楼主 |
发表于 2007-4-20 15:30:16
来自: 中国北京
E8的安装要求
This section includes the following:, p* ^4 T! s0 ^- t1 n
? Hardware Requirements4 C* b/ b6 G) M
? Software Requirements/ u1 P7 u4 d. m5 K! B3 k+ G
& I# M4 i }3 k) E/ `" PThe hardware requirements are described as follows:5 M$ j$ ^; m5 q& m
? Processor Pentium 4 or AMD64 (2.4 GHz (or higher)).
$ L$ A/ \5 `+ N0 F$ U. F? Pentium III and old AMD computers are not supported. For these computers use a special
. c h/ g1 w% v; D3 D& `version; CimatronE 8.0 OC (Old Computer). A message is displayed while installing a
2 [9 ~* G) k+ _& j/ i3 @, y- ustandard version on an old computer: "Your hardware (CPU) doesn’t support this
6 h4 X8 ~. s F0 v) A% pinstallation set of CimatronE. Please use the OC installation set instead. If you do not have% H+ \2 r. X0 p% h) ~! F
it, please contact your local Cimatron Provider."
& y7 Q2 v6 e, N" U& a. q? Memory (RAM): minimum 2 Gb (3 Gb recommended)
3 \! `3 u+ E0 e6 f? Graphic card: must support OpenGL 3D (with a minimum of 64 Mb)
. d6 C2 k) l' S% s# C; k? Free Hard disk space: 2 Gb
. C7 W. e! Q% ]- ?* k? 3 button mouse |
