查看: 2698|回复: 3
[求助] 关于SA-240Type310S和CortenA
发表于 2007-7-31 10:42:57 | 显示全部楼层 |阅读模式 来自: 中国山东烟台
请教以上两中材质的性能和特点,还有这两种材质和国内的什么材质性能相近啊??
发表于 2007-8-10 00:29:56 | 显示全部楼层 来自: 中国山东烟台
SA-240Type310S 相当于310S 查资料就行了2 F5 ^" B4 s$ a8 A4 a5 L
CortenA  %:0.10C, 0.40Si, 0.48Mn, 0.094P, 0.019S, 0.52Cr, 0.34Ni, ...( `" O# y, E. K7 O4 b
0 S; T% |( W. |7 z* k5 ^. f
Weathering steel, best-known under the trademark Cor-Ten steel, is a group of steel alloys which were developed to obviate the need for painting, and form a stable rust-like appearance if exposed to the weather for several years.. M) y- x: d, I  j. Q0 o9 \, V
' i" f) B5 v9 ]# O
United States Steel (USS) held the original registered trademark on the name COR-TEN, which passed to International Steel Group (now Arcelor-Mittal) with the purchase of USS's heavy steel plate business.[1]- e; q# B0 \& ~6 V
/ u! k1 I6 N4 c5 V( V# R; \
In some areas it may be known without the hyphen as "Corten steel".* I7 z3 z% A2 ~) ?
$ x" n4 Q$ h2 O) t/ n9 f3 CThe original Cor-Ten received the standard designation A 242 ("Cor-Ten A" from the ASTM International standards group. Newer ASTM grades are A 588 ("Cor-Ten B") and A 606 for thin sheet. All alloys are in common production and use.
wjliao + 2 应助
发表于 2007-8-10 23:51:45 | 显示全部楼层 来自: 中国
期待哪个英语能手将2楼朋友的应助的大概意思翻译成中文,同样奖励!
发表于 2009-7-16 11:18:57 | 显示全部楼层 来自: 中国江苏苏州
回复 3# BV 的帖子
240Type310S相当于310S查资料就行了
6 B* u) F7 o2 o9 g成分  % : 0.10C , 0.40Si , 0.48Mn , 0.094P , 0.019S , 0.52Cr , 0.34Ni , ...
$ K9 d* ?7 _* \
* e, W& B# b: P4 b! M' |耐候钢,不用表面处理,如果暴露于空气了好几年,不会有红锈.4 I5 Z" N- j$ ^
+ l2 `: i" k# K4 C  k
美国钢铁(号)举行的原始注册商标的名称西科个,其中通过国际钢铁集团(现为阿塞洛米塔尔)购买号的重型钢板业务。 [ 1 ]
. r4 C1 O$ D  E
0 |* B: [' |8 a4 Q( k, [在某些地区可能是已知的字号为“ Corten钢” 。
7 z: V- \$ e$ i- G7 @" P
# D5 C% c# ^0 f: a2 A, s. L- `+ b# P原来耐候钢标准收到指定甲242 ( “耐候钢 从ASTM国际标准组织。较新的ASTM标准等级为A 588 ( 耐候钢B ”类和A 606的薄板。所有合金的共同生产和使用。
