查看: 1939|回复: 1
[转帖] 金属材料的物理、声学性能参数
发表于 2007-2-21 15:33:54 | 显示全部楼层 |阅读模式 来自: 中国江西九江
材料密度
$ @3 [. D1 G* A% y5 d- ^2 C# b/ Dρ9 p4 i7 b6 i# W. C# J, L& r
g/cm3
切变弹性模量
* p4 g$ H! Y: o3 b) @3 UG x1011
4 Y6 X. D4 @: J( T$ J(达因/cm2)
杨氏弹性模量/ V" k" B6 O5 ^7 K
E x10112 C7 H  |$ D) A1 A/ z4 c
(达因/cm2)
泊松比, N& y4 W% X" g7 A4 L* L
σ
声阻抗  s( o( j5 N, H4 H
Z x106
/ E& ^0 L2 X& n$ \(g/cm2s)
声速 Km/s
体积纵波CL横波
5 `+ S, Z% H2 O* A  h' Q4 ?- KCS
瑞利波1 O1 x5 j9 {0 b! {! w
CR
金属
铝Al2.72.566.850.341.696.263.08
铝1100-02.71   1.726.353.102.90
铝2117-T42.80   1.756.253.102.79
铝2502.71   1.726.353.102.90
铝17ST 2.697.180.3551.756.253.102.79
铝LY12板材     6.133.07
铍Be1.8214.0829.650.052.3312.808.717.87
镁Mg1.741.614.570.311.015.773.092.74
镁Am351.74   1.015.793.102.87
镁M1A1.76   1.015.743.102.87
钼Mo10.2
6.38
6.253.353.11
钯Pd12.0   3.63.0
钴Co8.9
铪Hf13.31
钒V6.1
铬Cr7.19
铌Nb8.57
铼Re20.53
铱Ir22.4 51.4
10.7
铂Pt21.45.9716.80.398.463.961.67
铂铱合金25板材     4.311.95
镓Ga5.91
硅Si2.33
锆Zr6.5   2.84.31
锆合金6.54    1.92 2.40
锑Sb6.7 7.75 1.442.160.81
锌Zn7.14.1210.30.252.964.172.41
铋Bi9.61.193.140.332.142.181.1
铀U18.7    3.371.93
镉Cd8.61.944.950.302.42.781.5
银Ag10.52.367.320.383.83.61.5
德国银8.7   3.124.76
钽Ta16.6 18.6 5.563.35
金Au19.32.787.950.426.263.241.2
铟In7.31
铊Tl8.58   4.254.952.18
锡Sn7.32.045.440.332.423.321.67
汞Hg13.55   1.951.45
汞Hg(20℃)13.55/13.6   1.9731.451
钨W19.2513.135.40.359.985.182.87
2.65
超硬合金11-15   7.7/10.26.8/7.3
铁Fe7.78.0320.60.264.55.853.232.23
铸铁6.95/7.35   2.5/4.03.5/5.62.2/3.2
QT60-2球墨铸铁      3.018
7.7  0.254.535.88/5.953.2/3.28
302不锈钢7.9  0.284.475.663.122.89
304不锈钢7.9   4.465.643.07
347不锈钢7.917.5819.50.304.545.743.102.79
410不锈钢7.67   4.135.392.992.16
430不锈钢7.7   4.636.013.36
1Cr18Ni9Ti板材     5.773.05
0 P) b$ C$ X4 L4 T, q3 p: U  P- T
9 D& x8 Z% R$ c( S[ 本帖最后由 asdolmlm 于 2007-2-21 15:36 编辑 ]
 楼主| 发表于 2007-2-21 15:35:56 | 显示全部楼层 来自: 中国江西九江
材料密度
( x# r0 M3 I; `0 M/ e( r, N+ f" Zρ
% @) c9 G3 C$ \g/cm3
切变弹性模量( D$ O; L# {7 `: K
G x10119 X- U3 D/ G; W; C
(达因/cm2)
杨氏弹性模量: I' d" G$ h1 s4 L* T9 _
E x1011! G; C2 \9 l$ @
(达因/cm2)
泊松比9 Q* [; f/ F0 Q6 Q1 i
σ
声阻抗
4 p/ W# H' j1 O# u, d: X: a. nZ x106
" j7 O7 Z+ J3 W! I(g/cm2s)
声速 Km/s
体积纵波CL横波
& t0 {8 I1 @! I5 s9 O. g  yCS
瑞利波
$ D- e) Z( V( M( I, R6 f) ~CR
铜Cu8.94.5512.30.354.184.72.262.15
黄铜8.54   3.964.642.051.84
康铜8.86.1316.30.334.65.242.64
紫铜8.93   4.074.6
锰铜8.44.6412.30.333.94.62.35
铜1108.9   4.184.72.261.93
铜260(弹壳黄铜 70%)8.53   3.273.832.051.86
铜464-467(海军黄铜)8.41   3.734.432.121.95
铜510(磷青铜 5%A)8.86   3.123.532.232.01
铜752(镍银65-18)8.75   4.044.622.321.69
白铜8.43.9210.080.374.04.752.16
铅Pb11.40.5861.640.442.462.170.70.64
硬铅(94Pb-6Sb)10.88   2.352.160.810.73
锰Mn8.44.6412.30.333.834.662.35
镍Ni8.87.7120.10.314.955.632.962.64
镍铜锌合金8.43.9210.80.374.04.752.16
Inconel镍基合金8.5   4.955.823.022.79
X-750镍基合金8.3   4.935.943.12
Monel镍基合金8.836.5517.950.3274.725.352.722.46
钛Ti(工业纯)4.5   2.756.103.122.79
钛合金Ti150A4.54   2.776.103.122.79
钛合金TC11(BT9-Zr)4.48   2.836.153.2
钛合金TC11(BT3/1)     6.18
碳钢,退火合金钢7.85   4.665.943.243.0
退火碳钢7.86   4.685.953.263.0
淬火碳钢7.8   4.65.903.23
52100钢(退火)7.83   4.695.993.27
52100钢(淬火)7.8   4.65.893.20
D6工具钢(退火)7.7   4.76.143.31
D6工具钢(淬火)7.7   4.66.013.22
