- 积分
- 8
UID345409
主题
在线时间 小时
注册时间2007-7-13
大家帮忙看看代码:1 O2 Z, P0 V& A4 u+ `
得到了矩形的各个边的tag 也得到了边的条数,为什么得不到坐标啊,都是0,0,0???
% _4 R/ R/ I6 D% U9 [+ r; h$ ] double p1[3]={0,0,0},p2[3]={0,0,0};: A" N- O) S! r) l5 ^
int vertex,type,count=0;. n! O2 V9 h A
tag_t obj_id,part_tag,edges_id;; z M$ z, W3 U* N, D) Q* H K. E
obj_id=0;
& H( t3 L+ U* e uf_list_p_t loop_list;% g4 W1 D6 O" s3 l( q' `9 e1 G3 O, H
type=UF_line_type;' u/ D x9 F3 R" @
part_tag=UF_PART_ask_display_part();9 S% C1 i. s- x0 }
UF_OBJ_cycle_objs_in_part(part_tag,type,&obj_id);, n; a& h9 G H% J/ L* c
CString str1,str2;2 C) P6 j1 g, S5 M
! \ w2 h7 M, k6 r1 l) B* s while(obj_id!=NULL_TAG)
2 s$ l! N5 M' i) X- X, I {
/ [ z$ e% s& C" ~: b
& b/ p) {2 P" J8 c+ {; V( \ count++;6 A5 V9 ?+ t) s. N6 J' |
3 X- r/ B; S9 B* X% F5 V/ D) j( J UF_MODL_create_list(&loop_list);
$ C* P s3 P O! I! E; y UF_MODL_put_list_item(loop_list,obj_id);9 y* \% O5 }7 [8 I! @5 S% g6 |1 t
9 ], F7 b1 z- G( J/ A/ [$ C//edges_id得到了啊% ^) ^, k3 I0 u% `' O
; ]3 E; B; ^' y) T ^ for(int k=0;k<count;k++)5 P9 D; S; x, K0 S. k0 k4 m
( K$ U9 `8 r4 [2 X0 N UF_MODL_ask_list_item(loop_list,k,&edges_id); O' u. w3 K- T" c E O0 @. [) D
UF_MODL_ask_edge_verts(edges_id,p1,p2,&vertex);7 J/ `7 U9 b' I: y" B+ {
str1.Format("\n第%d条边信息:\n",k);
! `9 S" E) q: g. w UF_UI_write_listing_window(str1);
r L7 [3 I/ ?; y# _ str2.Format("strpoint:X=%f,Y=%f,Z=%f,endpoint: X=%f,Y=%f,Z=%f\n",p1[0],p1[1],p1[2],p2[0],p2[1],p2[2]);
# @7 f2 d5 L" Y UF_UI_write_listing_window(str2);$ Q: p; J4 q6 ^9 C9 y" J R/ _5 N
