer to view the folder.
) W. d4 l( h# o/ L" i/ QUse of Beta Software
    Do not use Beta software for production work.
  • We recommend that you save backup copies of all SolidWorks files (parts, assemblies, and drawings, document templates, sheet formats, or library features) before opening them in SolidWorks 2007 on VISTA.
, S2 y; X! R* P: S3 J+ L4 e2 u  u4 A2 u: T4 _$ {
[ 本帖最后由 shenrf 于 2007-2-17 07:38 编辑 ]
发表于 2007-2-20 09:03:37 | 显示全部楼层 来自: 中国湖南株洲
什么时候会出现D版。
发表于 2007-5-9 12:56:17 | 显示全部楼层 来自: 中国浙江杭州
装好用了一个月 可惜没有Crack 然后卸载重装XP!郁闷
发表于 2007-5-9 15:20:43 | 显示全部楼层 来自: 中国香港
有否朋友試用,效果如何?
发表于 2007-5-10 10:34:19 | 显示全部楼层 来自: 中国四川成都
没有Crack ,那你做个系统的ghost镜象,到期就恢复,只花几分钟时间!
