楼主 |
发表于 2007-6-28 20:15:04
来自: 中国广东东莞
我是写在另外一个文件里面的,里面有很多的程序,其它的都没有问题,只用其中的几个有问题:( Q$ ?5 Y) V5 V# z4 M
7 k: B. l( C7 b/ [5 v) g4 k(defun c:CCD()
4 E3 d/ c F& |. m6 h6 z3 M (prompt "\n恢復捕捉模式:")
5 x* |- L% [4 P2 q: p& i* c. C (setvar "osmode" 703)
( q, z. M0 l1 n p, p: ^). i- ]3 M" B& l
;******************************************************************************* O3 n3 ]2 R. ?2 K$ l: n+ g1 D+ D
(defun c:CDD()3 m6 h5 z! ]( A; P5 m! _1 k8 |
(prompt "\n取消捕捉模式:")
( X' Q6 _5 I% W$ B& u (setvar "osmode" 0)! Y, O) A$ C3 i* {- O
)! w; j8 q5 {4 @! Q* ?
! b/ a- o5 g- M" Y/ W7 T& m8 A(DEFUN C:er(/ VAR1 VAR2 O A P Q) ;功能:切換到物體所在layer
8 q8 Q7 g. }7 P; X2 N- s* E (SETQ VAR1 (GETVAR "BLIPMODE"))/ e9 t, ?/ f9 t2 [
(SETQ VAR2 (GETVAR "CMDECHO"))
+ f' Y/ t& b& C/ f (SETVAR "BLIPMODE" 0)
. D/ V; ^: f1 s- R3 R) z" k (SETVAR "CMDECHO" 0)/ Q* z" H& r! V5 [, |; u
(PRINC "\n 切換到物體所在層 : ")
4 k1 n8 x/ I! _7 h, q' n6 W7 I (SETQ O (ENTSEL))+ m+ P# o0 G2 p# Y5 n
(SETQ A (ENTGET (CAR O)))
5 e- S8 t5 w: n (SETQ P (CDR (ASSOC 8 A)))3 L, M; u& ?! J3 C) K; d$ ~/ M
(SETQ Q (GETVAR "CLAYER"))& G) f: _$ O3 k6 @% h% F' I
(IF (= Q P)! l! Y/ v- g2 ]/ l6 p5 Y& _& ?. ]
(PRINC "\n CORRENT LAYER,CAN'T FROOZEN!!!!")
; a# U' @( ?3 E1 `4 g (COMMAND "_-LAYER" "_s" P "")
, \1 w6 o3 H6 R/ H% o+ n! x2 s )
. ]2 e- @9 [! ]. Q (SETVAR "BLIPMODE" VAR1)
- d5 |, ~. ~" A7 Y (SETVAR "CMDECHO" VAR2)
! C1 q' |& X& ~- f+ d& P+ \ (PRINC "\nOK!")(PRINC)
+ F8 z( N0 U$ N A0 `) X- T)
1 y: V& h/ l( J! \;******************************************************************************** }' \7 T2 [' f0 a4 n$ d& y; R
/ N* s! S2 H# `5 D5 W' f另外:
+ j' b9 l* f; T直接在命令行里运行下边一句:. g, M8 _9 F( Z* m
setvar "osmode" 703" ~1 p! `' b: V2 j+ h* Z) ]* C. h) _
再确认就可以!. W y$ R5 z8 I8 k7 O! c
但是运行
- k2 ^6 M3 o7 I(setvar "osmode" 703)
9 d4 S9 {7 g7 X* [1 [, l. N就不行,. k5 t( c6 V- M( B7 X# P5 c
郁闷中…… |
