高分子材料的测试2 O0 x9 `8 K$ b+ {3 O
+ R5 m7 I2 M/ X$ E# i8 M
Testing Items Test Requirement( H( @" V. ?6 n! j
邵氏A型硬度 Shore Type A Hardness
9 {9 q2 a# f; p5 L ASTM D2240-05 1 v8 i: B. c6 z# r+ A
ISO 7619-976 e5 Y/ P8 u) o
GB/T 2411-1980(1989)
0 l0 {: a: a1 i4 g) V( |& a邵氏D型硬度 Shore Type D Hardness' W- ?+ r" z/ a: }- L4 s
ASTM D2240-05 s, U3 q$ X% K1 C) k& H7 j
ISO 7619-97
/ |) c* T9 d! i D3 n* \ GB/T 2411-1980(1989)
0 V/ {4 t8 r0 Q# J7 s洛氏硬度 Rockwell Hardness4 ~5 v) Y) t- D1 n+ f( E- M7 y; x0 b
ASTM D785-03
! D; z: Z6 h: @. I1 ? ISO 2039-2:1987: {7 F, S* Q0 W' x& y! K
GB/T 9342-88
- _ F4 E9 V3 H' ~2 x0 R/ U拉伸强度(模塑料,原料) Tensile Strength (Mould Plastic& Materials)4 K0 @, t8 @% ~3 I5 U
ASTM D638-03
4 f Q9 S0 Y6 o. H2 Y# a- p5 i3 d ISO 527-2:1993
) ]$ X6 @+ s G4 s6 k5 M7 C GB/T 1040-92
4 O' _ t$ K- \- P j; y
9 V. J8 U% D1 A0 Z6 d' W ASTM D412-1998a(2002)e1 (橡胶)4 D: B+ v1 K: ?0 ^' X* [/ v
ISO 37-2005(橡胶)0 l) P) M+ p4 H! s
GB/T 528-1998(橡胶)
, {( ~$ Z& X: e m 2 @3 m; H0 D) p; N7 n# V* q/ h
拉伸强度(膜材与片材) Tensile Strength(Plastic Sheet & Film)6 d9 E4 O5 M( M: ^+ _* J
ASTM D882-02 (单方向)
+ V" Q7 ?9 ]8 q' K' y9 x a3 c$ { ISO 527-3:1995 (单方向)3 g4 C* l' C3 i4 Y# m5 @
GB/T 13022-1991 (单方向)9 @2 K6 [0 p1 P& Q A( N4 s
ASTM D882-02 (MD/CD), j/ W" p0 R( [' d9 A7 D7 B) K
ISO 527-3:1995 (MD/CD)
& z) a5 j5 |: v* B( `" z' n GB/T 13022-1991 (MD/CD)* a# H! F9 J" L' Z3 w
拉伸强度(编织袋) Tensile Strength(Braided tapes )
/ \0 y. P4 d- _% X9 ?* v0 i ISO 10371-1993(单方向)
" I3 i8 y+ ?1 S0 ~' `5 p+ u GB/T 8946-1998(单方向)0 |6 o L; V; W% w# p" a
GB/T 10454-2000(单方向)& x: q2 N- Y; ~" ?$ I( v
ISO 10371-1993(MD/CD)+ H; [# y! m) h( y
GB/T 8946-1998(MD/CD)7 S, g+ j! H; v. P! m3 s
GB/T 10454-2000(MD/CD)8 h+ q% \# U4 f. [
断裂伸长率(模塑料、原料) Elongation at break(Mould Plastic& Materials)
5 @/ {) J! `% l! E; ` ASTM D638-03
- i5 L; ]: m$ Q3 U ISO 527-2:1993
* }8 d- e. ~+ q1 A( V4 }3 h1 [ GB/T 1040-92
; y7 g$ q2 B; _4 R& d( [9 r# R+ c2 ~
- ~9 i: c: E+ e$ X5 I: m ASTM D412-1998a(2002)e1 (橡胶)
6 y" b. k$ u/ L) I u ISO 37-2005(橡胶)7 W9 D3 \( s2 @+ ^* a( v6 u
GB/T 528-1998(橡胶)9 M' Y: I6 w1 J
: v- a6 q; U+ ^# B! R
断裂伸长率(膜材与片材) Elongation at break(Plastic Sheet & Film)2 U& ~+ R1 |# T, ^$ B$ I* ?/ \, S
ASTM D882-02 (单方向)
. l; D# z4 p6 }6 ^ ISO 527-3:1995 (单方向)7 i3 _4 E$ y) `7 B$ l
GB/T 13022-1991 (单方向)3 T6 C& S2 [) ]* C6 _
ASTM D882-02 (MD/CD)# s0 M" M; w2 H" }3 n" Q4 G
1 Y5 H' j! [7 \3 P2 l GB/T 13022-1991 (MD/CD)
7 g# _( ]& x2 E0 Z$ A/ D拉伸模量(模塑料、原料) Tensile Modulus(Mould Plastic& Materials)8 \# ?& X" k I% U5 u9 f
ASTM D638-03/ T. X7 ^$ D& H! U# b1 ~2 [7 e
ISO 527-2:19932 ~2 L2 _/ v( q, Y4 j8 q7 i- Q
GB/T 1040-925 H! C8 u% z3 F
拉伸模量(膜材与片材) Elongation at break(Plastic Sheet & Film)% ?7 f( m7 x0 O- A
ASTM D882-02 (单方向)/ ? }# I1 M. Z# ?. d& o- m: P# G+ x
ISO 527-3:1995 (单方向)2 U0 e* u* H3 r
7 T. z7 i8 z7 Q4 E- M ASTM D882-02 (MD/CD)
2 }4 v3 z1 U9 @9 g& L) D! P& c ISO 527-3:1995 (MD/CD)
' `. U0 A1 c6 B3 t8 V GB/T 13022-1991 (MD/CD)- y2 E: V5 F. _
弯曲强度 Flexural Strength
+ h+ _3 c) W. a1 P ASTM D790-03* n: H. [8 {. O3 e" L% E
ISO 178:2001
/ y z" e- S7 U, e3 Z GB/T 9341-20006 O" v( Q5 X! s/ G( E
弯曲模量 Flexural modulus
8 z0 y j- ^5 n) i" I s+ M5 d) ~ ASTM D790-036 g" Z: m! n* U8 X3 w
ISO 178:2001# ~$ B' j- D0 m2 o8 q( X
GB/T 9341-20008 [5 p" |: M+ h2 Y' e. ?
悬臂梁冲击强度 IZOD Impact Strength6 U* n, A& T- J4 p* r
ASTM D256-05(有缺口)
: T# F2 P' E! w x ASTM D4812-1999(无缺口)
) e4 m& F, a" Y( P ISO 180:2000' i0 O7 S7 n) W
GB/T 1843-960 x/ Z. s. E3 X8 x" X7 S: s
简支梁冲击强度 CHARPY Impact Strength
3 W/ B/ O8 L5 _ ASTM D6110-04
3 F$ w$ U9 w8 Q4 H- P1 T! f$ J ISO 179-2:1997
; I, g% G8 ~# I; f4 |# v" ? GB/T 1043-93. i& b$ S' B& D! L4 A
撕裂强度(膜材与片材) Tearing strength(Plastic Sheet & Film)
2 @* y* A) o$ m2 \ ASTM D1004-03 (单方向)
0 ?6 `- `1 C" A7 a ASTM D1938-02 (单方向)
9 g6 q3 y. b8 ]% e$ c1 [ ISO 6383-1:1983 (单方向)$ T3 j; |+ g, u! q0 g4 q8 i
GB/T 16578-96 (单方向)' Q) O( a+ c+ O$ F: M+ N
ASTM D1004-03 (MD/CD)
5 P$ A" v6 z" K7 \: Y ASTM D1938-02 (MD/CD)+ W) J2 u' s8 L+ H( {1 h/ ^
ISO 6383-1:1983 (MD/CD)
" M) T }) w1 A- |; N- } GB/T 16578-96 (MD/CD)
4 H% |# H' X) [) R
7 o5 s2 ~" F0 \7 m/ n ASTM D624-00e1(橡胶)
7 [! O7 Q/ G4 ]+ O ISO 34-1:1994(橡胶)! F# ^, I* \# Z C
GB/T 529-1999(橡胶)
8 P; t& j+ l: \
' c& t& X4 N& D5 B1 d剥离强度 Peeling strength$ O6 L8 E% p) r- l+ S: Z
ASTM D5458-95(2001)(复合膜)
! U9 j, o+ h% b1 g( z$ Q4 T' V4 T& S! ?穿刺强度 Puncture Strength0 u* w# k5 i; u9 ]% R! a2 |$ E
ASTM D4833-00e1
% z! j4 |5 Q5 d# [+ L! D压缩强度 Compression Strength
. v1 P. l% K7 B6 J, } ASTM D695-02a% X6 X' Q! w9 x) T) N: w! {9 m
ISO 604-02' m0 g6 Y1 M& `3 g
GB/T 1041-92
" z) Z; y* n/ R- z( C2 ]压缩模量 Compression Modulus
5 `5 W/ h: Y1 X: F7 \ ASTM D695-02a3 Q; `4 t, @1 k: d9 t( s9 F
ISO 604-02- R( |8 V' f3 [: @4 G
GB/T 1041-922 U9 Y; S2 c) ?! j0 w9 x
压缩变形 Compression Set' `# X. H. T# F
ASTM D395-03(弹性体)
7 t7 b- Z$ O* A1 f ASTM D395-03(橡胶)
) P6 l5 A. e, \/ G. M GB/T 7759-1996(橡胶)* S6 B5 `6 C8 K7 W
ISO 815(橡胶)! j+ M3 D6 H+ N4 B0 K
( _" G$ W K, S
薄膜摆锤冲击强度 Tear Resistance of Film & Sheet by Pendulum Method 2 \9 H2 q2 w9 q
ASTM D1922-03 (单方向)4 J" N/ H4 R7 J% H/ H3 T
ASTM D1922-03 (MD/CD)
- R* ]5 |- ]- w6 p落锤冲击强度 Falling Weight Impact Strength
; ]1 U- ^/ F' D& v# | ASTM D5628-96(2001)/ F: h) F/ }4 x( Q' W
ASTM D4226-2000(PVC建材)* R6 `' K/ n |
ASTM D5420-04(Gardner Impact)& {/ v4 V& L/ d4 S, f" ^
GB/T 11548-89(板材)
7 j7 r' t3 \8 M0 o$ W GB/T 14153-93(硬质塑料): G3 M( [- w. K; _' H- m
薄膜落镖冲击强度 Impact Resistance of Plastic Film by the Free-Falling Dart
' l8 @. y; C( N ~0 q ASTM D1709-03) ]; M: O" j5 D# \
GB/T 9639-1988& ~4 L+ a2 b) _/ B
塑胶及弹性体脆化温度 Brittleness Temperature of Plastics and Elastomers by Impact O7 S* |* e' t# T
ASTM D746-04(需指定温度)# n. l' S! ]2 y6 Y7 a
薄膜脆化温度 Brittleness Temperature of Plastic Sheeting by Impact
6 M: e! E$ E; r* L; h ASTM D1790-02(薄膜)需指定温度点/ F! I. D+ s8 D' U% M
GB/T 11999-1989需指定温度点
7 U: V# T: a' `3 j* G ASTM D1790-02(薄膜)未指定温度点
; a. N2 |4 M( v8 ` GB/T 11999-1989 未指定温度点7 f3 @# x1 }3 R0 L" i. E
薄膜与片材动静态磨擦系数 Static and kinetic Coefficient of Friction of Film and Sheet
* q6 e7 F5 |! ?) G: V ASTM D1894-01
$ }4 R6 m0 X0 U% P7 s1 i' [* ~! J ISO 8295-95
6 ~; s* Z+ D& _, S GB 10006-88
6 @8 X, G' E! G' L6 n* d0 N模具收缩率 Mould Shrinkage
; o+ C! ^+ ^; q ASTM D955-005 k, s# D7 U" |6 t/ x3 T4 m
磨耗性能(Taber) Taber Abrasion Resistance(需指定转数,磨轮,重量), T9 h- ]/ i5 O. n; @ r
ASTM D1044-99
8 J2 T( [0 {) a- e! i7 w ASTM D4060-01
7 V1 ]* O! @; T8 O8 S ISO 9352:1995/ d* O0 q+ \) L" `
密度 Density
! K' z7 S$ \9 ^, C5 ^ c5 S* a5 r ASTM D792-002 p" m; ]2 V: n/ B. a
ISO 1183-1:2004 f9 V' @0 ?9 g8 u& x& f* i% z
GB/T 1033-86
/ o. }! c" d1 p9 \0 s d ASTM D1622-03 (硬质泡沫表观密度)) K0 J: b# W+ s# |9 e
ASTM D3574-03(软质泡沫表观密度)
/ g' u* m! H6 f( ^; }# M GB/T 6343-95 (泡沫表观密度)3 {7 e7 p! z1 i% n1 A1 q9 Q4 g
尺寸 Size
& M g) w4 p4 \8 Q4 W/ v9 u! V& ]7 z4 Z ASTM D5947-03
% E7 P& q3 T$ m1 r; S) h ISO 4648-911 a, u8 {1 S2 L4 v5 s i
GB/T 5723-93& K0 L& v+ E4 @
面积重 Mass per Unit Area/ P+ N# p* {) c- z2 A/ b5 p5 S
ASTM D5261-92(2003) |
