英文版的聚合物数据手册,介绍了各种聚合物的各种物理和化学数据资料,相当实用。
( C( R @' Q9 U" K- {
; b) \ y; x f9 W* e6 j. |4 VBROWSE/SEARCH CONTENTS
; E" z3 r% b8 mTo find a material of interest, search this page using your browser's search/find option, or use the
& \. p) C8 Q: b9 ?+ Q$ V. oalphabetical browser.% U3 N- h, f; ^. G4 g0 W
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
1 {8 x' `* Z5 V7 S: {Click on the material to view the full text of that entry in PDF format. To view the PDF files, you; U: a( A9 L9 V0 g/ S) f i5 R# q
must have Adobe Acrobat Reader Version 3 installed on your computer. If you do not have the
" z t" u+ p+ q1 Q$ K1 hfreeware reader, it can be downloaded from Adobe in the United States or Adobe in the United
% H/ T5 R: s5 z: YKingdom.# [% X9 X: I' _0 F
Acrylonitrile-butadiene elastomers
1 ]! X$ o. m3 f, R# u2 pAlkyd resins
2 Q- v- {8 z8 ]1 bAmino resins
+ g) o" d9 q- U) U5 b5 KAmylopectin+ A* e! ^ M: G+ _! A
Amylose5 k) h5 u! Q) T: u% `* W
Bisphenol-A polysulfone
+ T! r# j4 e( y* T+ fCarborane-containing polymers
7 \! l2 _6 n4 TCarboxylated ethylene copolymers, metal salts (ionomers)
2 L! K( Z; Y1 q) W* G, j+ W0 |4 MCellulose
: ^' n9 i* X4 _- zCellulose acetate6 C. a* t3 q, A) a3 E6 D
Cellulose butyrate! o& n4 J9 v$ }: I9 d
Cellulose nitrate
z5 h) t: S9 R5 r. Q( f; NChitin: S _: }3 A- v! h, a1 ]) y
Collagen
/ b2 t$ z* m) J. BElastic, plastic, and hydrogel-forming protein-based polymers+ w2 C2 o8 y I; d7 r
file:///F|/Temp_temp/contents.htm (1 of 10)7/16/2005 7:02:22 PM
+ }1 ]8 t: w+ \# k, WEpoxy resins6 G6 z' Q2 d: W$ |
Ethylcellulose% j4 h5 z/ ~/ m: c- x* i" q \+ v) }* M
Ethylene-propylene-diene monomer elastomers
$ o% }7 y4 K4 e _$ O% MEthylene-vinyl acetate copolymer
. {9 a( L' o: ~7 ?/ G' b6 M7 VEthylene-vinyl alcohol copolymer) D @( S3 R( ?
Fullerene-containing polymers
4 [: R8 C; r, KGelatin- Y1 M7 ]0 l/ z, f1 g$ y
Glycogen
& @7 g' j. b, U7 \& q/ sHydridopolysilazane
5 u P% ]7 R8 @9 y9 ZHydroxypropylcellulose
! ~/ Y% N Q" M+ Q4 f' n' k) c) `Kevlar
1 D6 [; e2 I, g( j8 `" GKraton D1100 SBS
# h- O3 \/ `8 H7 k" uKraton G1600 SEBS% h. @. h% q7 b1 y6 Z& J
Metallophthalocyanine polymers
) p) M; X# l& f. J3 S% ]Nylon 3
6 m: O, R! _1 a8 H0 ANylon 4,68 n( `, x( H3 j$ G/ x
Nylon 6
. F/ s$ I8 e3 _/ C- s x3 fNylon 6 copolymer
7 F0 J( v/ ]' R! W x0 ]+ tNylon 6,65 c0 i( ]- Z; {: W1 D+ z3 @# X* E
Nylon 6,6 copolymer- J! x% ~: O( G% g2 I' z- H
Nylon 6,10
8 O, U% n% g, Bfile:///F|/Temp_temp/contents.htm (2 of 10)7/16/2005 7:02:22 PM# a8 \5 \( d; ?% ^. u! Q& T
Nylon 6,12
5 b5 B- e4 G. T( m2 ZNylon 11
" @; ^" J; R/ X( ^Nylon 12
! Y2 L% p" _7 g$ WNylon MXD6
" T( [$ _: v9 P q0 p+ D% z& iPerfluorinated ionomers
9 }) u/ r* H- E; q QPhenolic resins3 K. z+ I( ] N1 ^$ A9 J" E% d
Polyacetylene
& C: w- @# i e$ I7 j0 wPolyacrylamide# H1 O0 T2 {# y, y5 \2 j
Poly(acrylic acid)
; G" m# o X: g: o6 _' vPoly(acrylonitrile)
+ r& J1 Z% g3 k& M; e' @Poly(L-alanine)" j7 W3 G& s7 ^9 N
Poly(amide imide)& ~: c9 Q A0 ~6 f( U: y B$ S
Poly(amidoamine) dendrimers, l& A/ {+ F+ x- H
Polyaniline% h3 ? @6 Y Y. y7 f
Poly(aryloxy)thionylphosphazenes
a% H. [' `. U' V' U" EPoly(p-benzamide)
+ `# T' f$ o" r& lPoly(benzimidazole)0 \1 y7 {2 _" Q! q! l
Poly(benzobisoxazole)
1 S( d+ K# r3 z2 @" aPoly(benzobisthiazole)
0 x* m2 [9 }# G" j) E: j6 C( VPoly(gamma-benzyl-L-glutamate)
1 k3 ]7 c! a, _7 JPoly(1,3-bis-p-carboxyphenoxypropane anhydride)
8 j) y' [/ C# s) n) w/ z; Q等等。。。。。。 |
