发表于 2007-3-4 14:58:45
来自: 中国黑龙江哈尔滨
如何对UG文件进行公制英制转换
" _- [5 B, f+ x5 A6 H% S# Y4 O+ a5 S! f2 {% Y" \, D
1. 只进行单位转换,保证实际长度一致.(When you just want to convert the Unit but keep the same length.)
$ W" C, A+ ^% w4 s$ T8 }, C7 ^1 V+ `* T' p+ f) b ~ b# _$ n
a. Start->Program->Unigraphics V1x.0->UG Command Prompt+ E* h& O, t" B$ p, J
b. Cd d:\ugs150(eds140)\ugii * V, u% ]5 n1 o, \
c. Ug_convert_part -in (-mm) name.prt
' _6 U" w5 M0 M8 \4 ]2. 进行单位转换,保证数值一致,实际长度放大或缩小.(When you make a mistake unit, So you want to convert the Unit but hope keep the same parameter value. )
Z& [+ J- n$ k
/ G$ U( M- R7 ]0 h( M8 `a. 启动 UG, 打开UG part 文件,进入Modeling. 8 d4 |# i8 I M4 K7 f, [
b. Toolbox->Expression->export 产生 name.exp 文件.- @; {0 w, c9 d. V" o* w8 D$ k
c. Start->Program->Unigraphics V1x.0->UG Command Prompt
9 E2 z$ t! H) X5 Ld. Cd d:\ugs150(eds140)\ugii
6 X8 ~! V: r, b- m) xe. Ug_convert_part -in (-mm) name.prt
8 v7 H5 _/ q/ a5 @ p, p5 Rf. Close UG part 文件, 重新打开 UG part 文件。进入Modeling.
! |8 M( z- S" @# ]1 `9 g% X$ Vg. Toolbox->Expression->Import with option(Replace Existing). |
