查看: 1205|回复: 2
[已解决] 下载时遇到的问题
发表于 2007-5-29 19:54:01 | 显示全部楼层 |阅读模式 来自: 中国江西南昌
我在下载:Machinery's Handbook, 27th Edition
- F% r( Y. Z: Y
" L8 N7 x4 H* [/ w: ehttp://www.3dportal.cn/discuz/viewthread.php?tid=228350&extra=page%3D8
  z8 l$ F6 @* P: g
; }9 a" S& h4 X+ ?' W时遇到如下问题,请问何解??!- `9 {$ Y/ i8 `$ T0 w
7 j/ u1 q5 ~" w' e& j
* r5 `  O2 e. N- A6 H
8 ^! g3 K8 z' B) hDiscuz! info: MySQL Query Error4 [7 K6 ^  l% L5 M/ n
# p7 `! T- N+ x1 s7 G! _1 u9 ]
User: zoujia416
" l: Y1 D2 r& f+ y5 ?* wTime: 2007-5-29 7:51pm$ [. x- H0 U- M/ ~6 L
Script: /discuz/attachment.php
0 ^, L6 E0 J" W2 c4 e. M0 d1 Z: o  \1 J$ k. y
SQL: INSERT INTO [Table]downloadlist (uid,dateline,fid,tid,pid,aid,subject,username) Values ('198283','1180439474','85','228350','1044841','346251','Machinery's Handbook, 27th Edition','zoujia416')
7 Q2 l9 S5 j  _. kError: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's Handbook, 27th Edition','zoujia416')' at line 12 D5 |# X* ?4 Y2 r" r
Errno.: 10646 c' K! I; s8 ]- _% W
1 d* [: z# B; k3 ?Similar error report has beed dispatched to administrator before.
发表于 2007-5-29 21:23:07 | 显示全部楼层 来自: 中国浙江杭州
试了,确实有此问题,只有请系统管理员来解决了。
1 n3 d) J# ^" Q
: a, [3 [  {5 c- N; {! qDiscuz! info: MySQL Query Error
( F' a  O" n4 h9 X
+ W; r! R) r( L" ~* S4 L$ X' XUser: wwqq
% F; S6 S2 @! O7 h$ [% I, H7 nTime: 2007-5-29 9:21pm( o) O' }, M; O8 |
Script: /discuz/attachment.php. n$ j9 ~9 s, W  p( g' Q1 a$ p6 ~
9 @1 u# u( v/ z2 r2 U% z, gSQL: INSERT INTO [Table]downloadlist (uid,dateline,fid,tid,pid,aid,subject,username) Values ('74613','1180444913','85','228350','1044841','346252','Machinery's Handbook, 27th Edition','wwqq')( H  M- K* z& o( ]( b6 s2 Z
Error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's Handbook, 27th Edition','wwqq')' at line 1' v6 T$ G" i+ e+ L: h# l( D; l
Errno.: 1064
4 O0 N+ P- S+ g" K) F6 X/ N: i9 w" ^* \8 W4 K( P2 J& t6 m& w
发表于 2007-5-31 06:49:54 | 显示全部楼层 来自: 中国上海
已删除,让其重发。
