查看: 3129|回复: 3
[分享] 钢材相关英语词汇
发表于 2007-9-2 08:38:41 | 显示全部楼层 |阅读模式 来自: 中国广东深圳
A R Steel 高温度锰钢& R0 v1 @) Z/ R  S8 ]
Abnormal Steel 反常钢; 非正常钢
# a% o/ p. b) j. z% k) a1 BAluminium-steel Cable 钢铝电缆
; r# o' B! c" o4 S  E, t2 oAluminized Steel 涂铝钢1 S% @% \$ @$ J2 v; v
Aluminum Nickel Steel 铝镍钢
: C8 m, }* X+ I9 E5 LAnchored Steel Trestle 锚固式钢栈桥
! r$ V/ Z8 B: W9 dAngle Steel Ruler 钢角尺1 i- v; Q( s$ K/ f. ~. P
Anisotropic Steel 各向异性钢片* w" F' Y' r+ I! v1 m. L# ]# R
Anisotropy Silicon Steel 各向异性硅钢片
6 }- |5 m- w3 X. _Annealed Sheet Steel 退火薄钢板
, C! R- N, a- _( z! FAnnealed Steel 退火钢; 韧钢5 @1 C) Z. ~4 w+ \) g
Anti-Creeping Angle Steel 防爬角铁
5 m2 ?' G& T% J: z- h( BAnticorrosive Aluminium-Coated Steel Wire 防蚀镀铝钢丝* w& g' d( S# d/ q1 e5 O/ {
Arc-Furnace Steel 电炉钢5 g2 c0 C/ Z4 R; L9 v! B% F
Arc-Welded Steel Pipe 电弧焊接钢管6 v, e7 W- M9 i) r
Area Of Steel 钢筋断面面积; 钢筋截面面积$ n0 e+ }, h, M/ l6 r
Area Of Structural Steel 型钢截面积
8 |9 `+ M& X& M; Q+ MArmco Aluminized Steel 阿姆柯渗铝钢
! S$ G# J. H6 AArmco Aluminized Steel 表面浸镀铝钢- N: |# i9 c" F: a. `! r
Armco Stabilized Steel 阿母柯稳定化钢0 G# J" h6 b# L) g9 a8 T9 s
Armco Steel 阿姆柯软钢
) v  r! P$ b! q9 Y4 \; j& X% }0 a* Q( iArmco Steel 不硬化钢
7 H4 |. }+ s% s) s1 v  j9 }5 rAustenilic Ni-Cr Stainless Steel 奥氏体镍铬不锈钢) r* o# P9 M( E5 O6 P
Austenitic Alloy Steel 奥氏体合金钢
% ~; W3 I: G( w; x5 wAustenitic Chromium-Nickel Steel 奥氏体铬-镍钢
- y. q- D! D$ W1 x5 [( |Austenitic Clad Steel 奥氏体复合钢0 J6 Y' N9 q) h7 o
Austenitic Heat-Resistance Steel 奥氏体耐热钢. I' [5 T/ b" y9 N8 r0 S
Austenitic Manganese Steel 奥氏体锰钢; 哈德菲尔德锰钢! H. B; W9 ^2 O
Austenitic Stainless Steel 奥氏体不锈钢
& ^. X. E5 B3 NAustenitic Steel 奥氏体钢+ {- v, Y* N* c% {$ k& n* U
Automatic Steel 易切削钢/ B7 w% \; H0 g
Automatic(Al) Steel 易切削钢4 J' T. ?, [( g8 T6 z  E9 W
Axle Shaft Steel 车轴钢
* m/ ^) O+ {3 y. v8 iAxle Steel 车轴钢
( T, @7 O! i# mBainitic Steel 贝氏体钢
/ q$ b; A5 s2 Z: RBalanced Steel 半镇静钢5 v+ `) R' @) O* J& Q: ?) K( W- f, I
Ball Bearing Steel Strip 滚珠轴承钢带
# T8 a8 G3 m7 m% H  U% C9 wBall Race Steel 滚珠轴承圈钢3 @% J3 a" l; I0 l
Ball-Bearing Steel 滚珠轴承钢$ B* A* X, t" {- A* U* i
Bamboo Steel 竹节钢筋: A# |5 b; S) G- X4 ?  [
Band Steel 带钢
! W: I- |+ |, R. N2 J2 WBanding Steel 带钢; 箍钢1 g+ B: U1 R# T+ W% d$ c7 F& a
Bar Steel 棒钢; 条钢1 h! q# S/ }; K4 f' y) I3 _
Basic Bessemer Steel 碱性贝氏转炉钢- {! i1 C7 I$ W! ~# n+ K8 r
Basic Bessemer Steel 碱性转炉钢
8 k5 n8 H( R" x) TBasic Bessemer Steel Converter 碱性转炉钢转炉
/ x9 m1 r5 j# r4 r0 [4 P# J0 x" EBasic Converter Steel 碱性转炉钢% k9 a9 x) F/ d5 N2 a; @- d) @
Basic Electric Furnace Steel 碱性电炉钢  `: h5 _7 K# }0 O
Basic Open Hearth Steel 碱性平炉钢) z$ j# B8 @1 M5 j  V. Q
Battened Steel Column 双肢钢柱
$ j1 z$ M/ o9 d. O! U6 mBeam Steel Plate 大梁钢板+ h6 w+ r2 X3 x  C: \, {
Beam With Compression Steel 双筋梁
  q" r  ]  i. l) l+ m0 k8 D0 iBearing Quality Steel 滚珠钢
/ g# i$ L8 ^5 b& e% e# J6 `Bearing Steel 轴承钢9 w5 G% f- L9 ^8 q
Bent Steel 挠曲钢筋( }0 O/ K1 i) b& ]
Bessemer Low Carbon Steel 酸性转炉低碳钢
5 |+ K, z  o; [9 V5 S0 CBessemer Mild Steel 贝色麦钢8 g9 I- w4 A' J* q# r' I% E
Bessemer Steel 贝色麦钢; 酸性钢+ J8 j2 {+ h0 U6 F
Best Plough Steel Wire 铅淬火高强度钢丝
2 V1 d, [. f7 P5 }7 t) KBillet Steel 坯段钢; 钢坯; 短条钢/ Z' B' ?! h/ W* ^+ s- T" n* V
Binary Steel 二元合金钢( m! |' [2 B! w3 O$ I
Black Mild Steel Carriage Bolt And Nut 黑铁马车螺丝闩- ~6 }- A) _, z% I6 S
Black Mild Steel Fish Bolt And Nut 黑铁鱼尾螺丝闩
8 v% ?$ G2 _, p2 i% E$ U/ QBlack Mild Steel Flat Head Rivet 黑铁扁头铆钉8 K. T2 N& Q* ~) H+ x
Black Mild Steel Flat Head Tinmen Rivet 黑铁号头铆钉" L: w+ r9 r) X" t% z
Black Mild Steel Hexagonal Nut 黑铁六角螺丝帽9 i' k( U2 I2 D! ]- e) C3 U* N3 v
Black Mild Steel Pan Head Rivet 黑铁锥头铆钉
# E, J4 z2 b  O; }/ eBlack Mild Steel Round Head Rivet 黑铁圆头铆钉
  C# o$ {& \" b- |Black Mild Steel Square Nut 黑铁四方螺丝帽
2 f. A+ t( I; @+ b2 V# ?Black Steel Pipe 黑钢板' i, t7 T* o) y9 p6 p
Black Steel Sheet 黑钢皮: m9 O6 H, |, O% h# i% c9 N
Black Tin Steel 黑钢板1 w5 [* C" l3 `/ z. R" t; `
Blister Steel 泡钢; 泡面钢3 a2 X& L! ]3 `. Q% W) f  l$ s
Abnormal Structure Steel 反常组织钢
+ L$ `3 M9 U7 }( dAbrasion-Resistant Steel 耐磨钢
% b6 B, h  w: U) `* m( \8 ^& tBlue Steel 蓝钢
" c! Y7 @# N: u+ A" }Bluing Of Steel 钢加蓝
* {4 v( T  Y- }Boiler Steel 锅炉钢; 锅炉钢板
5 w! J/ K" Y* ~: m" O# TBoiler Steel Plate 锅炉钢板3 i& v- _  c* Z1 f. M
Boiling Steel 沸腾钢
8 p$ q7 |  x5 k& J; IBolting Steel 螺栓钢, m7 n# c5 B; Y3 t4 O
Blue Planished Steel 发蓝薄钢板
* I" r! ]$ U5 M4 `) Q6 j5 rBloom Steel 初轧钢; 钢坯. P2 |" x' w# O# q+ O
Boron Steel 硼钢+ ]* y. E" t, K5 y; E
Brass Fitting Of Steel Window 钢窗铜配件- p5 S5 A4 Z0 f; U& }( L! ^
Brass-Plated Mild Steel Round Bead Wood Screw 镀黄铜圆头软钢木螺丝
1 H( k8 R, H9 E( p; ?/ S  xBrass-Plated Mild Steel Round Head Machine Screw 镀黄铜圆头软钢机器螺丝
& L1 Y# g1 u0 [Brass-Plated Steel Wire 镀黄铜钢丝& B& Z9 y9 C+ R, r
Brearley Steel 布里阿雷不锈钢; 布氏高铬钢
! C* ~' T  {) D7 RBridge Steel 桥梁钢
, G7 ]+ i+ L+ G/ \: x: GBright And Black Mild Steel Flat Head Tinmen Rivet 号头铆钉
7 h. f3 s7 V# J* Q# G# `Bright Mild Steel Cotter Pin 光亮软钢开尾销
$ U  B3 g* a& W' R0 }9 R- jBright Mild Steel Countersunk Head Wood Screw 光亮软钢平头木螺丝
8 Q/ U8 T9 F9 WBright Mild Steel Hexagonal Nut 光亮软钢六角螺丝帽. ~( k8 v' k2 e3 q7 \, M
Bright Mild Steel Hexagonal Nuts 六角光螺帽; 六角螺丝帽
6 S3 c) X, K, u5 iBright Mild Steel Hexagonal Pressed Nut 光亮软钢六角冲压螺丝帽! w9 D4 ^0 d+ I, H' J& T3 d0 r. `
Bright Mild Steel Round Head Wood Screw 光亮软钢圆头木螺丝! Q4 [& R+ [$ u* J0 E
Bright-Drawn Free Cutting Steel 光拉自由切削钢
1 f) l$ N& n: w& ?; W; T, VBright-Drawn Steel 光亮拉拔钢材
. }5 r1 z/ i" |7 V+ aBright-Finished Steel 光亮精整钢
, [& P3 g" @# c! i' GBristol Steel Belt Lacing 布瑞斯涛钢带接头
- E; z. e' c6 _* U' v9 W2 y+ cBronze Steel 镀青铜钢  n! Z1 |: `) y* `6 A; h% \1 C
Building Of Steel Frame Construction 钢框架房屋2 @0 f0 H9 S2 R. T4 n
Bulb Steel 球扁钢+ f/ y; E, }, Y  o8 e1 ]6 P+ X
Bulb-Rail Steel 球头丁字钢
2 g& z1 ]# i- A  x3 ^8 a7 zBurned Steel 过烧钢' ^5 W; b  y& V$ p/ D. |! Z
Calorized Steel 涂铝钢; 渗化钢$ r* T& O; W% l6 b
Calorizing Steel 铝化钢
$ }2 h, j/ j4 aCapped Steel 加盖钢; 半镇静钢* h3 D8 X/ Z# C- H( ^% `
Carbon And Low-Alloy Steel Vessels 碳钢及低合金钢容器+ E( G/ c. m2 N  ?) s
Carbon Content Of Steel 钢含碳量
. X5 |- M, C" z/ H( d. ]8 G7 kCarbon Molybdenum Steel 钼碳钢
% D# ]; f6 X9 {! _Carbon Steel 碳钢; 碳素钢/ L2 ?+ E$ R( B$ w2 `; b
Carbon Steel Covered Electrode 碳钢焊条9 A2 A3 R* c+ u: T: X1 j
Carbon Steel Plate 碳素钢板; 碳素钢板和型材9 M$ Q$ v8 F* ~" v
Carbon Tool Steel 碳工具钢; 碳素工具钢- B/ Z- X' H) X$ D1 a' y! |
Carbon-Containing Alloy Steel 含碳合金钢
) ^! |/ c& G) x! TCarbon-Free Stainless Steel 无碳不锈钢
4 A5 u  `4 G1 k* `5 T! H$ B/ u1 C  `2 eCarbon-Free Steel 无碳钢
, e! Z. u. |1 u' `' dCarburizing Steel 碳钢2 i' c. Z+ B( v5 A( v
Case-Hardened Steel 表面渗碳硬化钢; 渗碳钢: Q6 x1 d1 g3 x) B3 E& t* M9 u
Bolts & Nuts For Steel Slotted 角钢螺丝
) R: q/ k, Y9 |( K# KCast Alloy Steel Piston 合金铸钢活塞
, B8 v4 K7 a' uCast Iron Electrode With Steel Core 钢芯铸铁焊条
- C! U( J# X- n  g: z, OCast Stainless Steel 铸造不锈钢0 K; A! x) S  @$ P
Cast Steel 铸钢件
! q8 T/ }5 u' F. sCast Steel Plate 铸钢板! R. [5 o, ~5 ]& h! L7 A
Cast(Carbon) Steel 铸钢
4 o  y9 ^/ i( J! S% hCast-In Steel Bush 铸入钢套. u8 u* l+ O5 p- V( ^; ?
Casement Section Steel 窗框钢9 Y9 O" Y$ t: P( _/ ]
Cast-Steel 铸钢
! @; a5 g' N. l9 d( Y: X& V  R- ^Cast-Steel Crossing 铸钢辙叉4 B- L7 ~+ q0 A$ u+ x% I
Cast-Steel Pipe 铸钢管
2 g. I* U% [4 q7 ]' z6 f- n0 ECast-Steel Separator 铸钢隔板; 铸钢横梁6 n! Y$ t8 F! ~! v6 i+ X
Cast-Steel Shot 钢砂( J4 B! j, A$ x3 w: |
Cast-Steel Yoke 铸钢轭
# N* d. c$ h" N* K( jCellular Steel Floor 格型钢楼板
0 a- L  f, [$ ~/ M- Q/ W# u( }  o$ _Cement-And-Grouted Steel Bolt 钢筋砂浆锚杆
0 A" a6 X2 E  F# O- \2 n/ nCemented Steel 表面硬化钢* N$ \/ }0 y; P; Z
Cemented Templet Steel 渗碳样板钢# v, V: G: F5 @- T# v
Centra Steel 球状石墨铸钢
( K6 E4 T- x% w3 f; K- rCentrifugal Steel 离心铸钢
' b2 X$ d) ^( L/ ]" G/ ]0 [Centrifuge(D) Steel 离心铸造钢8 P# H: v- e1 N+ j) Z9 s) k% ~, ~
Channel Steel 槽钢# ~4 R5 K3 \* C. g  o! p  G
Channel-Section Steel 槽形钢
! O4 h- `1 n0 f5 [+ \Channeled-Steel Wheel Rim 槽钢制轮辋. J/ v* D  A9 i% m( f; Y# T
Checkered Steel Plate 花纹钢板6 [. }1 H. v+ @. `5 `6 K! ^' l
Chemical Capped Steel 化学封顶钢
. ?' s. z' \5 VChilled Cast Steel 冷硬铸钢) z( {2 n0 C0 ^+ m
Chilled Hardened Steel 淬火钢
! e; G; e7 w4 WChilled Steel 淬火钢; 淬硬钢
: d+ L" S: J; QChisel Steel 凿钢; 凿子钢' @% b5 N, h1 r  K
Chrome Hardened Steel 铬硬化钢, L+ }7 [/ S2 V+ c
Chrome Steel 铬钢
6 J) L  r/ E; c& P7 C4 O# iChrome-Carbon Steel 铬碳钢
  X% J1 W3 R! SChrome-Manganese Nitrogen Steel 铬锰氮钢
- a' ~/ x+ d! ]( V6 KChrome-Manganese-Silicon Alloy Steel 铬锰硅合金钢
5 g* S5 Q2 Q! t" L5 ^! RChrome-Molybdenum Steel 铬钼钢
  X! v5 Y2 x& wChrome-Nickel Steel 铬镍钢
  s. t9 O' Y$ _+ M$ mChrome-Plated Steel Nozzle 镀铬钢喷管+ l; q4 x$ a$ u( V4 k
Chrome-Silicon Steel 铬硅钢/ X% m+ c( b( {9 P# T
Chrome-Tungsten Steel 铬钨钢
/ @3 P5 d3 {: S$ Y# @0 jChrome-Vanadium Steel 铬钒钢2 \% b" @: \0 ?) Y
Chromemanganese Steel 铬锰钢+ o2 ~5 H# v; i0 p8 d2 {
Chromium Nickel Steel 高强度耐蚀铬镍钢
. m! ~+ {) \( f9 ~, d* CChromium Stainless Steel 铬不锈钢
- e2 F  F7 Q- W# u5 k  MChromium Steel 铬钢* Q. F% s. S; K( X; M: ^, k+ E
Chromium-Molybdenum Steel 铬钼钢
# p$ H+ G; h  j- SChromium-Nickel Steel 铬镍钢
" y& q6 }. L; H0 R6 N+ |4 ?Chromium-Plated Mild Steel Animal Chain 镀铬软钢动物链条! q  ?6 H+ N, G- f/ k( U; Z
Chromium-Tungstenvanadium Steel 铬钨钒钢0 g- K5 H# o2 X2 a
Chromiummanganese Steel 铬锰钢
, }4 M$ Q* K6 k' X" lChromiumnickel Austenite Stainless Steel 铬镍奥氏体不锈钢
; x7 T- s) ~  W/ cChromiumplated Thin-Walled Steel Cylinder Liner 钢质薄壁镀铬汽缸衬套
# Z/ q1 E( w) D" x4 fChromized Steel 渗铬钢: s: Q- \7 C' {) S. r- @
Circular Steel Support 环形金属支架2 t8 C. i; \6 Z
Clad Sheet Steel 包层薄钢板0 r( u* M" T  s- }6 @$ ]
Clad Steel 包层钢; 双层钢; 双金属钢
& F0 r1 r8 x" f. y3 o2 WClad Steel Plate 复合钢板1 \" U. \/ I* _) b2 x1 w) ^& O) B1 _
Cladding Steel 包覆钢5 k6 W& j! q9 _4 j: l6 `0 R# @
Cladding Steel Sheet 复合钢板
. Q+ R& a, U1 q3 m+ Z) RClean Steel 纯净钢; 洁净钢; U# y6 H4 m" z; d/ m6 ?6 ]8 }
Closed Die Steel 闭锻模钢
8 n; X/ `' c/ g* {& A! PCoarse-Grained Steel 粗晶粒钢
- H8 m) o& @: I* N" |/ ~Coated Steel 镀层钢板
  q9 F# [; S+ p5 V6 i1 r. N# vCoating Steel Pipe 镀锌钢管
" y! f' W9 \/ xCobalt High Speed Steel 钴高速钢
; L3 d( m& f- G5 i* d' t# ZCobalt-Chromium Steel 钴铬钢3 M2 t  f8 f4 A* T$ N; O
Coiled Steel 成卷带钢
0 Z3 }' I' J/ H& N  E: v7 NCold Forging Steel 冷锻钢/ |; a  s1 C& e/ h7 N1 ]' {
Cold Pressed Steel 冷压钢
* r$ B4 B$ E" D5 W2 e) `) y+ X, XCold Reduced Steel 马口铁卷板
6 v  q$ L' u# ?% o: S+ K( \Cold Rolled Ribbed Steel Bar 冷轧竹节钢筋* p& I  I( x2 F) Y# ?5 N
Cold Rolled Sheet Steel 冷轧薄钢板) `3 }5 q+ d4 U4 i
Cold Twisted Steel Bar 冷扭钢筋5 T" ^9 i+ w2 [7 `0 N8 n) g, T
Cold-Banded Steel Pipe 冷箍钢管
" Y& B' D1 p! S( p  {) ?- vCold-Drawn Steel 冷拔钢; 冷拉钢
) v, [' {- J  x& OCold-Drawn Steel Pipe 冷拉钢管
6 B5 h# L, e0 L# c2 Q4 f+ `Cold-Drawn Steel Tube 冷拉钢管
! B( ^' ^. B2 q% u+ S" d* X; ]Cold-Finished Steel 冷加工精整钢$ j) v9 E" @7 [6 y
Cold-Pressed Sheet Steel 冷压薄钢板: w1 ~% j% ^' Q# I
Cold-Pressed Steel Plate 冷压钢板% I/ f# r8 P- Z' w- Z
Cold-Pressing Quality Steel 冷弯钢9 z2 V- z1 Z% D& [1 B* a
Cold-Roll Steel Sheets 冷轧钢板8 f5 N# m' x8 B6 M6 V
Cold-Rolled (Cold Rolled) Steel 冷轧钢7 P  r) U6 J5 Y% G0 M& A: ]
Cold-Rolled Carbon Spring Steel 冷轧弹簧碳钢
  [7 n' c1 `9 K& |3 @* \* B* P- dCold-Rolled Carbon Steel 冷轴碳钢
: ^. [7 Q2 d1 kCold-Rolled Steel Strip 冷轧带钢/ E+ v$ h7 D  Z0 V6 F8 B' n
Cold-Shaping Steel 冷变形钢8 E) e  i6 r- Q& M! o4 S& p
Cold-Short Steel 冷脆钢2 F' }# x+ f5 t6 X, ^
Cold-Steel 利器. p5 ]' d3 ~( V3 g* y* h* }1 n
Cold-Strip Steel 冷轧带钢/ \2 p6 L! s9 E* }
Cold-Strip Steel Rolling Mill 冷轧带钢机; 带钢冷轧机
- L" v" n" f% \% D! e; e! fCold-Worked Steel 冷作钢
  q$ d8 d6 X$ m/ c" e2 |Cold-Working Steel 冷作钢, m" h# c& \' q3 K$ g' S3 \
Coldshort Steel 冷脆钢% G! I/ M/ H* J5 g& J5 V  v
Color Stainless Steel 彩色不锈钢
  R2 X, B, }$ a1 N* t3 H* AColored Stainless Steel 彩色不锈钢8 G# n2 r, I) [- t( b5 ~
Column With Steel Hooping 螺旋箍筋柱2 u4 M% D5 T8 _
Combined Steel And Concrete Column 钢骨混凝土柱* W; e: ?1 W2 x
Comminuted Steel Shot 钢粉0 Q: F  M" h: @5 t
Common Straight Carbon Steel 普通碳素钢3 ^, l6 r- }6 `" i, i6 {9 M! Z
Complex Alloy Steel 多元合金钢; 合金钢
1 m6 g  t! E" R, x0 CComplex Steel 多元合金钢; 合金钢
, j1 z2 G9 s2 r7 WComposite Iron And Steel 包钢铁" K4 _: {1 C- k1 c* m. _
Composite Steel 复层钢; 复合钢; 多层钢; 双层钢
- H9 l+ A! \0 ^* n1 mComposite Steel Bridge 复合钢桥# ^% }- n' C' G4 J
Composite Steel Concrete Column 劲性混凝土柱
$ W) L4 q% O. Z4 QCompound Steel 三层钢+ t+ ^( [7 p# X4 l* g
Compressed Asbestos Fibre Ointing With Steel Wire 进排气夹金属丝网橡胶石棉板# S! p& o7 ?" X7 ?! E0 f
Compressed Steel 压钢
; \2 v: F" \/ T2 XConcrete Steel 钢筋钢; 劲性钢筋/ l/ c% U3 @$ ^6 f2 a; I
Concrete-Reinforcing Steel 混凝土加固用钢筋
2 e! ~/ e# z9 t3 S2 s6 B, T+ ^, FCast-In Steel Pipe 铸入钢管
0 `+ m9 ]0 N: n, L; \; B% h' EConstruction Steel 构造钢
7 C/ b3 T; n2 @Construction(Al) Steel 结构钢; 建筑钢
9 e" S' P/ i) F- f3 l/ dConstructional Alloy Steel 合金结构钢: c4 h- K" W6 O* ^4 u: g2 i
Constructional Steel 构造钢
2 z$ `5 N& @: z6 K# H0 WConstructional Steel Bar 构造钢筋" Q& S5 Q5 S( Y* ?1 F& P8 \9 L
Converter Steel 转炉钢
$ y: Y& w3 t+ F" zCooler-Plated Steel 加盖沸腾钢4 f: T! Q  n; Y# ]6 V5 r+ g9 f
Conical Steel Body 锥形钢体, M7 n& ~# c+ r: J) ^* Q; y
Cope In Steel Beam 钢梁的顶层: s5 f9 b$ `" S/ p8 O. `
Copper Alloy Steel 铜合金钢
6 c% j8 l0 }1 E; aCopper Bearing Steel 含铜钢; 铜钢
* \/ H9 K% b: a5 B# t6 ^/ a. A0 uCopper Clad Steel 包铜钢
1 R% l$ y5 ^3 o7 A2 {Copper Clad Steel Conductor 包铜钢丝
+ q* h* D# x/ z; R( O/ fCopper Clad Steel Wire 铜包钢线
! b* |" d7 J3 dCopper Coated Mild Steel Wire 镀铜软钢丝4 X7 G2 k$ t( E, U0 ~
Copper Coated Stainless Steel Wire 镀铜不锈钢丝
6 \4 g1 ^. v5 jCopper Containing Steel 含铜钢+ X! U9 l9 B$ B  C3 j& l
Copper Covered Steel Conductor 铜包钢线
* R+ G' q6 j2 F, VCopper Plated Steel 镀铜钢板2 y- `3 @! W: X' g
H Steel 宽缘工字钢$ j( P' q: d' p3 i
Hadfield Manganese Steel 哈德菲尔德锰钢, j0 b6 ]/ T, T/ X
Hadfield Steel 哈德菲尔德高锰钢; 哈特非钢; 奥氏体高锰钢; H" b- s, U& ~. z5 Y
Hadifield Steel 高锰钢8 Q2 c9 V- R9 U3 w+ g. Z. @0 D
Half Spherical Steel Bobbin 半圆形钢质滚轮
# y. n; O/ G2 P$ X6 a/ F6 LHalf Steel 钢性生铁
8 K0 k0 `1 `) [8 K3 E4 _2 XHalf-Hard Steel 半硬钢/ u6 q! k/ Q) l3 j0 v& t
Halvan Tool Steel 铬钒系工具钢
4 U4 a4 E4 f3 t' K( i$ FHammered Steel 锻钢
, M" S: D- H+ A, D+ [6 d& VHand Drill Steel 手持式钢钎3 U6 ]# b! ?2 w: E
Hand Steel Snap 手用钢铆钉模1 Z6 w" \; {; m- d
Hard Alloy Steel 硬合金钢; 硬质合金钢
8 s5 {1 ^# K4 w: ~9 ^, d; \! OHard Steel 硬钢) H# T0 F. p7 I$ @" @: C3 t
Hard-Drawn Steel Wire 硬拉钢丝4 X5 r6 a+ ?0 {2 u3 j
Hardened And Tempered Steel 调质钢
2 J8 q. E7 y5 q; B( l1 @Hardened Steel 硬化钢; 淬火钢7 V- R& N. L" ^; p
Hardened Steel Roller 淬火钢滚轮: w$ B$ u4 H9 N4 v$ M, E! a# a& }* K
Hardened-Steel Bushing 淬火钢衬套
) w) }2 k, Q& c9 ~4 E- `( A0 DHardened-Steel Guideway 淬火钢导轨! O% A1 J& v9 S. A/ \5 e* s
Hardened-Steel Tire 硬化钢环箍* O1 e. h+ [0 j% Z; `. U
Hardening Of Steel 钢的硬化3 |6 A7 B" m. K5 \; l$ M# |* O& X
Harvey Steel 固体渗碳硬化钢
3 r: Z9 a- m" T' M6 tHeat And Corrosion Resistant Steel 耐热防锈钢8 |; u1 W$ M' `  |
Heat Treatment Of Steel 钢的热处理' t$ M! i* F8 @. a+ `& D( R# X7 P  e
Heat-Resistant Steel 耐热钢' A( q! J/ p& S1 e
Heat-Resisting Alloy Steel 耐热合金钢, T! _7 K% U" X7 p+ C
Heat-Resisting Steel 耐热钢; 热强钢1 ]$ ]& S. M4 p& h
Heat-Treatable Steel 热处理钢, o! C1 K4 @8 d+ [& D
Heat-Treated Steel 热处理钢
! Z8 _  f! P* X$ u2 zHeat-Treated Steel Track 热处理钢履带
' i8 r) g" B9 ~1 a% GHeavy Section Steel 大型型钢2 l5 j0 g% ~9 A5 L1 u
Heavy Steel Rolling Mill 大型轧钢厂4 C8 Y" Q% M4 ]6 a! Z( W3 U
Helical Steel Support 螺旋形井筒支架
* B7 i2 K: ~! c5 QHexagon Bar Steel 六角条钢8 m" t+ d1 w5 @$ T1 l2 z
Hexagonal Steel Bar 六角形钢筋! E0 Z4 {9 S& P  }" T. X+ \" y9 N, g
Hi-Stren Steel 低合金高强度钢% v+ _! E  b, _; o- x7 a1 y+ F
High Alloy Steel 高质合金钢
* s+ o) }9 L6 G8 x3 {  e; q% qHigh Angle Smooth Bottom Steel Bench Plane 高角平底钢刨
" P, u. o/ v% z: w9 cHigh Boron Steel 高硼钢
% q# _9 a* |$ I' Q: k/ ^High Carbon Steel 高碳钢8 \/ {) |2 {) e
High Chrome Alloy Steel 高铬合金钢
' f: s. o7 x1 w2 W1 ]High Chrome Steel 高铬钢; 高铬钢
6 F5 I! P# i; O0 y4 ]; MHigh Chromium Steel 高铬钢' N* h1 W3 i: _1 A- k
High Frequency Steel Furnace 高频炼钢炉; }% b8 N" I2 c4 l' X8 ?
High Manganese Carbon Steel 高锰碳钢
5 C, @- ^" s. ~: w$ u# M5 AHigh Manganese Cast Steel 高锰铸钢
/ w+ `4 N  B! l! ]7 }/ B% cHigh Manganese Stainless Steel 高锰不锈钢
0 b9 ^- Y0 L# u$ Q3 L$ ~High Manganese Steel 高锰钢
# d* @) |1 [/ w0 I9 ]4 O  `1 uHigh Manganese Steel Casting 高锰钢铸件
+ H" J  G$ T5 ~+ q" J! p0 F/ _0 ?High Manganese Steel Frog 高锰钢辙叉
6 h7 n; w4 f  K0 i# u/ q- [' V) B1 SHigh Manganese Steel Rail And Guard Rail 高锰钢辙叉及护轨/ A3 q1 X5 j0 e
High Nickel Steel 高镍钢; 高镍合金钢5 Z5 d; d) w3 x
High Nickel-Chrome Steel 高镍铬钢- X4 W( {4 J" O: v" c# q7 s
High Pressure Stainless Steel Hose 高压不锈钢软管. u2 Z& ^4 {) ~& J5 F
High Quality Steel 高级钢
0 k3 Q) x5 E% m( t$ UHigh Speed Steel Bit 高速钢钻头
7 ?# m- s, o0 G) E2 i3 ?4 g; kHigh Speed Steel Cutter 高速钢刀具
) z  f* Q& j% N$ J  ]High Speed Steel Ground Tap 高速钢磨削丝锥0 s. H0 b5 o" u/ l) j
High Speed Steel Lathe Tool 高速钢车刀! \4 N+ M/ D3 u: H  M$ @
High Speed Steel Power Hacksaw Blade 高速钢机用锯条0 R# \; ~# s1 j3 v
High Speed Steel Tool Bit 高速钢刀具
( ^" Z( ~& f/ w2 a" `High Speed Steel Turning Tool 高速钢车刀! d' r2 L9 G" c6 b. Z) b+ Y! i+ z
High Speed Steel Twist Drill 高速钢麻花钻
+ A4 o( x' ^9 t9 `; X! i2 @High Speed Steel Wire 高速钢丝
) b, e6 r( F( G! `5 X! \! `High Steel 高碳钢; 硬钢- E# D- ~- U/ [3 F+ F0 x. R& [
High Strength Alloy Steel Shackle 高强度合金钢锁扣4 I7 }  X3 ^( f
High Strength Bevel Steel Washer 高强度钢斜垫圈8 Y+ F0 f7 |* u
High Strength Construction Steel 高强结构钢
$ K' K. q- y# d3 @  }High Strength Hull Steel 高强度船体结构钢& [1 C$ P) U6 k' \' V
High Strength Low Alloy Steel 高强度低合金钢; 低合金高强度钢, U( P, c$ c1 ]+ {3 q  X
High Strength Plain Steel Washer 高强度平钢垫圈
- z3 E3 h+ e7 A9 l& L9 xHigh Strength Steel 高强度钢材
% H6 @7 A5 l4 v/ i  V# jHigh Strength Steel Bar 高强钢筋& E3 e6 f0 U/ f: L1 h: i2 V
High Strength Steel Plate 高强钢板& U+ y$ h8 q4 N" h
High Strength Steel Washer 高强度钢垫圈0 D0 x7 X4 S6 z2 J
High Strength Structural Steel 高强度结构钢
9 \$ W7 `$ d2 MHigh Tensile Deformed Steel Bar 高拉力异形钢筋
! _' z; A$ @) y2 @High Tensile Reinforing Steel 高强钢筋
0 s" q( O! w8 X5 k1 Z6 x9 [% K  JHigh Tensile Steel 高强度钢; 高级钢
  X3 L: q- f  z9 d3 e% BHigh Tensile Steel Plate 高强钢板% `' J2 u& @* D' G3 E4 E
High Tensile Steel Tube 高强度钢管* Q, X( V& ^: R5 Z9 Q& J
High Tensile Steel Wire 高强钢丝
( N0 E& I# l2 YHigh Tensile Thin Steel Plate 高强薄钢板, W) E7 k& @) v3 y  F7 r9 ~
High Yield Stress Steel 高屈服强度钢, t: S9 }2 P  B% u; m
High-Alloy Steel 高合金钢8 ]" v. w1 e3 G
High-Alloy Steel Vessel 高合金钢容器
# m4 _9 G. x4 ~  I" h2 ?. I! MHigh-Carbon Alloy Steel 高碳合金钢
' w- R% X0 b& b, N. r) sHigh-Carbon Chromium Steel 高碳铬钢7 r, |. P/ ]; r. Q% q4 H
High-Carbon High-Tensile Steel 高碳高张力钢
3 D6 [6 g. [( iHigh-Carbon High-Tensile Steel Wire 高碳高张力钢线" J2 B% e/ E- \$ g9 o
High-Carbon Steel 高碳钢
; U$ P4 ^" M( A7 d  w* ZHigh-Carbon Steel Heat Treated 热处理过的高碳钢
' F/ P$ M1 ]% c' A! C; W4 p% |High-Chromium Stainless Steel 高铬不锈钢
, o, h" f  X+ p0 aHigh-Creep Strength Steel 高蠕变强度钢
& L3 f  O5 U& d( nHigh-Ductility Steel 高韧性钢; 高塑性钢
+ ]7 Y% u9 o9 p: l% o7 h% KHigh-Duty Steel 高强度钢
% D1 c1 p4 b+ I! oHigh-Elastic Limit Steel 高弹性极限钢; 高弹性限度钢; @/ b% K+ [+ Y3 x4 [  H
High-Frequency Electric Welded Steel Pipe 高频电焊钢管( W. A% r: o$ ^0 h: `4 r* S
High-Frequency Transformer Silicon Steel Sheet 高频变压器硅钢片
3 r) J) W6 P/ G# x0 I- kHigh-Grade Alloy Steel 高级合金钢1 t2 h0 f+ g# }. Q( ]
High-Grade Alloy Structure Steel 高级合金结构; 高级合金结构钢
0 u, q4 J% t" B8 {9 Q8 s( `High-Grade Carbon Steel 高级碳素钢
# T8 [- p1 `0 T* v0 \) r) X0 LHigh-Grade Steel 高级钢
4 H4 M0 T- X* c. Y+ kHigh-Quality Nickel Steel Tube 高级镍钢管$ N3 {! G" S& E2 K9 [
High-Quality Steel 高质量钢; 优质钢
, C  h4 o6 j) ]$ J$ JHigh-Speed Steel 高速钢; 高速工具钢
, \: @, t/ f* _) q2 A+ l, P$ aHigh-Speed Steel Bit 高速钢车刀
9 F; Q3 M/ I1 P8 PHigh-Speed Steel Drill 高速钢钻头, o% O' D/ f1 [& v
High-Speed Steel End Mill 高速钢端铣刀
8 @" B! b4 _) }# _" r1 {( J5 K4 I. fHigh-Speed Steel Geared Tap 高速钢磨牙丝锥8 e5 s: G# e9 X& |! P
High-Speed Steel Ingot 高速钢锭+ @% H6 X% c* G- `8 o3 f  z
High-Speed Steel Lathe Tool 白钢车刀; V, t' |; q) ?
High-Speed Steel Tool 高速钢刀具
% k, ?+ G7 m4 dHigh-Speed Tool Steel 高速工具钢; 高工钢
% i% P8 C6 h5 Y. UHigh-Strength Bevel Steel Washer 高强度斜垫圈
- S5 E& I# z: o5 n, IHigh-Strength Cast Steel 高速铸铁' l! N) U& i9 O1 z" E0 \
High-Strength Low Alloy Steel 高强低合金钢4 h: j$ Q6 {$ W8 Q4 V
High-Strength Low-Allow Steel 高强度耐低温钢
2 U/ v, Q0 @! u' \  z2 A7 DHigh-Strength Plain Steel Washer 高强度平垫圈
* E9 f* e$ {( t, I5 PHigh-Strength Quality Steel Wire 高强优质钢丝
4 k0 H7 g1 L, @! l( YHigh-Strength Steel 高强度钢
4 h$ W& g& C, b* U; f* J' ?9 O' hHigh-Strength Steel Electrode 高强度钢焊条4 d$ e* h4 Z' p! [
High-Strength Steel Washer 高强度垫圈
1 _/ V8 s# P4 m1 k! x9 g% ?High-Sulfur Steel 高硫钢: u! x4 q2 g+ I- b! _- E
High-Temper Steel 高温回火钢- U" F+ {2 F: R
High-Temperature Steel 耐高温钢* `$ B) D; [! o" r3 j* ?& t
High-Tensile Steel 高强度钢; 高强钢$ g& }  g5 P, D; F
High-Tensile Steel Bar 高强度钢筋
  D: h; i9 @- pHigh-Tensile Steel Bars 高强度粗钢筋! p5 A6 E$ I( n, Y
High-Tensile Steel Reinforcement Bar Fixture 高强钢筋夹具
* L( L; g% p9 OHigh-Tensile Steel Wires 高强度钢丝
5 }( C: n+ P1 f) BHigh-Tensile Structural Steel 高强度结构钢7 [% I8 G  S+ B  B
High-Vanadium Steel 高矾钢; 高钒钢: _- m' s9 g* B. f& l: q0 O* _. v
High-Yield Strength Steel 高屈服点钢; 高屈服强度钢
# H2 q5 \# j9 `- J  Y. ~Highyield Low-Alloy Steel 高强度低合金钢' U" ^+ B: L- X$ _+ J
Hoe Steel 中耕机锄铲9 H# {" G2 ^7 }, i8 r
Hole Steel Propeller 钢制空心螺旋桨) \8 l& K) A2 Y9 E% j! z
Hollow Drill Steel 中空钻探钢
4 h" O" ]1 H* o1 {6 nHollow Square Steel 空心方钢7 N* N7 P$ q! m9 v2 B
Hollow Steel 空心钢; 中空钢* U/ p4 a6 Z) X$ ^5 `# @5 N- L
Hollow Steel Propeller 中空钢制螺旋桨5 G) @  `/ ^$ `7 {3 t+ F! I
Hollow Steel Rim 空心轮辋5 B; D% B. h% g  h( j
Hollow Steel Roller 空心钢辊( N7 c5 P: e8 @. D6 ?) G' E$ R
Hollow Steel Section 薄壁型钢5 M% p% w9 o( N4 E: g
Hollow Steel Spoke Wheel 空心钢辐轮# g3 t* n/ K  v! k6 p9 y$ H
Hollow-Drill Steel 空心钻杆. Y: E5 p6 ~! |$ @3 B/ i0 i
Homogeneous Steel 均质钢; 均质钢
. D& n0 q+ k& x2 DHomogeneous Steel Plate 均质钢板; 均质钢板1 W! u, M% r! h: u
Honda Steel 本多磁钢
# N" `" I7 Z" j+ r  Q4 WHoop Steel 箍钢带
7 g9 |( ^: H. CHot Die Steel 热锻模钢; 热作模具钢
) t/ D& r0 G+ i/ O, c  N! _: BHot Work Tool Steel 热镀模具钢; 热锻模具钢
7 K% J" |0 v/ i0 b; ^- JHot-Die Steel 热变形模具钢; 高温模具钢
# p* ^2 g  C% v; ?7 J  E6 B# v* H9 \4 \Hot-Dip Galvanized Steel Wire 热镀锌钢丝
" a6 c  J6 V, Y$ KHot-Dipped Galvanized Sheet Steel 热浴镀锌薄板钢材0 ]$ W& Y" Z% U+ [
Hot-Rolled Mild Steel 热轧软钢% R! I) t9 _  [  E/ \+ B
Hot-Rolled Sheet Steel 热轧钢板, b% ^4 j: u6 K+ y( \/ o7 X* D
Hot-Rolled Sillcon Steel Sheet 热轧硅钢板
- F* Z! K' y- A8 {* [. y( DHot-Rolled Steel 热轧钢- ~3 c/ O: y2 E0 G) z; Z
Hot-Rolled Steel Bar 热轧钢筋3 n0 t! ^$ p/ Y% l) S' f7 Y/ W
Hot-Rolled Steel Channel 热轧槽钢  N/ g) m+ ?$ U5 n3 e8 e
Hot-Rolled Steel Joist 热轧钢龙骨
; L: ]; j2 h* ]& L9 FHot-Rolled Steel Section 热轧型钢
/ V. v% S( {) R+ D, RHot-Working Die Steel 热锻模钢" z7 x5 W: m2 F( G% @
Hubbing Steel 冲模钢5 `+ Z& m) q( Q/ }4 A
Hull Steel 船用钢; 造船钢: t! j6 y+ R) v0 w3 ?! r8 n, C
Hy-Tuf Steel 海图夫低合金高强度钢+ @4 I% M( P/ |. P5 l5 I* t- n, E
Hydra Steel 海德拉热模具钢
: ?/ T; t  L! j. N5 ?) a$ ~+ NHydraulic Steel Holder 液压持纤器
1 O3 a" t% P. lHydraulic Steel Support 液压钢支架0 T- U5 c, w. e' F
Hynack Steel Plate 海纳克护膜耐蚀钢板9 M0 |: y- Y6 w0 X8 s
Hypereutectoid Steel 过共析钢; 超共析钢
: e; v5 w1 ]: rHypoeutectoid Steel 亚共析钢* s; P9 ^' _0 I5 H9 R: h
Hysteresis Steel 磁滞钢* V. o4 L0 E. L7 d. q  I4 G
I-Section Steel Pile 工字型钢桩8 @3 ?4 Z4 }* B4 ^
I-Steel 工字形钢; 窄边工字钢& h( l: c8 i; t# r$ K- R
I-Steel Pile 工字型钢桩
5 k  U. f1 P5 L# f! a! e+ F9 {Inclusion In Steel 钢内夹杂
4 w3 I8 b6 w1 D" oIndented Steel Wire 齿纹钢丝2 {* M+ s% i5 ^( l
Industrial Steel Window 工业厂房钢窗
) D& T! w  E+ _. Y  W1 N7 OIngot Steel 钢锭; 锭钢" F$ V# r. E2 a& S* |$ Y" o
Inland Steel (美国) 内陆钢铁公司+ `7 l4 |) V: I4 a% q5 L* @
Instrument For Measuring Oxygen In Molten Steel 钢液定氧仪
& C  `3 k+ y- k2 n! FIntegral (Drill) Steel 整体钢钎
6 t5 O4 E+ }& E+ F2 CIntegral Steel 整体钢钎
" v4 V" E8 p# U" JIntegrated Iron And Steel Works 综合性钢铁厂* Z! L( y2 q8 i& c: G/ {
Intermediate Grade Steel 中级钢
! }* O0 D9 k$ r' [2 ^% JInternal Fixation With Steel Plate 钢板内固定术
' W: V4 h9 L) p/ t  i4 fInvar Steel 殷钢
+ a/ {$ {) S/ P/ N* ^0 p4 YIron And Steel Base 钢铁基地
6 B, V* T; D7 I3 ]Iron And Steel Casting 钢铁铸件
# s' s9 Z1 D$ HIron And Steel Company 钢铁公司0 `% p" L  Y7 t5 k- ^- {
Iron And Steel Industry 钢铁工业
; R8 S' y- J6 l5 A' nIron And Steel Manufacture 钢铁制造' ~9 J: \0 C% E
Iron And Steel Material Shaped 钢铁型材
. q4 L$ g$ V+ x- [: FIron And Steel Plant 钢铁厂0 o) ?, q. D6 V/ S
Iron And Steel Scrap 废钢铁
9 g# ]+ l% V+ r: n( W7 a5 F4 e) }7 lIron And Steel Sheet And Plate 钢铁板材* d$ l, p( E, p5 Y- i, Q- G
Iron And Steel Sheet Piling 铁及钢板桩法凿井! |$ a# @. Y5 v3 p% z7 i5 A, g; O
Iron And Steel Wire 钢铁丝材
; h* O. t6 K# P4 |6 {% I: ~! qIron And Steel Works 钢铁厂
/ B+ d9 T+ s5 C; j1 p5 qIron-And-Steel Furnace 黑色金属冶金炉" e. o: B' N+ F; }# |* i
Irreversible Steel 不可逆钢
. }# S: S1 z) a9 f+ w) ]Joist Steel 梁钢- z( ~2 L: U9 \+ Y) C
Joy Extensible Steel Band 乔伊可伸缩式钢带运输机
6 x' _9 n/ \, q$ e  u1 u1 MJumper Steel 钻杆钢; 长凿钢2 ^! _: x4 P0 S  u
Jute-Covered Steel Pipe 包黄麻钢管+ ], `" \  r# r( V( c
Killed Carbon Steel (KCS) 镇静碳钢
. \# c' j4 P  c2 P2 t8 RKilled Steel 镇静钢$ T+ Q. |- E  V" w4 g6 f/ y
Killed Steel (去氧钢) 脱氧钢
7 [5 t* x) g  F; n) w; PKrupp Austenite Steel 奥氏体铬镍合金钢
3 r2 {: J( W) ?2 s7 a3 w* {Krupp Triple Steel 克鲁普铬钼钒高速钢
1 r% C, N- Z) f* LL.P.N. Steel 低氮碱性底吹转炉钢0 T, c& g1 A. a+ p
Lacquer-Coated Steel Sheet 涂漆薄钢板
$ E% Z* K) s7 s/ M: \Lead Bearing Steel 含铅钢  I% n* M- t; Z# l% i
Lead Treated Steel 含铅易切削钢" }; @6 }0 G2 _/ ]" k0 c
Lead-Coated Steel Plate 镀铅钢板
% M8 c* Z3 M: |; aLead-Sheathed Steel-Taped 铅包钢带
! a7 E' @& w4 k7 qLeaded Low-Phosphorus Steel 含铅低磷钢
( j. m: l. j8 p4 T9 ?% NLean Alloy Steel 低合金钢$ O& L% H* y1 s0 E
Ledloy Free Cutting Steel 加铅易切削钢
1 n# m* {% m/ c# e. v& i9 wLight Channed Steel 轻型槽钢
9 h6 Q7 n4 o) p* `Light Gauge Steel 轻量型钢
7 Y: F2 y4 \( ?# Q6 M" ALight Weight Steel Shape 轻型钢材
0 o- g. t/ |! {6 {* C4 HLight-Gauge Steel Section 薄壁型钢5 M- k# u& k$ l; _0 a0 `
Light-Weight Angle Steel 轻型角钢
6 E2 h# J+ T% E. L5 GLightgage Steel Joist 轻钢龙骨$ |) S8 w7 h2 y' F
Lightweight Steel Construction 轻钢结构
( U3 f: c6 h) l! J2 |/ j6 LLightweight Steel Shape 冷弯型钢
. t6 X& ^: |" P: `( D* }, VLip Hat Section Steel 带缘帽型钢0 u4 v2 s% A! a3 g6 D3 y
Lip Z Steel 带缘Z型钢2 ]# l6 C7 j8 R) }4 I9 l
Liquid Steel 钢水
; h1 ?. @2 N5 yLiquid-Compressed Steel 液态挤压钢; 加压凝固钢  H$ d' K! R( y) ]$ p# y0 a
Little Bessemer Steel 小型酸性转炉钢
: f: ^9 B+ H0 c+ p; G' ~- HLock Bar Steel Pipe 箍锚钢管
# E! m7 @/ Q( e  [2 GLocking Steel Wire 锁紧钢丝
! Q- _# A3 Z9 Y( u5 xLong Steel Tape 钢卷尺
5 N9 _/ `+ y; ^) p, o% Y0 N4 nLong Steel Wire Saw 长钢丝锯
% {' y8 m6 ^2 ]1 o0 \Long-Span Steel Framing 大跨钢构架
/ n" E  |$ L  A' m3 Z# PLow Alloy Steel 低合金钢6 v- x9 V! L" G
Low Alloy Steel High Side Wagon 低合金钢敞车
9 n2 y: b; ~. n1 ?+ {+ rLow Alloy Steel Plate 低合金钢板
) n6 Q0 T! k! b1 X& B2 WLow Alloy Tool Steel 低合金工具钢6 v4 c5 a* l* ]4 y+ M
Low Alloyed Steel 低合金钢
& p, Q# e* u% u. I5 pLow Carbon Steel 低碳钢( p5 j5 p1 N( R/ o3 ~' v8 n
Low Carbon Steel Electrode
 楼主| 发表于 2007-9-2 08:40:39 | 显示全部楼层 来自: 中国广东深圳
Rail And Structural Steel Mill 钢轨及钢梁轧机$ T+ V& j0 ^* ^$ s$ \  H
Rail And-Structural Steel Mill 轨梁轧机( T: k6 }" E, {8 x( Z  H2 b
Rail Of Self-Hardening Steel 自淬硬钢钢轨
# i! l, I2 E2 {" O) ERail Steel 钢轨钢; 轨钢8 ^7 |" H6 r9 H# k
Railing Of Stainless Steel Tubes 不锈钢管栏杆/ l8 L. v5 y! F5 [* j
Rapid Steel 高速钢
8 P! |7 r. ^& H: \/ H! gRapid Steel Tool 高速钢工具% N% R) T' x% E' f. ]
Rapid Tool Steel 高速工具钢
' {/ {$ z( {+ J1 k! j: a7 u5 a  ~Raw Steel 原钢; 粗钢0 ^, D) y+ x* s1 x1 A3 i
Quenched Steel 淬硬钢
. U- }/ j3 Y0 Y# q0 u& s0 bFile Steel Brush 钢丝刷
2 x4 e9 X1 w0 K. l% PRectangle Steel 矩形截面钢板; 矩形截面钢板
& J, Z. N! T1 `6 ^/ z5 JRectangular Bar Of Steel 长方形钢
+ |0 X8 O: F# ]8 w) G& f- \/ G% vRed Hard Steel 红硬钢
0 `, e: l; f! z' ARed Painted Steel Pipe 红油涂面钢管
4 E. ^: e, O1 W; U- c' fRed-Hard Steel 热硬钢; 高速工具钢6 C4 D- _5 G4 X$ y
Red-Short Steel 热脆钢. n$ D5 C: s& ~2 k4 R
Flat Steel Heald 钢片综& s! {3 r( w$ \+ e7 ]& ]( k
Refined Steel 精炼钢# Z! z& y, F  K/ J0 @
Flat Steel Lawn Rake 草地扁钢耙
$ {+ w) f9 V; |: B  w" BRegular Smooth Bottom Steel Bench Plane 普通平底钢刨
& F$ v  s; `* C# ~3 C1 lRegular Soft-Center Steel 正心软心钢+ r) w" q; I1 c0 v/ S& ]+ K
Reinforcing Steel 钢筋
6 S" ]0 S7 q: H9 F$ s' rReinforcing Steel Adjusting Cutter 钢筋调直切断机
0 l" J2 ^& H. ^) o$ g0 _+ ^Reinforcing Steel Area 钢筋截面积; 钢筋截面面积: S8 z  @2 B% B- d3 q
Reinforcing Steel Crooking Machine 钢筋弯曲机( @9 e* h$ ?5 m4 k7 \
Reinforcing Steel Cutter 钢筋切断机
8 s8 z$ F+ ?0 p" p% N2 aReinforcing Steel Reinforcement 钢筋$ h* V3 m0 A+ J- l4 m9 X
Relaxation Of Steel 钢筋松弛9 L( s9 I6 a! O* a- ~; Y7 D) ^
Rephosphorised Steel 回磷钢
- X& S; Q4 t" `; x- dRerolled Steel 半成品钢
' Q! J9 W3 {% A6 IRerolling Steel 半成品钢
  g# s- I( b" W6 E7 lRetractable Steel Joist 伸缩式钢梁; 可缩钢梁$ P3 Y. ^. H. ~% F- k: w& x
Retractable Steel Rule 钢卷尺
& d7 l+ `. m+ D5 d% f' g3 m* gReversible Steel 双尖松土锄铲
6 f- J7 a8 D6 k- p! f% N% OAcid Electric Steel 酸性电炉钢/ t; |3 U9 S" A; v4 T8 k4 P; m
Ribbon Steel 窄带钢" ^; Z2 B, ~" u
Rich Chromium Ball Bearing Steel Wire 高铬轴承钢丝
( ]) q8 i4 r4 X  K4 jAcid Open Hearth Steel 酸性平炉钢; J" z: Y( p- v/ H
Acid Open-Hearth Steel 酸性马丁炉钢! e6 }: d) {6 k4 b
Acid Steel 酸性炉钢# T6 L. {: [& W  r8 M" y/ q+ w, `& J
Rimmed Steel Sheet 沸腾钢板" c+ k0 x" Q. V
Rimming Steel 沸腾钢
; i% D* n4 W3 j) f/ h* h) r5 K3 uRising Steel 沸腾钢/ p# O+ a5 J1 f+ T) j
Rivet Steel 铆钉钢
- `5 f4 @8 m1 HRiveted Steel 铆结钢3 q+ M6 A  x0 t- o
Riveted Steel Pipe 铆接钢管( ], Z' R8 d6 H
Rock Drill Steel 凿岩钎钢3 w0 r3 t3 N* m
Rock-Drill Steel 钎子钢
% j+ l5 a4 [4 W8 k; iRolled Sheet Steel 辊压钢板
$ n7 m* i/ N. {1 v) |" x7 `Rolled Steel 轧制的钢材; 轧制钢; 钢材
/ z* C0 t# q& e1 ~3 HRolled Steel Beam 辊压钢梁
2 U& f5 f, [  lRolled Steel Channel 轧制的槽钢
' e5 m% `3 k: W" ^+ @% _Rolled Steel For General Structure 一般结构用轧制钢材
- L9 z1 {# {, N9 W1 p5 |1 dRolled Steel For Welded Structure 焊接结构用轧制钢材
6 V8 Q( G, Y' m8 F: xRolled Steel Products 钢材
. W) I4 T6 q5 W8 XRolled Steel Wire 盘条6 H1 o; p3 K" f3 F3 x, w* Q
Roller Bearing Steel 滚柱轴承钢  ]3 a6 C" R0 _* Q4 i  Q2 f
Roller Blind Of Steel 钢制滑轮百叶窗
! w' K' P* I# q6 W5 KRotating Stainless Steel Cage (浸出用) 回转不锈钢笼; m1 p8 E5 r" q) r7 a
Round Steel 圆钢
* M0 b0 Y+ T/ mRound Steel Bar 圆钢筋2 O- ]6 }# ^! u& M
Round Steel Fork 圆钢叉子
6 n" ]  H6 m. ~& x6 MRound Steel Wire 圆钢丝" I2 I. |- u& g9 v1 B5 ~6 v
Round-Edged Steel Flat 圆边扁钢4 t- S6 C! E3 C1 H. t1 b5 S
Reacting Steel 再结晶钢
6 i* M6 M1 N4 i- R9 O0 O+ TRazor Steel 剃刀钢; 刀片钢
4 m' @/ e# B  ^Rubber Lined Steel Sheel 衬橡胶钢制壳体+ F4 o* u% g1 _  h& [, W
Run Of Steel 钻杆长度! G. q0 K. r# C% x! F
Rust-Proof Steel 不锈钢, d) S; t- ]! ]4 ~' Z
Rust-Resisting Steel 不锈钢
7 L: l3 o* L( Q) V/ ]' u0 f6 JRustless Steel 不锈钢, |( a0 ~1 v" O4 }
Sandwich Steel 夹心钢
# y  w4 R( }6 E; HSaturated Steel 共析钢
+ P. R5 _3 b/ X6 G, {( A9 ySchedule Of Structural Steel 钢材一览表
; W% n+ ?  @4 vScorched Steel 粗晶钢; 柱状晶钢$ ^& x/ D7 [+ i7 H3 O
Scrap Steel 废钢; z* ^1 \( a# w. z8 i
Screw-Thread Steel 螺纹钢筋' Q1 ]) ]! t% ~% I# s* T9 T
Screwed Steel Conduit 螺头钢导管; 带螺纹的钢导线管1 @0 W. ]1 }5 f
Seamless Steel Pipe 无缝钢管
# t1 A, [: _* }) M! p$ B. ASeamless Steel Tube 无缝钢管; 无缝套筒
4 l7 N/ i! _* OSeamless Steel Tube For Drilling 钻探用无缝钢管, S1 M: ]4 R: o
Seamless Steel Tubing 无缝套筒% I$ m5 W' y" M9 D9 o. _
Second Steel Sheet 精整薄钢板. }' x0 \8 A. r4 }
Section Steel Rolling Mill 分类轧钢机
) A3 A& K4 M4 H% J8 b0 @; L: j+ SSectionalized Steel Form 组合式金属模板
# {  T  B" T9 W" \* ]2 OSelenium Stainless Steel 硒不锈钢
$ d6 D" i; A3 z; eSelenium Steel 加硒钢
+ V& K. X1 h7 a5 k) |1 `/ P3 `Self Hardening Steel 气硬钢" x+ a# {3 x6 o6 W9 R( m
Self-Climbing Steel-Form 自升式钢模
% X5 D5 G5 @. w3 ^1 }0 V% ^' D) [Self-Hardening Steel 自硬钢; 自淬硬钢; 气冷硬化钢; 空冷淬硬钢; 空气硬化钢$ M; [& S1 L! o5 A( [! l
Semi-Circular Sheet Steel Flume 半圆形钢板渡槽$ W/ u$ z, X! n/ Z, H
Semi-Deoxidized Steel 半脱氧钢" L' r8 ^: S4 Z8 L) p; `# Z
Semi-Finished Steel 半制钢$ V& F% ?& C  t$ R  t5 r
Semi-Hard Steel 半硬钢
+ U% V4 b$ a2 F' w$ n7 jSemi-Stainless Steel 半不锈钢
" }8 C1 T# G- p0 ESemi-Steel 钢性铸铁; 高级铸铁
: C' T0 w' e  m! WSemi-Steel Casting 半钢性铸铁件
+ t- q) @  Y) QSemikilled Steel 半镇静钢& `, S; t7 T% Z  X& d, @3 ]
Semirimming Steel 半镇静钢4 B+ j* |8 {2 c  _& _! O
Semisoft Steel 半软钢1 l. ]8 H! ~' z4 s
Shallow-Hardening Steel 低淬透性钢
) u" c* ~% o. _; L. H' d! \0 PSharpened Steel 锐钢钎
: x; Z* a4 _, ?& q7 J- k9 qShear Steel 刀剪钢; 高速切削钢
. z4 T7 l9 m7 z- [2 G7 XShear-Steel 刃钢; 剪钢; 剪切钢
- d7 j' b3 \5 k7 SSheet Steel 薄钢板; 钢皮; 钢片; 钢片# {" o3 m- N6 w1 P$ P) Q& D
Sheet Steel Enamel 钢片搪瓷
# O9 W1 [; a1 r% M# ySheet Steel Flume 钢板渡槽( _* p' e+ Q  Y3 b
Sheet Steel Form 钢模板
8 M) t, U7 r4 t6 J* gSheet Steel Mill 薄钢板厂5 F0 H5 m3 T5 }0 R' b# h
Sheet Steel Pipe 薄钢管) W4 p% J: D  o, r& t5 {- g  x
Sheet Steel Rolling Mill 薄钢板压延机
, D4 w& Y. i  u# b5 u9 d, uSheet Steel Straightening Unit 薄钢板矫平机
' {  E/ s3 q) t0 r7 v& @5 eShipS Steel Side Scuttle 钢质舷窗
8 c/ @  Q% u6 R. x$ U. Y0 _ShipS Steel Weather Tight Door 船用钢质风雨密门2 `! p" W4 k. `- q
Shock Absorber Link Rod Pin Steel Bushing 减震器拉杆销钢套
" j( D* e6 w$ J9 {  eSi-Steel 硅钢
  G5 E4 y9 A  |4 o0 {Si-Steel Strip 硅钢带+ t; s7 i' k! x8 Z8 \+ A+ @
Sichromal Steel 铝铬硅合金钢; 铬铝硅合金钢4 F6 X$ ~! X& W" [$ V
Side-Blown Basic Bessemer Steel 侧吹碱性转炉钢
, [0 R  a& y& @7 MSiemens Steel 西门子平炉钢) X$ T5 W0 B! R  J* n1 P9 E, s
Siemens-Martin Steel 平炉钢5 w$ t1 u' _4 y, F$ h" \3 q9 {. p
Silco-Manganese Steel 硅锰钢
3 u) l) g6 O' }( G. pSilichrome Steel 硅铬钢) _" @+ \& b1 T1 n
Silicium Steel 硅钢, V1 E. h! U# F* O2 P
Silico-Mangan Steel 硅锰钢
! z. f$ J' @2 u0 e1 `+ ?+ hSilicon Chrome-Steel 硅铬钢8 k1 q+ u3 H, t
Silicon Steel 硅钢
8 P! X: [$ ]  C' y- `! RSilicon-Chromium Steel 硅铬钢6 w. X) p! E9 t6 k$ K
Silicon-Steel Plate 硅钢片% v5 V- n- M0 d3 A6 _4 ]# [2 F
Silicon-Steel Sheet 硅钢片4 k, e! b5 Y2 b( v" e5 y6 ]8 |
Silver Ply Steel 不锈覆盖钢: f+ F' P! _$ t0 B0 w
Silver Steel 银亮钢; 银器钢
2 P' G" d( P+ ]* s7 w7 GSilver Steel Wire 银亮钢丝) V) w, ]1 O, J0 B9 M' a  t4 V
Simple Steel 碳钢; 普通钢- g+ l- H0 h( O3 Q* b. X4 ]
Single Steel Intrauterine Device 金属单环
5 u0 ~) D7 `' S' ~8 sSingle Steel Roller Cotton Stripper 单钢辊式摘棉铃机
* o* y( p8 l& h7 i5 X+ |Single-Skin Steel Dam 单层钢面板坝3 T  i+ P& {3 ^. H) ]- \
Single-Slag Steel 单渣钢5 Y, Y: ]( u0 c. W$ i
Sintered Stainless-Steel 烧结不锈钢
1 A8 `) n/ z8 V  [/ u8 w( ^! |Sintered Steel 烧结钢
/ ^9 G9 x" y2 z- E# {: b9 S. \( ASintered-Carbon Steel 烧结碳钢
) j& H6 O7 z) ?9 ]# B) o5 h3 hSkelp Steel 焊接管坯钢
0 z. V) C7 O& f5 eSkhl Steel 镍铬铜低合金钢* P+ t, u( C* R& Y
Ski With Steel Ski Pole 带钢撑棍的滑雪板
  f' J, y& Z9 X  |, K' HSkillet Cast Steel 坩埚铸钢4 R& F( Y3 }. @/ m
Sleeper Steel Mould 轨枕钢模7 C" n: U' ~3 O
Sliding Head Steel Bar Clamp 木工夹  X" E# R- x% T( z% ?
Sliding Shears For Steel Band 钢带滑动剪刀
( n, U8 L5 H/ TSmall Self-Contained Iron And Steel Complex 配套的小型钢铁联合企业: L* J3 |3 @  j; V- i! i1 T
Small Steel Shape 小型钢材( X9 H5 y; E6 H: V$ t
Smooth Steel Pipe 光面钢管4 J0 U/ n  G/ }! f! ?
Soft Center Steel 软心钢3 h* r! Y- ^- @( O0 k& a# H5 L
Soft Medium Carbon Steel 软中碳钢$ F" H" n! }6 ?$ i+ J* {  v
Soft Medium Structural Steel 软中碳结构钢9 u$ k. V" E" W4 |. l) o8 Q
Soft Steel 软钢; 低碳钢5 y3 f6 G" H5 U& v! n9 U: P
Soft Steel Water-Jacket 软钢水套) [7 T5 s+ z6 H3 T
Soft Surface Steel Hammer 软面钢锤  }& ^  R' G; n6 U2 S7 ^0 c
Soft-Center Steel 夹心钢
( Y' S  {0 z" X0 bSoft-Center Steel Mo(U)Ldboard 软心钢犁壁. y2 S$ I( X! m7 G# H2 q$ Y, C+ y
Solid Steel 镇静钢; 脱氧钢
  T& N. a* W  A3 Z/ f0 kSolid-Drawn Steel Pipe 无缝钢管7 W/ U2 R3 W5 D) T" ]9 B
Space Frame Of Tubular Steel Sections 钢管空间构架
! S) V) T% ]" b7 z+ ASpecial Alloy Steel 特殊合金钢; 特种合金钢
$ y3 r+ \: n& ?Special Cross-Section Steel Wire 特殊断面的钢丝( |4 C% X$ N( M( l
Special Rolled-Steel Bar 异形钢
: G9 h" B# W% k7 }4 v( VSpecial Soft Steel 特软钢! S+ P/ ~7 a9 j/ o! j1 m
Special Steel 特殊钢; 特种钢3 V5 K, T5 y3 _! V% I; w3 m( H! o
Special Steel For Making Instruments 特殊仪表用钢
* {$ }4 d9 w, d6 g* L4 m5 KSpecial Steel Plate 特种钢板
/ }! C2 x8 B) d; O+ S& ASpecial Structural Steel 特种结构钢6 t; X& |& Y: H  ?6 O( R. K
Special Tool Steel 特殊工具钢; 特种工具钢
, j; h% e- K, E* ]Special Treatment Steel 特殊处理钢
; B0 t' X, l' y$ {& h. L4 X+ O) mSpent Steel Pickle Liquor 钢酸洗废液
8 n3 I+ {% {0 {0 e' U4 b7 o7 GSpheroidized Steel 球化处理钢- o% E  H5 G/ O3 z5 L: G% O
Spiral Steel Pipe 螺旋钢管5 I* |$ l1 Y! ^% m
Spiral Welded Steel Pipe 螺旋焊接钢管
( C, M7 e5 @, |( d0 }, JSpiral Welding Steel Pipe 螺焊钢管' G) y9 W9 l- w# U, ^2 }
Spotty Steel 白点钢
! U8 R- Q. L% d+ z5 h; ISpring Steel 弹簧钢. b  v: u0 T* x/ I: E* M* ]9 E
Spring Steel Band 弹簧钢带8 c# [' t# P: R' v5 Y2 z% n! Y
Spring Steel Wire 弹簧钢丝
0 B9 q5 F" H+ L, aSpring-Steel Floor Member 弹性钢底梁- G; S7 m( p$ q+ X2 c4 n- N
Spring-Steel Holder 弹簧持钎器
" X) o4 f+ p6 Q! H- {Spring-Steel Roof Member 弹性钢顶梁
2 J7 O& A* B0 [+ Y0 y" v& L- dSpring-Steel Shutter 弹簧钢活门3 I9 M! \8 o3 V  Y
Square Spring Steel 方弹簧钢
1 J4 U- L( ~7 d) k) L8 C2 v# [Square Steel 方钢
/ `5 D' k$ f. ^, O- L5 n! ~4 \/ Y- _4 [Square Steel Bar 方钢筋; 方钢条
. w) _7 `% K5 S% kStabilized Steel (Sheet) 稳定化钢板3 P- s* d3 ?& x9 J8 a9 f- E! \7 \
Stabilized Steel (经过加铝稳氮处理的低碳沸腾钢) 稳定化钢
& r4 f- R5 ^' x8 xStabilized Steel Sheet 稳定处理钢板% s" Z! x$ Q; @0 u6 `/ ^
Stainless Acid Resistant Steel 不锈耐酸钢  P  X. K4 U& X& X5 g% c
Stainless Acid-Resisting Steel Wire 不锈耐酸钢丝
4 ?# ]* A8 a3 i" ]( j3 ?0 sStainless Clad Steel 不锈复合钢
  R& o$ N9 M3 K/ v7 jStainless Compound Steel Plate 不锈复合钢板4 ~  P$ F) ~' }. p; @0 g& f
Stainless Sheet Steel 不锈钢薄板
! E# R% p. Z3 j# w" _Stainless Steel 不锈钢
" q$ c, C7 w( P% rStainless Steel Alcohol Stove 不锈钢酒精炉
1 z3 M- f2 b% N) x4 i3 BStainless Steel Alloy 不锈钢; 不锈钢合金+ ?5 @  y9 g3 u
Stainless Steel Angle Rule 不锈钢拐尺9 {6 ]- G) D% Q# E( h0 A
Stainless Steel Ball 不锈钢球' L* q( J1 ]& P  ]1 F/ f
Stainless Steel Ball Valve 不锈钢球阀
3 W9 w8 L, R5 U2 O9 fStainless Steel Band 不锈钢带
$ U5 f7 W* X4 _' qStainless Steel Basin And Plate 不锈钢盘碟
( l0 ?1 c0 N; d5 \% FStainless Steel Blank 不锈钢种板
, \) D1 R, x6 V- i" m& rStainless Steel Buckle 不锈钢扣
, {( J0 O9 C5 k! m, w/ X( nStainless Steel Burden Drum 不锈钢配料桶& N' n) C9 n1 W' q, s
Stainless Steel Case 不锈钢壳
& T$ k/ X7 }" [/ kStainless Steel Clasp 不锈钢丝卡环
* E& _! a" P* d( g6 W! YStainless Steel Cleaner 不锈钢清洗剂
8 @4 Z9 g  s# l. R( dStainless Steel Cloth 不锈钢丝网
" _4 q* E5 R, y2 \Stainless Steel Condenser 不锈钢冷凝器
# Y* t) {  h0 @0 j, tStainless Steel Condiment Pot 不锈钢调料罐
, A) Q8 |- c& JStainless Steel Corrosion-Resistant Needle Valve 不锈钢防腐针型阀
9 k1 M2 C! o" ~) V$ r% IStainless Steel Crucible 不锈钢坩埚. A+ t' P4 l/ C8 g9 p) k* z
Stainless Steel Disc 不锈钢盘7 w, G0 q6 a1 u+ B" R% r
Stainless Steel Disc For Casting 铸造用不锈钢块
' |1 `- ^; I9 S! l1 k5 ]* d% KStainless Steel Electrode 不锈钢焊条
, P. f- \1 d1 Q! t( n- tStainless Steel Enamel 不锈钢搪瓷) ?4 |# L3 D! `. `, ~5 i
Stainless Steel Fertillizer Belt 不锈钢撒肥带- @1 b2 ?$ }# H
Stainless Steel Fibre 不锈钢纤维3 M) h# b0 N3 H+ }8 G
Stainless Steel Filter 不锈钢过滤器
' Y8 c: [* w7 |+ P. |4 }/ e8 ]Stainless Steel Flag Hinge 不锈钢旗铰链
) _1 c( {  I7 h! M% lStainless Steel Flexible Hose 不锈钢软管
$ j7 Q, M! e9 A8 \1 AStainless Steel Grating 不锈钢滤栅
; w% B: Z; n; V6 Q7 aStainless Steel Heavy Duty Vernier Calipers 不锈钢重型游标卡尺
  Q% m0 {5 H. C( o) O5 Y0 UStainless Steel Helices 不锈钢填料% m% M9 p- m/ J
Stainless Steel Honeycomb Core 不锈钢蜂窝芯子) @2 N+ ]8 f" h
Stainless Steel Honeycomb Panel 不锈钢蜂窝板
# i. V! b1 k9 i( `6 [- j3 ?, {Stainless Steel Inside Calipers 不锈钢内卡钳: Y' {* f; y" a# S- K1 S
Stainless Steel Kettle 不锈钢锅
/ F8 p! P" K  V1 g5 r; ~8 R* oStainless Steel Kitchenware 不锈钢厨具5 J% K# K4 G+ L  t
Stainless Steel Mineral Spring Pump 不锈钢矿泉水泵1 l# X  C; Z8 _2 B. z& t* J
Stainless Steel Mother Blank 不锈钢母板
1 w' }5 s4 U* qStainless Steel Net-Cover Of Axial Fan 不锈钢轴流风机网罩* {3 B! H1 \# z1 e8 E9 ]$ N
Stainless Steel Nylon Hinge 不锈钢尼龙铰链/ s6 j* A& H& L4 \3 z9 n. Z3 J
Stainless Steel Nylon Ring Square Hinge 不锈钢尼龙垫圈方铰链
# F8 {. \7 p5 {. |0 p. ?Stainless Steel Outside Calipers 不锈钢外卡钳
0 j% W, j# m' Z7 ^3 GStainless Steel Palatal Bar Wire 不锈钢腭杆丝9 ?) F( H- |1 e
Stainless Steel Paper Holder 不锈钢纸托
' x' Z7 E+ H, s# W7 TStainless Steel Powder 不锈钢粉
8 _' M0 ]- ^8 x5 p7 h; ]Stainless Steel Products 不锈钢制品) `* i2 D1 M0 J# k
Stainless Steel Pump 不锈钢泵
  N5 a/ G% [( hStainless Steel Retainer Ring 不锈钢卡环
# h8 E" g5 U$ s9 K5 VStainless Steel Retort 不锈钢蒸馏罐0 N6 x5 I% G1 M" m7 d" n: ~: b+ L
Stainless Steel Rule 不锈钢直尺
2 }3 |7 o) s9 R+ \+ b& @Stainless Steel Ruler 不锈钢板尺$ @) `7 I' J+ [" K
Stainless Steel Screen 不锈钢屏; 不锈钢丝网
2 _) t/ w; i1 o) e6 AStainless Steel Seamless Thin-Wall Tube 不锈钢薄壁无缝管
; i: G$ e7 c" V: O9 sStainless Steel Square 不锈钢直角尺
& o) L3 C3 S- ]1 |. @4 JStainless S
) F/ z1 w+ X; L+ _Steel Mo(U)Lder's Paint 铸钢涂料
6 d) c) k" j6 B. K7 WSteel Mortar 钢研钵
% r+ l% b  R# o9 v  M# LSteel Motor Lifeboat 钢质机动救生艇0 a" Y! v7 F4 q  D; I( `+ L
Steel Mould 钢锭模; 钢模; B# D% G- t) p! `; {( ?
Steel Mould For Electric Pole 电杆钢模
; k5 n1 M  x0 [" V! WSteel Moulding Plate 钢模板9 f$ ^/ O% G, ]2 w0 f, P
Steel Movable Form 钢滑动模板8 C1 a7 j* w7 }. I* x
Steel Nail 钢钉
5 s/ V5 T# h9 U. rSteel Pad 钢安全臼
+ @! h5 K4 U2 x6 j$ F4 r/ bSteel Panel 钢护板' z$ _8 Y$ R8 l( Y
Steel Pattern Number 钢型号" M6 E) F- |% D: j0 w
Steel Perforating Rule 打孔用钢尺
# R$ ^4 U  b9 `# F4 VSteel Pick 钢镐
* L; a: Q: c8 ]; }, t% c4 aSteel Pick Head 镐头
& _$ @- \: b! _6 NSteel Pickling Operation 钢酸洗作业6 C: J+ Y2 y! u" G7 A  m; ]5 w7 K
Steel Pickling Waste Liquid 钢酸洗废液
4 l- e1 t. P9 n8 `! u: MSteel Picks And Mattock 钢镐6 s! m2 P* @- j2 ?+ `5 ]
Steel Pig 炼钢生铁+ m# C: J% T/ e9 u6 R6 G& \
Steel Pile 钢桩, B$ z" I+ [7 h0 Z% g. i/ Y; C- E) w
Steel Pile Type Dolphin 钢桩系船墩. ]" c: X2 W* V, \- i
Steel Pipe 钢管
$ s. F/ U1 k4 r* Y5 e" S. N+ j' ?Steel Pipe Clamp 钢制管卡8 A; T1 \/ V/ ~4 `5 F
Steel Pipe Column 钢管柱
1 V6 Q3 p" U8 E1 y) a$ ASteel Pipe Flange 钢管法兰
* q. t5 X) }0 m) FSteel Pipe Handrailing 钢管扶手$ `5 ~" B4 Z" Y) H) i/ b" Q
Steel Pipe Railing 钢管栏杆
/ u2 I% P% \) k  ?6 y4 I# |* fSteel Pipe Scaffold 钢管脚手架
# H5 ]2 V1 y9 u( @/ T. H; a/ QSteel Pipe Support 钢管支柱
+ i( b) l2 [# Z  m/ \, s& m% DSteel Piping 钢管
; Z& r7 v  Y5 O( l- d$ BSteel Pit 凹坑
! |$ k  T2 J) h7 ISteel Plain Splice 钢板平面拼接
# W$ ~- j7 A; W+ O6 wSteel Plane 钢刨
9 [3 @9 ~4 z7 q( Q$ w' [Steel Plant 钢铁厂( l* M1 V4 w% i6 K: i$ A  k
Steel Plate 钢板
: q; t$ Q8 A% @Steel Plate Door 钢板门
+ ]9 y& u' z6 u; a+ @" I4 ^Steel Plate Flange 钢板法兰
4 d% s! {* x% r7 q# b4 WSteel Plate For Fixation Of Fracture 接骨板
* R* J/ ^2 `7 f  V4 CSteel Plate Girder 钢板梁1 H  T/ b, y4 m
Steel Plate Lining 钢板衬层
; q1 N, `/ r8 O0 c1 K8 z2 J  M% VSteel Plate Radiator 钢制板式散热器) c: O# j% y. O8 S! U
Steel Plate Square Washer 方形钢垫板% ]  {% R# I& `- K5 u4 b
Steel Plate Stamping 钢板冲件) H7 T7 c! _# e3 C  ^5 K, N, t
Steel Plate Thickness Meter 钢板测厚仪1 N, i# K1 f! ~7 _( }  X1 U1 U
Steel Plated 包钢板' c8 t) b7 m$ g8 b1 s
Steel Plates For Boiler And Pressure Vessels 锅炉和压力容器用钢板6 E: Q9 D. Z5 G: Z! j: U
Steel Plates For Low Temperature Service 低温用钢板1 P9 Y; Q$ q6 \8 V0 n
Steel Plating 镀钢的
% Y9 C3 w2 |' o$ W$ j( _2 ?4 ^3 xSteel Pole 钢杆
* `5 y4 p( y$ |1 D$ Y* zSteel Production 炼钢2 F6 n5 s. b; x+ t9 E
Steel Products 钢材2 Q% n- i6 \* M# @% T8 e
Steel Profile 钢材剖面& I+ v% o: g2 b
Steel Prop 钢支柱! |+ h1 o) G/ w
Steel Protractor 钢制分度器% X8 [1 a- P4 J- J; b
Steel Puller 钻杆提取器9 _1 ^/ h) U8 I/ v* m
Steel Purlin 钢檩
7 Y6 \9 V$ Z, F" m! [1 s1 USteel Rabble 钢渣棒
/ I8 j5 d* V2 z- q* ~( @Steel Rail 钢轨
( ^3 L! [8 m' U& ]( m( ]Steel Ratio 钢筋百分比; 钢筋百分率
! D) I3 \% s0 o2 f# a% bSteel Reactor 钢制反应釜! e- ^( Y, P* ~1 I  u5 U% L
Steel Reinforced Aluminium Wire 钢芯铝线4 n/ i7 C* J+ u2 T3 t0 a: q  ~
% T7 H# q: f7 L. bSteel Reinforcement Bar Delivering Roller 钢筋输送辊
( @! W. @' l9 @( l% dSteel Reinforcement Bar Feeder 钢筋送料机: M0 n0 `! N; T: Q
Steel Reinforcement Bar Pre-Drawn Platform 钢筋预拉台
; G# q0 Y  ^( j/ H8 ASteel Reinforcement Cage 钢筋笼- S& ^$ [8 i+ c- S, S$ f1 V, m
Steel Reinforcement Laying Machine 钢筋敷设机
/ |" F9 h: N6 l, j& h( C3 OSteel Reinforcing Rod 钢筋棍
8 H7 S; g4 P# e) t  XSteel Relaxation 钢筋的松弛
# N7 t$ |0 X* y7 {0 zSteel Retort 钢蒸馏罐- l7 e$ I+ o2 }) Q( m2 H1 d
Steel Ribbed Floor 肋形钢楼盖
/ S* U8 B- Y" `& }/ M9 P# }Steel Ribbon 钢条
9 @! _/ U3 p* M# }  aSteel Rider 钢辊+ K+ b4 j9 v+ L2 r, ~
Steel Rim 钢轮辋  {1 }) z" _* ~; j1 w" Z
Steel Ring 钢环; 钢圈4 b/ O% e( A, C: [9 ]
Steel Ring Set 钢圈支架% Q2 z' ?. A& w- x7 v7 O
Steel Rivet 钢铆钉
1 L) j, N8 |6 g- Z0 ^* G! cSteel Rod 钢棍; 钢拉杆; 钢条$ H  g6 U9 [' k
Steel Roll 钢轧辊- B9 O1 i& W9 G8 A1 w
Steel Roller 钢辊; 钢轮压路机" L* k  u/ y1 X* ~# a2 w
Steel Rolling 钢材轧制; 轧钢" k  B( x5 l6 z+ z
Steel Roof Truss 钢屋架
1 S* E: n1 k; I  t9 t! a2 K" zSteel Rope 钢索
: q/ [2 v# H/ E) Q8 \: n5 kSteel Rule 钢尺
5 W- c2 ?, v% BSteel Rung 钢踏棍
) x' x! e! u9 x8 P7 v7 m' x0 r0 L" TSteel Sand Drilling 钢砂钻进
' J: T7 E( N/ t+ o: ~: N. gSteel Sash 钢窗; 钢框格' \5 t" x' S3 X, f* \1 v
Steel Saw 钢锯
' `& {: F* v- B& X  tSteel Scale 钢尺3 Q  c# Z+ x$ Y- J9 F  H/ g7 s! N
Steel Scoria 钢渣
; F* A  o! D$ @: |* HSteel Scrap 钢屑; 废钢
  \6 ^: {' {+ c  G0 t+ L. w, ]Steel Scraper 刮钢尺
1 H1 H: h1 b1 M8 hSteel Screen 钢板网" A& @  e! N, Y! |5 M9 ?
Steel Sets 矿用钢支架
% B; \; B$ H0 W* C) X5 pSteel Shank 钎子尾
  J: E# H- e* {; g% |- j* G- m: \% }Steel Sharpening 锻钎
2 u3 E* C( |  Q. `Steel Sheath 钢皮+ E% [8 \2 y% d+ y( R
Steel Sheathing 钢棉面板; 钢面板
# P, f$ u2 i" h  O- MSteel Sheel 钢壳体
# K, n/ e, n2 m% r) @7 I/ ?' A# QSteel Sheet Disk Wheel 钢板盘轮6 ^+ ^. \# h+ q+ F- ^2 B  r
Steel Sheet Pile 钢板桩# o! a5 y. V% p
Steel Sheet Pile Breakwater 钢板桩防波堤. y: Q6 h4 C# ~' U* l& R" ?
Steel Sheet Pile Bulkhead 钢板桩驳岸; 钢板桩护岸" I. d9 h) Y! i& R; O
Steel Sheet Pile Cellular Cofferdam 钢板桩格型围堰! D- F# X2 e' X2 h. V
Steel Sheet Pile Earth Cofferdam 钢板桩填土围堰  J5 t8 L: u+ }) E* M: \
Steel Sheet Pile Quaywall 钢板桩岸壁; 钢板桩码头
( j0 z1 @7 m) \. m3 uSteel Sheet Pile Wharf 钢板桩码头. R" g: R5 {7 L, [  M
Steel Sheet Piling 钢板桩; 钢板桩9 Y7 `, Q- x; _, j3 y
Steel Sheet Piling Cutoff 钢板桩截水墙
" Y' L/ ]8 g- O: _2 DSteel Sheet Piling Type Dolphin 钢板桩式系船墩# V/ I, b6 P4 _
Steel Sheet Shears 钢皮剪刀7 |. D# n: c: N' r. `
Steel Sheet Straightener 钢板校直机3 \4 a, b) P. e
Steel Sheet-Pile Wall 钢板桩墙6 _8 K' z6 `# \9 n  R" T
Steel Shell 钢壳; 钢制炉体
4 F0 |" i, \, `/ I" _7 }- ASteel Shelled Box Type Load Switch 钢壳负荷开关2 Y# Q3 }- i& @/ m$ J# d0 V: @
Steel Shield 钢盾; 防护钢壳
1 M7 E  z, H, V' t1 P( R5 H+ I6 CSteel Shoe 钢挡板; 钢桩靴! A+ t$ }7 a7 ]( U, T1 u
Steel Shot 钢粒; 钢丸
7 Z0 u3 q6 e  QSteel Shot Abrasive 钢砂磨粒
: C0 D, e! l- p  i3 I4 V8 OSteel Shot Boring 钢珠钻探
/ [# d! ]  ~  F  i* T& W& SSteel Shot Drilling 钢砂钻井; 钢珠钻孔; 钢珠钻探
/ N  U4 r' v' m. SSteel Shotcrete 钢支撑7 t6 ~- z; v/ A+ A/ d
Steel Shovel 钢铲; 钢锹
6 o' p' r' ?) R4 F" [Steel Skeleton 钢骨架
& ?! ~3 z9 P! qSteel Skeleton Building 钢骨架房屋; 钢骨架建筑9 U) n. S  O4 h$ d3 p: G+ v* Z. Q
Steel Skeleton Compact 钢骨架坯块
. @3 B0 Y) G4 Y, ~Steel Skeleton Construction 钢骨架构造
7 A' m9 P/ {5 M- B' GSteel Slab 钢锭
: k* e6 U& B- M2 R6 h/ JSteel Slab Bridge 钢板桥1 ^" n1 I# R* K; V' }# t8 [- J
Steel Slag 钢渣& g- w0 @7 b- H4 Z
Steel Sleeper 钢枕; 钢枕木
( W- P* |+ o) JSteel Sleeve 钢衬垫; 钢套管2 q% h4 |7 f; D# H$ w
Steel Slip Gauge 钢制块规3 h/ S1 Q9 ?4 W
Steel Snare Wire 鼻息肉绞断钢丝# W! A* g: f, m1 t6 y. {) |
Steel Socket 钢套节
1 o; N  J1 u- M6 @1 ZSteel Sorter 钢鉴别仪9 y0 b0 ~! Q* }% r9 Q
Steel Space Frame Structure 钢空间框架结构
$ v. L9 F3 ?9 |Steel Spade 钢锹9 u" J7 S) v2 ^
Steel Specification 钢号
  Z7 M  m9 U2 i( y# \: q- cSteel Spirit Level 钢水平尺) \* C2 C. k5 e
Steel Spoke Wheel 钢制辐轮
4 f4 N& o4 l9 W" e# \7 U$ S- F1 CSteel Spout 出钢槽9 k9 j* |1 l$ z: _2 m" ?! W( k
Steel Sprial Spring 钢螺簧* V& M6 \. O" ~- ]
Steel Spring 钢簧# L' e* t4 l, d% i; q
Steel Spring Plate 弹簧钢板& L2 J, N0 n, O! ^1 s
Steel Spring Undercarriage 钢簧起落架
) s0 p  Y$ k+ R9 n( d% i" W) GSteel Square 钢角尺; 钢曲尺; 直角钢; 直角钢尺; s  R% H' U' Y
Steel Stack 钢通风管; 钢烟囱; 钢制烟囱& }% E$ n* X. U+ s1 P1 c
Steel Stair 钢楼梯
) V- q2 Y# n7 v0 R1 ZSteel Strand 钢绞线
, \& g9 j; E; E: v2 M, dSteel Strand Rope 钢索
8 g) M5 d- q0 x, }- d$ X+ JSteel Stranded Wire 钢绞线* \2 }, D: f; Z) i  K( |' b5 x
Steel Strap 钢片
  e. P6 L" Y) e4 p" hSteel Strapping Equipment 钢带捆轧机
3 A: I: I  i- ^Steel String 钢绳弦线
* H) @7 \5 R- m5 c, Q( HSteel String Stair 钢梁楼梯3 Z# C: e. z# {+ C# ]# ~3 L2 \" W  L! P
Steel Strip 钢带
( d" K% L1 u4 ~( @2 vSteel Strip Die 钢带模
9 e; R, E0 ]  |5 B+ MSteel Structural Derrick 钢结构钻塔
- D, B) r5 p/ NSteel Structure 钢结构
/ g3 N) C' U5 ISteel Structure Design 钢结构设计
: q7 l3 v9 N$ b+ w5 [Steel Structure Work 钢结构工程
  u3 o* U2 ^1 Y5 ~2 S! I* SSteel Strut 钢支柱
" F9 P) Y( ?) a" Z; _" R  ?% k- vSteel Stud 钢立筋& Q4 e$ u/ f8 j: Z: P1 A
Steel Sub-Tread 钢踏步底板
9 Y+ @. i3 o2 L* [3 dSteel Superstructure 上部钢结构
, y! e- ?0 Z4 [( CSteel Support 钢圈支架; 金属支架
+ {+ u- k, A/ A0 ^Steel Support Structure 钢支撑结构" k& K6 i; k( [) b& v, e
Steel Supporting Stock Column 钢支柱料柱2 j6 V( M5 N: [/ [' J
Steel Swarf-Removing Tool 断屑刀片
7 Q# X1 v  i0 ?: I) q  Z, @Steel Tank 钢槽; 钢罐; 金属结构罐: a& X4 ]( N  [' x" Z  G
Steel Tape 钢合尺; 钢卷尺" r* d" |( A/ ~0 h) J! N4 i1 o: m
Steel Tape Web Divider 钢带毛网分条器% e+ ^8 |' D* o9 `  J8 R
Steel Tendon 钢丝束
( A+ m4 U. U! J) Q% wSteel Test Piece 钢材取样块
+ m# t$ f. c" V* p- |* m" w5 oSteel Thimble 钢套管2 N  `, @# B# P" K7 }& @
Steel Thread 钢丝
2 g9 y/ s$ ~6 P% c# gSteel Tie Beam 钢拉梁
% y' u- n1 n  L3 G7 qSteel Tie Rod 钢拉杆+ a7 P" I0 P- l2 ^# ^# Z2 I  {
Steel Timber 金属支架
  n" k) a9 e$ gSteel Tool Box 钢壳工具箱  x/ U4 r- _) I8 W# z0 t9 Y
Steel Tooth 钢齿
) v. M" k8 R  I/ j8 ~5 s. GSteel Tooth Bit 钢齿牙轮钻头
4 N7 ]' a+ g0 B* k7 p& T& D1 ^8 ESteel Tower 钢塔; 铁架; 铁塔" F  L/ Z7 L9 E% ~7 W2 A
Steel Trap 捕兽夹
6 B7 E3 D. \6 Z* u9 U, |; pSteel Traveler 钢丝圈6 i! H( I+ H; H& m
Steel Trestle 钢栈桥0 @5 B7 F# W. V
Steel Trowel 钢抹子; 钢镘; 钢镘刀
5 I- p/ a/ `# b/ y" j1 w* W  KSteel Troweling 钢抹镘光
% \' c- n8 W& B! F# C; u" FSteel Truss 钢桁架" P$ q! o! j5 g# G
Steel Tube 钢管7 c7 _3 P3 g$ n: W( K6 B
Steel Tube Armour 钢管铠装
8 a+ N4 D* U$ SSteel Tube For Fired Heater 加热炉用钢管! Z& N6 h1 d3 G& S7 m
Steel Tubes For Heat Transfer 热传导用钢管
( \" J8 ]9 W! q! [) b. k2 N4 ~Steel Tubing 钢管2 K. g3 l8 {$ _- K4 k8 y) ]
Steel Tubular Handrailing 钢管扶手
) m, J8 R( F  ^1 c& {# C9 n, ~Steel Tunnel Support 隧道钢支护
, E7 R, m# I% d0 M8 P3 S# p/ D0 @Steel Type 钢材型号/ l' {! [4 x! g( P* b) O# l
Steel Tyre 钢轮箍
+ K+ J) s% q5 u! r* ^- [1 y$ }/ ~Steel Upright 钢支柱+ [/ e1 ]# L4 B1 [8 x/ c
Steel Vessel 钢制容器5 ]+ w5 A, F% E, _" |7 K
Steel Washer 钢垫圈
) S, u4 Q* ^+ h4 q6 ]; V7 _Steel Wedge 钢楔; T: ^- G  S+ h4 m
Steel Weir 钢堰# a, C: m. }" S1 U+ A6 Z% }
Steel Wheel 钢轮
7 H( @( H( H2 _" _2 G) FSteel Window 钢窗
1 _5 y) J  @+ @6 D- ~- cSteel Window Frame & Accessory 钢窗框及配件& S$ X6 F# }2 @: R6 o
Steel Window Section 钢窗料
2 S. E$ \8 r6 _2 T/ E$ R1 S3 J* @) z, z- aSteel Wire 钢丝; 钢线
+ p1 @! r* L* ^" E9 mSteel Wire Armored Cable 钢丝铠装电缆# s4 o! U5 h3 Y
Steel Wire Armour 钢线铠装( j  P) c# b# G1 D. ^/ G8 w- q
Steel Wire Armoured 钢丝铠装的
. |( y, D' A  S3 YSteel Wire Armoured Air Rubber Hose 钢丝编织空气胶管
, F2 l# b1 F0 q" H" LSteel Wire Armoured Cable 钢线铠装电缆4 N5 }9 k$ j* o0 W
Steel Wire Armoured High Pressure Rubber Hose 钢丝编织高压胶管4 C  N" I* n9 f  V( t5 Q
Steel Wire Armoured Water Rubber Hose 钢丝缠绕排水胶管) Q. d, D- p' C3 L" I
Steel Wire Braid 钢丝编织层
; ~; R4 o/ g9 B/ E4 @Steel Wire Braided High Pressure Hose 钢丝编织高压管
' ]- p$ y% R: U  S) `, d7 SSteel Wire Brush 钢丝刷$ f+ H" o$ [( T
Steel Wire Clamp 钢丝绳卡头- d3 k) \4 X& {+ n
Steel Wire Cloth 铁砂布. Z+ {7 f" }! Z& B( V9 a$ U
Steel Wire Cutter 钢丝刀. T5 G& ?' j- B5 ]! ^9 {" L
Steel Wire Cutter One Step Quick Forming 钢丝刀一次快速成形法
% n0 \6 a# f) y: WSteel Wire Embedded Water Suction Rubber Hose 埋线工业吸水胶管
$ f; |& j$ S( z# l& ?Steel Wire For Aural Polyp Snare 耳息肉绞断器用钢丝
; W9 f; q% `# a* ISteel Wire For Welding Electrode 焊条钢丝; g/ |3 B, T. r0 e3 y3 S% q6 T3 K
Steel Wire Gauge 钢丝线规; 钢线规
9 C* ]& \) a6 C; _0 J  zSteel Wire Gauze 钢丝网
- g" N! ^3 O  M; dSteel Wire Heald 钢丝综: p$ a5 }* n$ {* L: j9 N) |
Steel Wire Lashing 钢丝绑扎" Z, g- ^8 B) S1 `! h  r9 G; d
Steel Wire Mesh 钢丝网# e  j% ]% X; {: R, a* v+ |% P# s
Steel Wire Netting 钢丝网/ l$ u2 X9 I* O% B* K
Steel Wire Of High Tensile Strength 高强钢丝
$ [( v. l  ?) e2 g9 n$ D+ y3 MSteel Wire Packer 钢丝打包机! C* W( _; b" t7 B  ?* b1 K2 N
Steel Wire Reinforced Belt 钢丝芯加固橡胶带
, q; J5 s: K9 \/ X$ USteel Wire Ring Wheel 钢丝圈刷轮
: N) q3 U: A% n7 g8 j1 F4 oSteel Wire Rope 钢丝绳; 钢丝索9 b( ]1 J/ f, F4 y/ |
Steel Wire Rope Clip 钢丝绳卡头! D1 C& [) J8 K, O4 U
Steel Wire Rope Graphite-Base Grease 钢丝绳石墨润滑油
4 H2 b1 b( `. E, d, h: t8 zSteel Wire Rope Stranding-Bundling Machine 钢丝绳绞束机; r: ^) v7 R8 \
Steel Wire Rope With Thimble 带线环钢丝绳
+ w  k: I2 N5 T- ySteel Wire Rotary Brush 钢丝轮刷$ c1 K2 l4 N$ v- X: N
Steel Wire Strand 多股钢丝; 多股钢线' s% v7 u8 V  u0 f  Z
Steel Wire Stylet 钢丝针芯' }" D. x9 J4 I: n" e9 }
Steel Wire Tube Brush 钢丝管刷
5 V( d+ ^0 N$ D+ DSteel Wire Wheel Brush 钢丝轮刷, E, D( |  j, f6 m$ \4 ^9 P
Steel Wires 钢绞线( `( h& ~* S( d& R! R
Steel Wiring Reinforced Brick Wall 钢丝网加劲砖墙  m9 T; G& T* j0 w# M1 q. Z6 _
Steel Wool 钢棉; 钢丝棉; 钢丝绒; 铁绒" {9 Y3 M3 E* ~
Steel Wool Filter 钢丝绒滤油器
$ m# {: V. x  r3 P" TSteel Work 钢制件
  @, M0 Z* \0 ^, ZSteel Works 钢厂; 钢铁厂
( F+ N6 p2 v  ~; N8 ]8 n! h( tSteel Works Equipment 钢厂设备  A: F6 Q0 c' d2 l  s: _
Steel Yoke End 钢叉
- h4 V0 V1 f3 g) r) R! FSteel-Alkaline Battery 碱性镍铁蓄电池
' c) ]2 J8 H. z) M: T# l5 `& ySteel-Aluminium Conductor 钢铝线; F- k" o. g/ K7 k& g) s7 y' F
Steel-Backed 钢背的
4 Y$ Y4 E: L& h) FSteel-Backed Bearing 钢背轴承
0 V4 u# d0 f1 oSteel-Backed Bearing Alloy 钢背轴承合金9 v& ~, H: M# M% d  _3 p* Q
Steel-Backed Bearing Metal 钢背轴承合金0 m" {0 c& g1 ]& B* N
Steel-Backed Bronze-Faced Washer 钢背铜面垫圈+ n; r1 Y% l; l+ Q) Q& m
Steel-Band Conveyer 钢带输送机; 钢带运输机9 B2 v% I$ a" D
Steel-Based Plate 钢基印版: H% s* D1 i: r; q2 u1 K
Steel-Bonded Carbide Products 钢结硬质合金产品
! b  n: a. I' g. R. LSteel-Cable Conveyor Belt 钢索输送机皮带3 a/ a" c) m3 j
Steel-Cage Construction 钢骨架构造/ q, i. D' f' Z9 ?
Steel-Cast 钢铸的; 铸钢的  F8 w8 V6 e+ K+ n
Steel-Casting Foundry 铸钢厂; 铸钢车间
# Q8 v6 H0 D; Z- {Steel-Clad 钢片衬; 铁甲; 包钢6 ]' O- h: [7 q1 H
Steel-Clad Brick 铁皮砖; 钢皮砖
( [% k9 l1 Q$ l4 g0 _. o! l$ m, \Steel-Clad Rope 钢甲绳
1 e( K. r( j) n9 `3 [' RSteel-Clad Switchbox 铠装开关箱/ n( ~" V( b$ u2 k7 p
Steel-Concrete Composite Girder 钢材混凝土组合梁7 |: m) ~  l+ ]: u: v
Steel-Cord Conveyor Belt 钢丝绳运输带) L, g/ Z+ @! _) k7 M2 y
Steel-Cored 钢芯的. }( D, G7 i# J9 {
Steel-Cored Aluminium Cable 钢芯铝线! c6 X" w! H9 R- Q! f/ z
Steel-Cored Aluminium Strand Wire 钢芯铝绞线
0 `7 A4 q, `- g& h6 RSteel-Cored Aluminium Wire 钢芯铝线+ `8 G! G3 |1 f
Steel-Cored Aluminum Strand 钢芯铝绞线* k& J, I3 B4 O
Steel-Cored Copper Conductor 钢芯铜线/ w1 [, C9 e* E) u2 K4 x
Steel-Cored Copper Wire 钢芯铜线
! l+ t# c" D& HSteel-Cored Wire Rope 钢芯钢丝绳7 u0 o/ U* r- R5 z
Steel-Die Engraving Press 钢凹版印刷机
6 G/ K' K' [% t" R9 PSteel-Encased Beam 劲性钢筋混凝土梁( g5 A& Y6 ?  j0 U4 D
Steel-Frame Construction 钢架
发表于 2007-9-2 11:09:14 | 显示全部楼层 来自: 中国重庆
又复习了一下以前学的,非常感谢楼主的收集。
发表于 2010-11-11 16:20:29 | 显示全部楼层 来自: 中国河北石家庄
非常受用
4 ^  L/ D: c7 h; p 3# wszdzdh_25
