5天前
查看: 4245|回复: 10
[已解决] SW转换CAD工程图乱码
发表于 2007-5-10 12:01:10 | 显示全部楼层 |阅读模式 来自: 中国广东深圳
我从论坛上看了解决SW工程转换CAD工程的乱码的问题,按照上面的修改了,可是还是不行,怎么回事,希望指点
* o7 m/ U! B6 z! K* s; _0 k我用的SW2005,CAD2004,不知道版本有没有影响
, V; I; m' d3 Y! e! d修改的参数如下
* E7 {5 ]+ I" ~' f" A; n*AutoCAD SHX or TTF to SolidWorks or Windows True Type font, mapping file
+ B: t+ R1 F( Q6 B/ K# J, @! M) w*Created: October 18, 2001. C: A  U% ^  _# B& Q2 e5 ?
* file format: 3 columns, space delimited. ]( [1 f/ \* X* W
* first column = AutoCAD *.shx or *.ttf font names, ' A+ O2 B; J, k. y. A+ t- Z$ x& }
* second column = SolidWorks or Windows installed *.ttf font names# }% o* t) f8 o$ j$ Z
* last column = SolidWorks->AutoCAD width adjustment factor2 Y' Y; t! V+ k! V
* All font names in the columns below must not contain file extensions.
1 W! Y) b( \% u& t( J% [, @' m* Font names in the right hand column must be SolidWorks or Windows installed True Type fonts.% j* y  W' H# k. t! s
* You can add fonts and rows to the mapping file.$ w/ L% l% L$ d' {" v% D3 u% q6 G$ U
* For any fonts in mapping file that are not installed, substitute default fonts are used.
) M5 ~7 j, r, p, X0 D* You can add comments to the mapping file. Comment lines must be prefaced with the asterisk (*) symbol.& Q; t/ o4 d2 N5 V
complex  SWComp   0.97
4 m3 Z7 U, l+ i# X; Egdt      SWGDT    0.825
. P; M# c" B, p+ X3 X, U* @* amgdt    SWGDT    0.825% a9 T, h! _1 a; U; }5 ?
* amgdtans SWGDT    0.825- R( ]) X% @- u& @0 f, a! Z
gothice  SWGothe  0.978 L3 H: C: R# Z
gothicg  SWGothg  0.97
0 Z9 I5 w- f1 |5 K7 }7 Kgothici  SWGothi  0.97- a' l2 Q2 |; p$ g
greekc   SWGrekc  0.97
- Q, V% n& f/ A, a% v- Igreeks   SWGreks  0.97
9 g: {1 Q. _# Qisocp    SWIsop1  0.96
, \# B8 M, Q: H5 c' S/ U9 |% kisocp2   SWIsop2  0.96' N& c! G. ^$ m' l1 ~$ ?+ [
isocp3   SWIsop3  0.96- x; V/ {* g/ s/ \& F. L- v
isoct    SWIsot1  0.97
$ E4 ]3 `$ v  U" _isoct2   SWIsot2  0.975 e/ q* n- d; W; g" v: C6 L( W/ O
isoct3   SWIsot3  0.97$ Q' E: C* s9 D# S. T/ s/ q6 |
italic   SWItal   0.85' I1 P3 Z. Y4 e8 r
italicc  SWItalc  1.0
6 M2 }2 M1 E! ?1 r" g3 A* d% Z5 H, yitalict  SWItalt  1.03 {& w% r3 J$ ^, h8 U- P
monotxt  SWMono   0.98
$ w& `4 R/ V# U" X) _# I4 Aromanc   SWRomnc  0.971 V# K4 b, _6 A- l4 J6 X
romand   SWRomnd  0.97
" S" J8 \) t( m1 @# }+ y# Kromans   SWRomns  0.97$ z: j9 D4 @' B. s  [2 }
romant   SWRomnt  0.975 b6 w! X8 g  ~
scriptc  SWScrpc  0.96
! ^: `! n5 n5 F" [8 W% `1 y3 r" B1 _scripts  SWScrps  0.84
! O2 D5 S9 Y4 C- r! ^# F/ j* g) nsimplex  SWSimp   0.97
( e+ L0 o5 X6 |; v7 bsyastro  SWAstro  0.97
# {# ~9 P# D1 u* n  n' Bsymap    SWMap    0.97
! n/ U0 c: ]8 W5 Q4 o7 Q3 s' z$ zsymath   SWMath   0.95
1 P3 U: \! f/ y- M& I; B# Xsymeteo  SWMeteo  0.95
  x, M+ z# u$ _, _8 X4 `+ j: }symusic  SWMusic  0.94% T/ e: e+ U- ]# z  M: ?% D1 I
txt      SWTxt    0.962 g2 o2 U' x2 V6 d; `/ R+ V
Simplex Simplex 0.97
7 p  d' R) f1 O  [+ l. |9 J  i0 `0 GArial Arial 0.97" u' }7 w: S, Z# z4 m# v, t. n/ c
SansSerif SansSerif 0.97! E" z' l: q; p+ ?. V& G4 a
Swis721 Swis721 0.97/ m) |- Q) E9 O& g6 p3 D
宋体 宋体 0.97: c& I3 ?8 ?* u( ~/ Z- y, H  |* j1 T
新宋体 新宋体 0.97
' n# A- H4 \5 k& S, }% T! t仿宋_GB2312 仿宋_GB2312 0.97
6 L) d* g& }  \; p8 n楷体_GB2312 楷体_GB2312 0.972 P  N8 c+ a$ o8 h
隶书 隶书 0.97
发表于 2007-5-10 13:23:09 | 显示全部楼层 来自: 中国江苏南京
我也使用SW05转CAD2004,只是文字会乱码,从新改一下就好了% b( ?, W  e$ P% U/ Z
但不知道怎么才能消除乱码
发表于 2007-5-10 13:25:02 | 显示全部楼层 来自: 中国北京
修改字体,或者把sw工程图的字体复制到cad的字体里面,或者把sw工程图的字体修改为宋体
发表于 2007-5-10 15:29:33 | 显示全部楼层 来自: 中国北京
转过来的图纸不大好用,比较乱
 楼主| 发表于 2007-5-10 17:02:38 | 显示全部楼层 来自: 中国广东深圳
SW里面字体只有drawfontmap.txt,而CAD字体fonts里面可是有好多字体的
% w: w2 _3 f" O% t  Y! D如何复制可否指点一下8 s! A" }& z+ z; t) `0 w' I
不知道有没有人用修改drawfontmap.txt里面字体的方法成功的,是不是我操作有问题?
发表于 2007-5-10 20:24:21 | 显示全部楼层 来自: 中国辽宁丹东
我刚刚用修改drawfontmap.txt文件的办法没有成功(sw2007,acad2006)。不过以前的确成功过(sw2007,acad2002)。
" B  T) p: J0 j在转换设置中用trultype字体,虽可以显示汉字,但字号变大、字体变粗、超出标题栏表格,且直径符号显示成了方框。
$ K6 d/ `; n; H那位高手能解?请多多指教。
8 |! `! ^) |* v
5 O- q. k  |6 {, V. k1 ^[ 本帖最后由 wuzhijian 于 2007-5-10 20:26 编辑 ]
发表于 2007-5-10 20:48:35 | 显示全部楼层 来自: 中国四川成都
我在sw中支持选好图幅大小和投影视图的比例和方向,然后保存为dwg格式,然后在autocad中添加标注和注释,这样不存在乱码的问题
发表于 2007-5-11 09:31:02 | 显示全部楼层 来自: 中国广东中山
回复 #1 brave7122 的帖子
http://www.3dportal.cn/discuz/vi ... &extra=page%3D1# i' x" d  U; ~. [+ W
我自己亲手试过的都可以的.
发表于 2007-5-11 14:03:17 | 显示全部楼层 来自: 中国广东惠州
发表于 2011-9-17 11:15:18 | 显示全部楼层 来自: 中国江苏徐州
我刚刚用修改drawfontmap.txt文件的办法没有成功(sw2007,acad2006)。不过以前的确成功过(sw2007,acad2002)。; U2 \7 S9 I9 z9 [" L6 O& V
在转换设置中用trultype字体,虽可以显示汉字,但字号变大、字体变粗、超出标题栏表格,且直径符号显 ..., p1 Z, u# V( Z( n8 p, U8 ~
wuzhijian 发表于 2007-5-10 20:24 http://www.3dportal.cn/discuz/images/common/back.gif
遇到同样问题,忙了一个晚上没有解决,不知道是不是版本问题。
发表于 2011-9-18 19:19:21 | 显示全部楼层 来自: 中国广东佛山
下载一个钢构CAD,里面有一个乱码工具。
