小弟初来宝地,献上一些资料与兄弟们共享!因为CAJ格式不能上传,所以转为pdf格式,请大家下载后再将后缀变为caj,就可以看了。如有不便,还望见谅。如有那位兄台可以帮我解决上传问题,鄙人将十分感谢!
+ E. J4 U- ^- \+ u9 Y: [2 ^
7 d: l* o: ~6 \- w$ Y/ i. I常 温 磷 化 技 术
$ x0 v. R) K; s# d+ Y华南理工大学化工所(广州 510641) 夏正斌 涂伟萍 杨卓如 陈焕钦
- P( D! q# [" M9 t! \6 n( ]' s+ B/ i摘 要 从磷化膜形成过程、磷化液组成、促进剂的选择等方面综述了常温磷化技术的现状与发展趋势。" l1 }6 S, d' J! D
关键词 常温磷化 磷化膜 涂装前处理 促进剂
0 ?+ E, M! x0 k/ Y6 Z16 Aug 1999 MATERIALS PROTECTION Vol.32 No.8% n6 k. a( v% K1 ~
* _1 |9 m2 N: Q) L4 E4 P" z! g( b$ u* s3 V' n8 p& ~
2 s( r5 \! E+ c/ @3 i! I
* W# Z- R ]) ~# XDevelopment of a Normal Temperature Washable Iron Phosphating Solution (1.陕西天科核工业技术研究所,西安710054; 2.铁道部四方机车车辆厂,青岛266031) TANG Lin1, ZHEN Min2, SHANG Hong-feng2 (1. Shanxi Tianke Nuclear Industry Technology Research Institute, Xian 710054;2. Sifang Rolling Stock Plant under the Railway Ministry, Qingdao 266031) 摘要: 研究了一种可水洗的新型常温铁系涂装前磷化液的组成及其磷化工艺,探讨了其成膜原理。该磷化液无铬、无亚硝酸盐、无渣,膜层致密均匀,耐蚀性能优良,磷化后可水洗,适用于中、低碳钢及其合金制件的涂装前磷化。 Abstract: The composition and process of a novel water washable normal temperature iron phosphating solution are studied and itsfilm forming principle is also explored. The phosphating solution is free from chromium, nitrite and sludge. The resulted film is dense and uniform with a good corrosion resistance, and can be washed with water after phosphating, suitable for phosphating medium and low carbon steel and their alloys before coating is applied. Key words: Normal temperature; washing; Iron phosphating solution 中图分类号:TG 174 文献标识码:A 文章编号:1000-4742(2003)02-0028-02 |
