ASME B31.3 Process piping -2006: ' {) C1 D0 M5 T) Q* `) G n345.9 Alternative Leak Test$ l: z6 x# l) c! O: K" Q% j% @ N
The following procedures and leak test method may! B$ D- H M+ V
be used only under the conditions stated in para. : [2 N, Y- L( C8 y345.1(c). $ N p# K ~# j" m4 e2 A' W345.9.1 Examination of Welds. Welds, including : A0 a( T# _! ` u* c% O _7 Wthose used in the manufacture of welded pipe and fittings, ' z+ E( `$ v- t4 H6 }which have not been subjected to hydrostatic or * `7 e1 N6 w* w6 L) g' c8 Hpneumatic leak tests in accordance with this Code, shall. a0 b4 @+ g! U' h# l, m
be examined as follows: 2 j0 q. I# u B3 ?796 P) u) Q0 R# `4 o9 A- T
(a) Circumferential, longitudinal, and spiral groove 0 n" K8 B$ l5 {3 q' |welds shall be 100% radiographed in accordance with ) E$ Q. i# M/ s: \para. 344.5 or 100% ultrasonically examined in accordance. R/ V: G6 V/ {3 X% q" q5 }
with para. 344.6.8 T, j I! x4 |# B: g' A
(b) All welds, including structural attachment welds,1 ^$ i* _/ ~& k& @; h* G, f$ `& o
not covered in (a) above, shall be examined using the- T( P" @+ [0 t0 F; \- \
liquid penetrant method (para. 344.4) or, for magnetic, j6 a e9 E @$ M/ d J4 u; }, S, P
materials, the magnetic particle method (para. 344.3).
还有,就是同意用NDT替代压力试验了,我们还得选择探伤的方法,看工件的材质,接头形式,厚度,焊接方法等等,选择是用RT UT MT 还是PT. 象这样光说是热力管道,选择100%UT,我们应该是无法说他是正确,还是考虑不周.5 q* o, h9 v/ U0 k) w
欢迎提不同的意见,大家探讨,以学习没目的
