Index( \ d4 A9 C; A* g: }$ g; c, {, n
PAGE CONTENT
1 p& |3 t7 a& HSection 1 1 g3 ]. @/ V( r$ k7 `
2 Selection, Definition and Advantages of Conformal Coating" q% a9 _. G$ {4 x( D9 f
3 Design Application & Criteria
: g- Q2 ?% \2 c( Z# Y) Z, zSection 2
4 D3 e) P% X5 T. I8 O% G& q, f1 q, M 5 Material Characteristics
8 D9 R6 H* z N# `, P6 O$ V' U9 u 5 Pot Life, Shelf Life, Viscosity, Solids Content y1 R1 e' Q# q% F _2 p5 W
6 Cure Temperature, Electrical Properties, Moisture Permeability/Absorption,& b5 H2 @; ^* z- w2 |
7 Chemical Compatibility and Properties, Mechanical Durability,Repairability, Thermal Properties, Fungs Resistance8 J6 l. J2 h; n/ t) w) I/ D
8 Curing and Setting( }% `. Q; [: S4 L7 J
Section 3
3 l# e5 d' l C' A( A' c8 W 9 Coating Types8 K/ a6 l a( H
9 Acrylics, Polyurethanes, Epoxies
' V N' G9 H' g: d* B# p 11 Silicones& E p3 Y' k2 a
12 Environmentally-Friendly Coatings: Water-based and Low VOC
H" P8 r2 N" D$ e' {+ T9 S( ` A 13 UV Curing Coatings, Conformal Coating Selection Chart4 d* b* Y H( {* j' R+ N6 T& \
Section 4
. k+ D6 i, q! O* S* X( T4 S 14 Long Term Reliability Testing and Cleaning( e8 d& h. y- t+ z; w* B
18 Surface Preparation, Masking4 D& w% K1 G5 d% J0 t
Section 5
]- Q. T; K" |+ X' X( L 20 Application Methods & Procedures
- u2 o$ c9 B7 r4 p9 B) x9 h 22 Selective Robotic Coating
! m$ W5 G- u T6 L- ^ 23 Automated In Line Spraying6 n/ A( B, @$ G9 a5 l% w! ?- s
24 Hand Spraying
* [2 ]. J h+ j1 g8 q; Y" R& c 25 Aerosol Spraying
7 G* J1 A% j) Y: X: @. n- q 26 Brushing, Humidity, Vacuum Deposition, Inspection
7 P& G6 ^ t) t2 n1 M 27 Conclusion5 l5 M$ m5 Q* N# N2 A' M
o& t$ l; `% Y! _& `: U
[ 本帖最后由 wanglinyou 于 2007-6-27 13:55 编辑 ] |
