查看: 1164|回复: 1
[分享] Surlyn 8920 thermoplastic resin
发表于 2007-8-6 13:41:31 | 显示全部楼层 |阅读模式 来自: 中国四川成都
Surlyn® 8920 thermoplastic resin
1 Y1 m( a- C$ SGeneral Description2 J2 o) A* C$ F
Surlyn® 8920 thermoplastic resin is an advanced ethylene/methacrylic acid (E/MAA) copolymer, in which* r7 [# y: R; j0 s/ \- i3 L5 e
the MAA acid groups have been partially neutralized with sodium ions. The amount of MAA and
) n5 t. h- \& W! Mneutralization levels for this grade result in excellent abrasion resistance, clarity, and stiffness. The resin
; n. [4 D9 Y1 v, @. wcan be injection or blow molded, and is processable by extrusion into sheets or shapes. It also can be used& U9 A* L% ]+ o% o4 J
as a nucleating agent for PET molding applications. The resin complies with the provisions of U.S. Food6 S( \& n2 R9 l0 ^. f+ P/ t/ L
and Drug Administration (FDA) Title 21 Code of Regulations 177:1330. Typical performance properties are6 ]; W& T1 g. k/ m# @) C7 k% z
shown below:
Surlyn8920.pdf
36.62 KB, 下载次数: 2
 楼主| 发表于 2007-8-6 14:04:56 | 显示全部楼层 来自: 中国四川成都
Surlyn树脂的简要说明
DuPont™ Surlyn® 8920 Data Sheet2 F2 ~/ l# n& Q$ S  K' S
杜邦公司的   沙林TM(SURLYN&reg  离子键聚合物树脂  技术资料。
