查看: 2572|回复: 2
[求助] 怎样修改MPFAN.PST有余量?
发表于 2007-5-14 10:21:20 | 显示全部楼层 |阅读模式 来自: 中国湖北荆州
发表于 2007-5-14 13:39:10 | 显示全部楼层 来自: 中国江苏常州
关注中,我也想知道
发表于 2007-5-14 20:47:38 | 显示全部楼层 来自: 中国湖北武汉
也被这个问题难住过,现在解决了,仅9版本% L0 ?/ z& a9 N# E) d, k0 B
% G; m- G0 ]' R: X! F7 W/ I" O4 N加入这些可以做到加工余量信息
; W& s! E, r& J" u: z$ H# --------------------------------------------------------------------------; I1 d9 l/ X1 f
# Common User-defined Variable Initializations (not switches!)
7 C; G4 Y! K3 n4 R/ G$ z9 f5 l# --------------------------------------------------------------------------# I: I9 h+ O7 V. x7 j% G5 t
) J& u6 y; [0 M$ h- k% M#XYZ stock variables
, N0 E* ~- Q( B8 oxy_stock  : 0      #Declare a unmeric variable to hold
7 O) q; d9 ]3 X; y/ F                   #the "XY stock to leave" setting
! G6 X1 v, z2 g2 }3 I2 s3 x) J7 t: Zz_stock   : 0      #Declare a unmeric variable to hold
9 v( p0 J* v/ x$ G# C6 J; I6 s                   #the "Z stock to leave" setting  ?9 }' W8 p( L, ~- t: }
; G0 b$ o& X! N) X  _( f
: u& S) N4 o7 e# e+ n8 z$ [0 y8 b  @  v+ P# w' B
/ ^6 X3 I; N) i4 C) U; w7 ~! w5 L; o  ^( D4 {
* `9 z$ x4 ^$ j* f( q8 s. Z7 x% V  ^, [
fmt  "TOOL = "      4 tnote       # Note format* H8 `2 V/ P5 Z; t9 i
fmt  "DIA. OFF. - " 4 toffnote    # Note format2 }- G# }$ e2 }
fmt  "LENGTH - "    4 tlngnote    # Note format2 a; u2 h9 g" R8 C, e( \
fmt  "DIA. = "      2 tldia      # Note format
' R3 m; k8 A& z" ~, rfmt " RAD. = "      2  tcr       # Note format
' r& n1 \3 b& X& ?/ s5 cfmt "XY= "          2  xy_stock   # Assign an output format / o& U$ o3 z' q  w% ^! D' D
fmt "Z = "          2  z_stock    # Assign an output format$ M' O' R  `, t1 E
0 @2 T  z' I: q; K% i6 S, `
- K1 e1 ~7 M# ?+ H( }
3 x, G3 ~2 q" `
! _1 O! F% Z; O1 Q; ~9 N9 L$ J" U6 @7 m5 X
"(STOCK:",*xy_stock," ",*z_stock,")"& m" h8 B- m. y. D3 T) H# v& x
* b! L, `* n9 S* G5 |- l
7 W/ |' y. x6 x" @9 ]# XYZ Stock setting( H$ f' y& A0 q7 j0 j4 g
- n6 J! ^( F5 T5 Z. \. i, upparameter     #Information from parameter
6 }5 g& k# c# J2 y# B3 g) O9 D, L2 S6 _6 ]+ p6 j0 \0 L/ ]* O7 `0 F
#Capture parameter values
: C  ~! d. L7 I) ^$ j    if prmcode  =10010,  xy_stock = rpar(sparameter, 1)
1 {( Q8 J1 G: x* W. ]    if prmcode  =10068,  z_stock = rpar(sparameter, 1)
. @9 n5 Y- s& x/ M
2 f# X5 w1 T; u7 @3 X9 s1 V$ P6 M2 F8 F' G7 S- |) m# i9 W
5 O2 z  ]' p7 z2 z2 M
! u4 q& r2 X. ?$ g
+ E! w  B' _" N! F这里如下设置
7 W9 Q# R6 v6 K1501. Insert parameter information in the ascii NCI? y
1 h& h* _/ `6 p. H3 ~5 J4 t" Q0 |1502. Write operation information to binary file (.ops)? y( F3 M. r. V7 e
1503. Write transform operations (0=transform ops, 1=source ops, 2=both)? 1
, I0 {  ]- B; E4 }
0 G; Y8 D6 Q0 C0 W4 s  H% i, B: H, F0 h+ C# G* }$ x
这样的值才不为零
qiushaojun + 5 应助
