Logopress3 v4.0 SP2.3 for SolidWorks2006(2007) (both x32 & x64 Editions) 1 D% \5 X5 ~2 R e v+ p 5 l+ I0 G- Y4 B8 xLogopress3 v4.0 SP2.3 is officially certified (tested) for SW2006 (up to SP5.0 x32 & x64) and SW2007 (up to SP1.0 x32 & x64)# F ^ d# W2 F
but in fact can be run under SW2007 SP3.1 * N- c, v1 j+ F8 @" E0 {, y' J2 }/ U2 n7 n. K- u& z* o
1 ~% a" J) p; U6 tIt will be archive of 38 parts (67 Mb) + crack for SW2006(2007) x32 Edition 2 v: F9 V7 h) Q% Rcrack for SW2006(2007) x64 Edition will be in a few days!!!1 s+ ]( z1 X3 j: x1 M
2 O5 R( {; Z8 o
1 J6 e! ?: `/ B9 H# OAll work under SolidWorks x32!+ X t8 x( t9 i" Q
If you have a problems try to uncheck and check onece again Logopress3 in SolidWorks add-in...
* Z! |! p$ Z& O+ n
I did not try it with SW2006 SP0.0 (I have tested it with SW2006 SP5.1 and SW2007 SP3.1 installed) but I think it could be used with all SP's of SW2006 x32
