這個要加在 sha_stamp_functions.lsp 這檔案裡頭
/ N% i' o7 U8 c- ]% x5 u4 c5 h初始目錄位置在安裝OSD程式路徑內,請自行尋找 (我自己的位置完全跟安裝預設位置不一樣,這是可以規劃設定的)& D9 }- O1 K) i5 Z+ d% y! r
% z$ w' |# O: k6 U. ` m) ~1 y
(defun sha-grnd-profile
U* f1 O" W" V# i# ^ (&key
Y8 j, d5 }5 d1 N9 O( s" Q7 a depth. Z8 a6 \+ Y5 W
stamp_dir% I4 x+ ^ j1 \+ X( P/ k* w
thickness
$ c. I0 O- ], Q8 e& x2 `, \ resolution
|6 p+ a9 y* E+ Y &allow-other-keys( L: B9 v, o8 d8 ] t$ ^
)( k7 r$ J3 x. |
(let* (
) t6 P$ X U! e* s3 C6 p8 C (tool-wp (sha-tool-wp))
. z4 T" O8 n( v4 D2 r K! z7 p )
! J- C/ T$ F: y/ I; P (create_workplane :new
5 d" m2 J& a- H :name tool-wp
* ~! u! N' {2 w% {/ a+ c :world_origin9 D+ G6 l" k {1 K3 b
) Q0 g7 Z( s/ U! ]/ }. r$ ?# G( c ;********* create Profile **********' ~& m9 V* Q. Q; i) I: l0 ]. ^6 F( n
(CIRCLE :CEN_DIA 0,0 10)! W' f. N: d$ e& H2 Q5 x
7 d+ s- i7 V) f0 `* c9 T ;******** create Adjustpoints ******( T3 C9 ?) i4 Z
(C_POINT3 M. w% g h( K6 o; A4 ~4 g
0,0: {& p2 t0 S2 L/ x1 h* _
(gpnt2d 0 5)1 X: f# P; L6 X: _
(gpnt2d 0 -5)
& p0 G' w: O: g& `2 O% B6 s (gpnt2d 5 5)
: \8 k( m. H0 X& z X9 ~% v+ ]2 C (gpnt2d 5 0)
# {* I# ?1 r+ a6 |; s; A (gpnt2d 5 -5) n2 |2 P5 `( L' p B
(gpnt2d -5 5), @; ]& w; B2 k" `
(gpnt2d -5 0)' Y: v7 P7 t! n+ k
(gpnt2d -5 -5)
$ }8 K9 P/ g0 C0 g; _, G( _( w( q ). r1 g: y" j$ h/ h
(setq result (sha-profile-of-wp tool-wp))
. A4 D$ N$ v& l' _ (delete_3d (sha-absolute-name tool-wp))
; ~! s J$ X5 } result7 R: A; B! Z* V, j
)/ y/ a/ D. a# M6 V* V
)" W; A& |& Q( N# B+ {
(defun sha-grnd-tool
, K( Z0 D# r+ F' E (&key
. N g7 \# ~! B depth
0 g8 k, s: I m5 x stamp_dir
% g; V% k4 f H$ o j3 b thickness2 d$ j1 }5 B% @& G! p' G
resolution
; I6 A& z3 ?& m9 P4 T0 `5 m7 v6 C &allow-other-keys
; G3 }0 T: Z) W+ D )
- X4 S w3 b! y$ ]4 g( e (let ((result nil)6 Z6 @% r, f. H0 c- |; d* j
(tool-part (sha-tool-part))
3 P! b% l7 i3 I (tool-wp (sha-tool-wp))9 [$ C3 ^, B* B1 S5 k: C2 _3 s
)& K. O; E5 z# L5 \5 j# x. a
(unless (or (< depth resolution))
/ {& ^4 U4 A) {1 N% c- { (if (equal stamp_dir :DOWN) ;create a new wp for direction DOWN
( Y4 F6 W3 V7 ~/ i% i (create_workplane :new- o3 O( U- {/ p7 d; m9 h
:name tool-wp* ^$ l! S( B @
:pt_dir :origin (gpnt3d 0 0 (- thickness))
: m! C. u" n8 l) c9 E V% e' k3 v :normal :neg_z
! q9 h' D. C7 D+ i0 g* R :u_dir :neg_x
z( X- O+ q9 H6 z6 R )* H& ?7 E& \& L4 k0 |
(create_workplane :new ;create a new wp for direction UP
; C/ X/ W2 d3 u, u" j; J- C ^ :name tool-wp
0 t8 {' S' p1 Q- @& N$ y :pt_dir :origin (gpnt3d 0 0 0)
! `7 I9 Z, F$ {. \ :normal :z, {/ J% r/ Y1 C! `7 l7 z; t
:u_dir :x7 H9 j4 Z \3 Q: K. G+ g- R! ?
1 _ M2 K& ^. i. s- ?; p )( P6 q$ b: Q N" A4 Z
;******** create tool part profile******
- n! f3 C6 U1 T2 z (CIRCLE :CEN_DIA 0,0 10)
: d0 u6 }7 N9 R- o1 c, \5 n (extrude
% A5 A" P% W! ?! {8 C {' t, r7 ^1 k :part tool-part0 G8 l0 k) I- N8 }1 o" _
:direction :-W
: w. h. d) S0 x" _8 k: |& R :distance thickness
* F' z/ a8 {( A; `; g )( x2 E4 N! `( W
(delete_2d :all_2d)
( G4 {0 l' [0 m (CIRCLE :CEN_DIA 0,0 9)
* Z' U4 y* Q! P" Q$ m9 ] (CIRCLE :CEN_DIA 0,0 10)
* `; N2 r6 g+ D3 F# @ (LINE :TWO_POINTS (gpnt2d -1.2 -3.9 )(gpnt2d 1.2 -3.9 ))% l% r/ @0 K v' f
(LINE :TWO_POINTS (gpnt2d -1.2 -3.3 )(gpnt2d 1.2 -3.3 ))3 `5 T. p0 x, g* X8 e) @ ^6 M& ?
(ARC :3_POS -1.2,-3.9 -1.2,-3.3 -1.5,-3.6)8 {) J# F4 }$ Y
(ARC :3_POS 1.2,-3.9 1.2,-3.3 1.5,-3.6 )
. n, |& i9 Z: [; C (LINE :TWO_POINTS (gpnt2d -2.2 -2.1 )(gpnt2d 2.2 -2.1 )) h5 T, t* t3 n" ~/ {& J/ O( D
(LINE :TWO_POINTS (gpnt2d -2.2 -1.5 )(gpnt2d 2.2 -1.5 ))
( Y9 C: K2 l3 G+ M (ARC :3_POS -2.2,-2.1 -2.2,-1.5 -2.5,-1.8)
3 Q d6 X7 Z1 m% d8 @ (ARC :3_POS 2.2,-2.1 2.2,-1.5 2.5,-1.8 ) H$ U# [1 B& z" U% Y& I
(LINE :TWO_POINTS (gpnt2d -3.7 -0.3 )(gpnt2d 3.7 -0.3 ))" i0 S6 w3 c" c* n; f! ~5 i
(LINE :TWO_POINTS (gpnt2d -3.7 0.3 )(gpnt2d -0.3 0.3 ))
5 K$ H; k; U7 g, t5 E8 n4 J (LINE :TWO_POINTS (gpnt2d 0.3 0.3 )(gpnt2d 3.7 0.3 ))! D, J( w; u0 ]! }! I
(LINE :TWO_POINTS (gpnt2d -0.3 0.3 )(gpnt2d -0.3 3.5 ))
$ Y6 W1 t6 ~$ `, \4 A) H9 j' M" k (LINE :TWO_POINTS (gpnt2d 0.3 0.3 )(gpnt2d 0.3 3.5 ))
9 l V* m O8 Q2 t8 z3 f (ARC :3_POS -3.7,-0.3 -3.7,0.3 -4.0,0)
: r n, b5 I; h3 ` (ARC :3_POS 3.7,-0.3 3.7,0.3 4.0,0 )
8 S9 t3 m# U2 P6 C/ d) G (ARC :3_POS -0.3,3.5 0.3,3.5 0,3.8 )
5 m, ~ A# _2 }% \ ;******** create tool part ******
: D- T* O( b) ?4 O5 H0 f) H (mill% r3 r' W1 E3 P5 d$ x" y/ A
:distance depth
/ ~6 B0 C* [% P1 r )
4 g" X( n7 ~( P) D; x (setq result (sha-body-of-tool-part tool-part))& B0 R9 ]3 m: ]
- B! q. O& I* R4 v* y& F (delete_3d tool-part)
7 \) y- n3 A9 V4 r. x$ N* t* A% f! I )
# Q& a; e) T! K5 Q- ?, \! T! t' b- f result+ D4 E* s. P9 n3 a/ S4 W- h4 m- t$ E/ \
( e0 H8 U M( C% v2 R3 `)
4 m& F/ R) ~ V3 Z+ q- O0 J6 M2 |. L# v" l3 ^% L! r+ Y
下面這個要放在 demoshop.lsp 檔案裡頭 stamp tools 之後' N7 @$ x4 `9 m( t& G3 g7 L
# b0 C8 v' K7 h2 y0 b+ _
(sha-define-shop-table "stamps"$ F0 U+ M8 f% O9 ?; X6 r t4 h) N
:TABLE-TITLE "Stamp Types"
4 @- y; C- B/ \- [9 Z6 Y+ D' C.
7 a3 Q1 e3 q' L8 |7 n.& S& h% g: D5 N4 t( U2 x5 ?
("grnd" "接地符號" "" ) ;加上這一行
% R! q- `3 q1 k.
* N4 k& _+ B- A4 \7 d3 f) b.
/ M/ Q6 T1 m/ g6 K; T( C:KEY (:TOOL_TYPE)5 V9 C R' J) w. I0 S
:DISPLAY (:DESCRIPTION1 :DESCRIPTION2 :FACTORY ). u+ c7 r7 n3 ]. [
:FLAT-TEXT (:TOOL_TYPE)
7 x6 Q* s; [6 k3 X0 K* t:HELP "sha_stamps"
# d) o* U k8 z0 _:BROWSER-ICON "icon_stamps"
* X4 E( I* p1 e)
5 j( h; E: Q; r$ r! T' u
0 M! q8 b/ N7 J: f: a
: D; O3 C) S4 G( m* }
" H6 b( o; y: \( n/ E
- V" l0 s7 s# N7 e. a0 a之後下面再接底下這些敘述
% O9 Y' Q) w, q0 J. H5 L( `0 q. I/ i9 P$ Q8 p' o H
5 k2 l9 K8 c/ x
5 D( a# W2 @( ?
;;接地符號工具# m' }: q% w: ^& o7 g8 Z9 u
(sha-define-shop-table "grnd"
) T8 @7 s" i; i+ F3 L% Q :TABLE-TITLE "接地符號"
6 r2 E$ O+ s M8 v3 i, D :COLUMNS ' G: k$ |* X9 B- `$ K+ ^
(:DEPTH :STAMP_DIR :MIN_THICK :MAX_THICK :TOOL_ID :DESCR :PREFERENCE :ADVICE)
4 g5 i( S7 ], B1 p :COLUMN-NAMES
6 C% Y( [3 `6 k/ ~8 i ( "請勿更改" "Stamp Dir" "Min Thick" "Max Thick" "Tool Id" "Descr" "Pref" "Advice")
! }' [6 e# P- u+ W; M; j5 n+ Z- T :UNITS
8 d! u8 O5 [" K1 K ( mm nil :mm :mm nil nil nil nil)- j2 L9 f( e0 ~( \5 g
:CONTENTS
( s+ A: _) Q# G5 l" l; s; s (
4 Z" O& ~5 S9 X (0.01 :UP 0.8 1.6 "13404" "6669" :PREF "-" )9 y; X; n0 u1 m1 i
(0.01 :DOWN 0.8 1.6 "13404" "6669" :PREF "-" )3 b& G) E M8 i; R1 Q* a; m
) I/ J& _/ B* N5 I" V, w
:KEY (:DEPTH :STAMP_DIR)- a9 j; s" J. H2 ^2 D, t0 W" Z
:DISPLAY (:DEPTH :STAMP_DIR :PREFERENCE :ADVICE)
j6 @1 w* a( J- I' e# r+ b :FLAT-TEXT (:TOOL_ID)
3 e; o3 l% l T) H6 y* t :HELP "sha_grnd"
. T" a; @6 r6 g1 x# s7 N* c; unique, not displayable column entries2 I6 V3 H) L* G7 E
:PROF_FNC sha-grnd-profile% b8 X7 a4 i* F7 N, p/ O' I3 q
:TOOL_FNC sha-grnd-tool- j- w& H! r8 n
- m5 q# s9 V, j! L# V1 S6 g1 b2 W1 Y- m
3 Q1 Q+ b& e! t. m: q# T
說明
* I M! k' [6 F. q0 t$ U& m5 y9 F7 l
OSD 鈑金需要用COMMON lisp 來寫 stamp tools 才能避免鈑金厚度問題 punch tools 則可不用
1 w6 a0 q" E% V \2 ?5 a3 v2 B+ q6 L0 I0 }( d" y, E
[ 本帖最后由 aris63 于 2007-4-22 12:13 编辑 ] |
