发表于 2007-6-25 14:53:43
来自: 中国上海
我在这里补充一下二楼的.
) k8 D5 [ \ R6 w& h, ^3 u$ R润滑油牌号对照表
}! ^# J% Z% |润滑油 40℃温度下ISO-VG粘度mm2/s.标准DIN 51519 润滑油选用实例8 N; L8 ]9 w; G0 _
- _3 |4 W. A8 S$ Q1 k
& O1 _. J2 l; \7 G" y8 }& w合成油1) VG1000 Degol
5 `+ I! s& R5 J/ f9 g: l8 v6 bGS1000 4 r; Y2 e, Q( [& r& i8 J3 ^
' S0 T+ v. w5 v0 G1 A
TRIBOL S/ Z3 `; `+ A( D' J' O* h
800/1000 Optiflex3 V7 n; C6 ?" ~( B5 y0 n
A 1000 W- T% k- d0 N* V, I) s
VG680 Degol
" f8 z) r9 W$ ~GS680 Polydea
8 ~0 k/ x# n2 B: ]" a2 k* |! _PGLP b* x: K9 H5 c$ n
680 Glygoyle
; B" d( I5 Z( k0 [4 s4 Z5 a9 pHE 680 TRIBOL
$ y/ l9 c, O; t$ p* O" s2 V800/680 Optiflex$ O5 B7 q) F7 m
A 680( j4 S9 A X& W4 `, l& R G
VG460 Degol9 L! Q4 N9 J J; N* F" T
GS460 Enersyn
2 @& A+ @: p" `$ a4 ~! \% e# ~' y2 mSG-XP
% F) e1 @) y, s) H8 O460 Polydea7 B6 o! E9 A( Q- B
PGLP
' C6 v; ?+ f* S* `; ~ [4 _460 Glygoyle5 m- j7 ]7 R! |( i! v/ @
HE 460 TRIBOL
7 f2 A' ?6 J/ d N3 R( }800/460 Optiflex
7 \) O; S' A/ U3 j. b$ k5 yA 460- p# `! V/ H+ d+ G
VG320 Degol; Y( Z* k) f3 o
GS320
" Q. a$ a5 I# T) n# ~1 k! S% E$ L% j
Glygoyle
: G0 j; m- e8 W- ^; j/ tHE 320 TRIBOL' _/ k- E: ?8 E
800/320 Optiflex( _1 c; r. m4 _: M
A 320
' D: @( A ]9 Y% j2 I3 P VG220 Degol
: B+ c- l' I/ @, A2 y2 OGS220 Enersyn
6 d6 v' [/ `3 VSG-XP
, ? b% A" }4 r9 v220 Polydea2 P s2 g7 k# `* K* {
PGLP9 |7 d ^1 R+ R |
220 Glygoyle! ^& i; g6 N. \( \! B) D2 \) @
30 TRIBOL
7 C# M* X2 i% m" p800/220 Optiflex
$ {" j) r1 J. H) G1 uA 220+ W' K2 G* s4 U/ x/ u0 ^6 y+ {
VG150 Degol
# l# V" s5 F8 z7 T. `GS150 Polydea
( K5 ?! ^: t4 B5 g. O. T6 UPGLP
* ?/ P$ `9 k+ [- ]1 l* z& T8 H150 Glygoyle
, a. B" F* `- E22 TRIBOL
$ L, W8 k/ Q# C) l3 V# D3 v800/150 Optiflex( U5 S4 `7 R5 @6 f$ ]
A 150; m _, o) w$ X- R- o1 E7 Y
VG100
0 a& V8 L. T# _/ w) w
$ N+ Y% L* {) ^) R' v- G# u" @ TRIBOL! X; L: }3 {: R/ l+ X
800/100
2 V3 g4 P; C$ E. z: I4 y矿物油2) VG1000
* N4 H. U+ V! ^7 d
' c8 Y3 g( {6 W# K TRIBOL
& P" N# j# V* o1 i& n& Q! T1100/1000 Optigear
( ?* L5 U# {! J1 K# vBM 1000- r' r q M/ r$ B
VG680 Degol2 D% q! U: M2 V2 E6 j
BG680 Enersyn# c/ ?3 ]4 I6 r% K' ]
GR-XF7 g1 k; J4 V* P# c/ W8 M8 Y' ?
680 SPARTAN- L e6 {0 L5 i ?7 |5 T# z" ~5 R
EP 680 Mobilgear
, r% ?9 l* ?9 n: T7 I636 TRIBOL
$ z7 @5 e+ U; I/ ^& t5 Z1100/680 Optigear
( r1 i& F7 ~) V1 MBM 680! S! M7 P$ H+ _5 ~5 N4 P: v
VG460 Degol
; W0 I: [2 K8 y% ~8 p9 I' B% FBG460 Enersyn
. Q' ^! X" S& [3 N: QGR-XF* S( y. d: d( e8 E/ h. Z
460 SPARTAN
4 ~; z& B" s7 |( L5 B3 n- AEP 460 Mobilgear
- {6 J6 P! @1 c- u634 TRIBOL# P- X4 i, Y* p2 @! u+ U) x! Q
1100/460 Optigear6 u5 b! n* E% k
BM 460, p' T, A# b6 f
VG320 Degol r$ K! O8 ?6 D$ Y" i8 J; i3 S
BG320 Enersyn& X$ x6 P4 \/ o5 N! w0 T( b; o" |
GR-XF
; L$ \1 V5 I4 P2 M# X2 }* Q320 SPARTAN
, ?8 O6 ?4 s" g+ EEP 320 Mobilgear/ `! j$ N) d; S, P
632 TRIBOL. }! {( P5 u) S
1100/320 Optigear
5 i! L. J/ D( y& p, E! }1 ?# ~BM 3206 @% R/ v; G9 {$ z7 Q3 `
VG220 Degol8 X9 U% U2 Y( i- O& n# G! W
BG220 Enersyn
7 y6 }# f: N! \GR-XF' P C* M. v" d5 [, _+ |( R7 A
220 SPARTAN
4 P, U4 S- R1 _EP 220 Mobilgear: N8 \* S+ j1 {1 G3 F* x ^
630 TRIBOL) b; n: K4 h) j) k- y
1100/220 Optigear
1 U* w' ? i# m7 x, vBM 220
7 _, V- U; R$ W& t/ g VG150 Degol2 Q5 Q8 D; r* K# M
BG150 Enersyn, w6 I+ u7 @: J; O! ]
GR-XF6 k& r/ f* k; v
150 SPARTAN
% P+ F4 Y9 s# f# @EP 150 Mobilgear
# l( W v8 F. `8 J, M* E629 TRIBOL
/ P# N H; F) @+ z% {% \; ]1100/150 Optigear
* j6 ?; p* T6 nBM 150
4 a* B4 a {5 p f# z VG100 Degol2 ?4 I0 b# }1 [$ a) B! m) k
BG100 Enersyn
2 [7 Y8 K( p9 M3 x' LGR-XF
3 i5 C; a: {2 Z" t+ y100 SPARTAN
( e$ P; c4 T( L8 C( X" ^! YEP 100 Mobilgear% j. E! s$ v. t
627 TRIBOL
! s+ [. \% P) V8 m$ b1100/100 Optigear" d9 Z& L* z. i5 n
BM 100
; i8 T0 L s" U8 y" f' i+ a齿轮润滑脂 Aralub
/ _2 _' t8 m0 y5 _5 C- a4 uFD 00
3 ]2 @$ e1 l& h4 eFDP 00 Energrease( u3 r4 ^- s) {& o
HTO7 F) b* ~* ^0 s8 z' M! o+ j* R! r
HT 00 EP Orona 00
, k7 n2 X5 D: ~8 gOrona
. Z L( P% ]; O, T1 f, Y0 b8 ^" jFG EP 0 FIBRAX
- U' ~" o }7 k" y9 CEP 370 MICROLUBE2 {. h& z; M' h `+ T) R8 ]) o) M
GB 00 Mobilplex
* |! T1 [( r+ O: Q% j( i3 y& E44 特殊齿轮润滑脂
% B) s- G2 y* F) TH 多功能润滑脂
' i3 K. I: w* f5 U4 @4 e9 Q) cTRIBOL8 S; ~, ^: ]6 y- F( a9 |8 C/ j0 B
5000 Wiolub0 Y; P% ]0 W3 X( C% D1 G6 k
GFW Longtime
. h* {4 U' g# D! t6 p3 [PD 005 x9 V: R0 @- m; W* i5 S& O; \! Y
锂基皂化减磨轴承润滑脂 Aralub' Y( q. E) o' D# ~8 U) ]2 h" s/ _
HL27 Energrease, y6 _' i9 L( l: c7 `
LS3 Glissando20
' M1 A+ N$ a5 E, YGlissando30 BEACON3 CENTOPLEX3 k! J y$ ^6 Q1 o
GLP 402 Mobilux2 Mobilux3 润滑脂R37 a. C) L% |6 |! N# ^
Awania
6 i9 ^# c5 x2 Z/ jFett G3 MOLUB-
) `8 P& Z' F2 b$ O* V* T% @1 bALLOY
* b* h1 W" F# {) m* k: I* l/ \BRB 572 Wiolub% M9 x$ a' _6 f# E; [
LFK 2 Longtime% i. E8 c2 h9 C' Z: }" ]
PD 23 a) d I$ L; K- `4 c* Q9 F
1)合成齿轮油(聚乙二醇)根据DIN51502标准定名为PG。这类润滑油具有良好的抗老化性能,可有效地提高齿轮箱的机械效率。工作温度适用范围为-20℃止+90℃(瞬时可达110℃)。* ~; I( }5 _. c- k, |
2)矿物基齿轮油根据DIN51502标准定名为CLP。这类润滑油可达到DIN51517第3部分规定地最低要求。工作温度适用范围为-10℃至+90℃(瞬时可达100℃)。 |
