查看: 1796|回复: 5
[已解决] One VFD vs Motors
发表于 2007-2-26 13:05:19 | 显示全部楼层 |阅读模式 来自: 加拿大
Is there any VFD that can control two more motors? Thanks
发表于 2007-2-27 13:35:56 | 显示全部楼层 来自: 中国黑龙江哈尔滨
可以的,但要被控电机的参数相同才可
发表于 2007-3-8 08:48:03 | 显示全部楼层 来自: 中国山东临沂
回复 #1 frankljh 的帖子
yes,most  VFDs can control two or more,but at first the  VFD must have enough capacities.
 楼主| 发表于 2007-3-10 23:05:12 | 显示全部楼层 来自: 加拿大
Can I use a converter from serial mode to parallel mode to drive two more motors that have different parameters if my VFD doesn' t have enough capacities?
4 o. ]% k7 h8 g5 }$ i( a; F/ j# b$ ^; [+ q4 @
[ 本帖最后由 frankljh 于 2007-3-11 05:22 编辑 ]
发表于 2007-3-11 10:32:10 | 显示全部楼层 来自: 中国山东临沂
回复 #4 frankljh 的帖子
Your VFD won't work normally  if your VFD doesn' t have enough capacities.
 楼主| 发表于 2007-3-22 16:30:26 | 显示全部楼层 来自: 美国
The capacities means Ampere capacities which goes through a VFD. If not enough, a VFD will
+ N( m  P! I# `be tripped when it is on. Thanks for your help.
