This online reference guide documents the SolidWorks Application Programming Interface (API), which you can use to automate and customize SolidWorks. The API contains hundreds of functions that you can call from Visual Basic, VBA (Excel, Access, and so on), C, C++, or SolidWorks macro files. These functions provide direct access to SolidWorks functionality such as creating a line, inserting an existing part into a part document, or verifying the parameters of a surface.
9 ~/ A" s0 N8 y- }2 s% SEvery object available in the SolidWorks API, including its associated properties and methods, is documented; undocumented SolidWorks API functions are not supported and should not be used. Use of the API assumes that you are familiar with Visual Basic or C/C++, or both, programming languages. ! D' w. b; H$ `9 W
Click any of the following items to learn more about this online reference guide and the SolidWorks API.
6 T! e( U$ V5 e" @+ y) _Access and Navigation. Provides various ways to access SolidWorks API Help as well as tips on how to locate information in SolidWorks API Help.! X5 A7 z4 \6 b3 H1 H
Syntax Conventions. Explains and illustrates the syntax conventions used in SolidWorks API Help.5 o9 r; Q# k2 l
Obsoleted APIs. Explains obsoleted APIs.% O( _" p6 T( T4 M3 _( W
Resources. Provides a list of additional resources that might further assist you in using and understanding SolidWorks API and SolidWorks.- SolidWorks API Release Notes. Provides an overview of this release. A must read for users already familiar with the SolidWorks API and SolidWorks!
3 [( \; ^5 B; Z# M& h |
