查看: 1881|回复: 0
[太阳能] 潜热储能系统的传热及热力学优化研究
发表于 2007-3-23 23:21:15 | 显示全部楼层 |阅读模式 来自: 中国辽宁沈阳
潜热储能系统的传热及热力学优化研究  论文4 @  Y- |$ c1 e* P& g% k2 z
来源《新能源》
+ r3 y5 G9 v" d$ N5 n$ a
潜热储能系统的传热及热力学优化研究
Study on Heat Transfer and Thermodynamics Optimization of Latent Thermal Storage System
张正国  余晓福  王世平
摘 要:介绍了相变潜热储能系统的组成、特点及其传热和热力学优化研究.
) r1 x% f& k) G关键词:潜热储能 传热 热力学优化 相变储能1 I0 L; f8 l3 W& H# K2 z$ y3 v
: N& c' _/ S/ G! V1 I
5 d' W  z. E- R  t
3 k' Y: B$ ^. x- o
基金项目:教育部重点基金和广东省自然科学基金资助/ X4 R% l1 [, p5 A6 M
参考文献:! K( k, R+ k7 E1 q$ U. C  B
[1]Dincer I, Dost S, Li Xianguo. A review of phase change materials research for thermal energy storage in heating and cooling application at the University of Dayton from 1982 to 1996. International Journal of Global Energy Issues,1997,9(4~6) :351~364
3 F2 w5 Y' e4 N: a, Y0 \. d6 ]/ Y4 ~[2]Hasnain S M. Review on sustainable thermal energy storage technology. Energy Conversion and Management, 1998,39(11):1127~11383 G! P6 w, {1 o. |; e2 L
[3]Jean P, Michel F, Cecile V. Thermal storage by latent heat, a option for energy conservation in buildings. Energy Sources, 1993, 15(1): 85~93
0 _5 R9 w& E' g; M; d[4]Zhang Yuwen, Faghri A. Heat transfer enhancement in latent heat thermal energy storage system by using an external radial finned tube.Journal of Enhanced Heat Transfer, 1996,3 (2):119~127
6 ^  L8 b; P* m' J9 [; G[5]Kurklu A. Energy Conversion and Management, 1997,38(4) :333~340
( R; D" M. Z% K4 K) [# U; ^. A[6]Gong Zhen xiang, Mujumdar A S. Cyclic heat transfer in a novel storage unit of multiple phase change materials. Applied Thermal Engineering, 1996,16(10) :807~815
3 U. h1 c# n6 j7 T: ?( A[7]Takeuchi H, Pyatenko A.Yamagishi Y, et al.Characteristic of microencapsulated phase change material slurry as energy transportation refrigerant. Thermal Science & Engineering, 1998,6(1): 163~167& B1 U# |: E* B+ r. @7 @
[8]Bedecarrats J P, Strub F, Falcon B, et al.Phase change thermal energy storage using spherical capsules: performance of atest plant.Int J Refrig, 1996,19(3) :187~196+ e' C! B* v1 h1 l+ M# n
[9]Jotshi C K, Hsieh C K, Goswami D Y, et al.Thermal storage in ammonium alum/ammonium nitrate eutectic for solar space heating applications. Journal of Solar Energy Engineering,1998,120: 20~ 24
$ N1 X9 U7 ~; Z- f# _9 B( e[10]Royon L, Guiffant G, Flaud P. Investigation of heat transfer in a polymeric phase change materials for low level heat storage. Energy Conversion and Management, 1997,38(6): 517~5240 z; R( H/ R: r' V+ r2 M
[11]Flaud P, et al. ANVAR Patent 854012929,1987
- ]- y' D  p" a2 v6 p* ]) H/ \[12]Kamimoto M, Abe Y, Sawata S, et al. Latentthermal storage unit form-stable high density polyethylene, part I:performance of the storage unit. J Solar Energy Engineering, 1986, 108:282~2896 A4 x# R+ f5 Y
[13]Inaba H, Yoneda A, Horibe A, et al. Thetransient latent heat storage characteristics of the shaped-stabilized polyethylene by condensed heat.日本机械学会论文集(B篇),1996.63:282~289- j2 i, I& A, l) m2 _  A
[14]Zhang Yuwen, Faghri A. Semi-analytical solution of thermal energy storage system with conjugate laminar forced convection. Iht J Heat Mass Transfer, 1996,39(4): 717~724
/ E* Y5 X# l# G2 U/ d; f3 }[15]赫俏,张仁元.相变储能换热器中传热问题的研究@热力发电,1997(4):15~19
) \* ~; l" i# X  ^/ L  D[16]Bejan A. Advanced Engineering Thermodynamics. New York: John Wiley & Sons, 1988
$ I+ ?5 l) F( j* j: x[17]王剑锋,陆国强.陈光明.组合式相变材料储能系统性能研究.新能源,1997,19(4):7~11
. ]6 S1 U% y. P6 q[18]El-Dessouky H, Ac-Juwayhel F. Effective of a thermal energy storage system using phasechange materials. Energy Convers Mgmt,1997,38(6) :601~617
9 L" j+ q2 u8 @2 O/ {[19]Gong Zhenxiang, Mujumdar A. Enhancement of energy charge-discharge rates in composite slabs of different change materials. Iht J Heat Mass Transfer, 1996,39(4): 725~735
1 R0 |9 q1 M' h; P% @3 W
潜热储能系统的传热及热力学优化研究.pdf
166.09 KB, 下载次数: 7
