发表于 2009-1-4 16:56:03
来自: 中国江西南昌
I don't know the box what you said used for what product. Because the box used for different product, you need to use different method to calculate. I advice you to use software such as pro/e、ug and catia this software all had the function to analysis.
/ R! r7 J# |; V) t1 o: j+ p9 M but has a question, use this software, it is difficult to evalulate the results if it is ok, I think this need your experience. usussaly the result of the intention is not smaller the material of your product. + T1 z9 K) u- @2 T
I usually to analysis by Pro/E, It is enough us to calculate. & A& x# O# ~4 y
Of course, you can use the software of Analys. |
