查看: 3627|回复: 3
[已解决] 这是什么材料?
发表于 2007-8-13 10:02:30 | 显示全部楼层 |阅读模式 来自: 中国广东东莞
ERTALYTE-TX是什么材料?
7 a/ k* H1 _% n  W. s在论坛上看到有问ERTALYTE材料的,这个后面带TX的是不是和它一样?
( [4 o4 K" \/ p% ?是不是就是PTFE?铁氟龙或者超白钢?
发表于 2007-8-13 14:23:10 | 显示全部楼层 来自: 中国山东泰安
网络解释,仅供参考!
ERTALYTE-TX:- a9 k; s8 f# }2 t0 n: g
PET+固体润滑剤;
. _, x$ [" Q$ G: ?* ]- |2 z种聚乙烯对苯二酸酯化合物,添加了均匀的固体润滑剂。) e  d: v+ }+ u# r! e; r) ^# u
具有高级的内润滑轴承级材料。其摩擦系数较低,能承受更大的压力速度系数。
云动风清 + 5 应助
发表于 2007-8-23 19:10:40 | 显示全部楼层 来自: 中国安徽合肥
也是网上找的资料  可以看看
/ q9 D$ t0 ~( W1 w
Ertalyte® TX
3 L9 F' b  D# s6 U4 HErtalyte® TX rod for machining high-wear-resistant parts is an unreinforced semi-crystalline thermoplastic polyester (PET-P) that has a solid lubricant filler. The material has excellent performance in both high-pressure and high-velocity conditions, and is ideally suited for applications involving soft metal and plastic mating surfaces. + A+ s/ ^. f7 ^' q3 I( a  _
  f; l, H0 G$ n! OKey properties of Ertalyte TX, are its high strength and stiffness, high wear-resistance, very good dimensional stability, high creep resistance and very good chemical resistance. This combination of properties make it an ideal material for machining bushings and bearings that require no startup or running lubrication. 0 }) g" G2 _3 P3 j" E$ x
2 I" d  \' c9 A/ oErtalyte TX has FDA and USDA compliance and is ideal for applications in food packaging and processing equipment.
2 j$ w2 e. G) h0 ~4 C7 |3 v9 o, n) x
Ertalyte TX stock shapes are made using proprietary resins produced by Quadrant. Quadrant's Ertalyte TX shapes offer dimensional stability, wear resistance, and low-friction characteristics superior to those properties of competitive filled polyethylene terephthalate polymers
' [" }( I, ^4 g( ?: O1 N
. A9 W/ M) {" T. a- {* `+ _! e[ 本帖最后由 xiaozhu0607 于 2007-8-23 19:12 编辑 ]
发表于 2007-8-23 20:33:19 | 显示全部楼层 来自: 中国辽宁沈阳
也是从网上查到的:6 [5 F* Z# X; V+ `2 _; C* M
ERTALYTE®是种结晶体 PET(聚酯) ,特别适合制造精密的机械加工零件,承受高负载并且耐磨。
1 \3 X7 O7 I5 @6 y( IERTALYTE® TX( (PET + 固体润滑剂)是种聚乙烯对苯二酸酯化合物,添加了均匀分布的固体润滑剂。其特殊配方,为我们提供了高级的内润滑轴承级材料。ERTALYTE® TX 不仅耐磨性出色,与 ERTALYTE® 相比,其摩擦系数较低,能承受更大的压力速度系数。) R( S: G7 {( Y7 D8 A. X
7 w8 v; j2 o2 \% w- G; a
ERTALYTE®与ERTALYTE® TX 应是两种材料,一种是PET,一种是改性PET(降低摩擦系数,提高耐磨性),两者都是由瑞士工程塑胶(亚太区)有限公司生产的聚酯材料(工程塑料的一种)。$ Q. n" {0 v/ J  O2 u+ U7 T% r+ X
2 ~1 z: L5 ?% H/ Y* T) J
[ 本帖最后由 hanjixian 于 2007-8-23 20:57 编辑 ]
hoopoe + 5 应助
