查看: 1517|回复: 0
[讨论] 关于自动装配的二次开发问题
发表于 2007-9-7 15:57:20 | 显示全部楼层 |阅读模式 来自: 中国山东东营
请问各位高手,有做关于自动装配的二次开发的吗?我用的是VB。试了很多方法不行。这是我写的代码:- b: b! u# j! V5 ~9 P2 v
" W/ \  R  p8 L  ?1 }Public swApp As SldWorks.SldWorks
* |. `+ u+ d$ L! T9 `6 H" WPublic Model As SldWorks.ModelDoc2
  q2 G6 M8 D; h2 _$ F' I2 Y" {Public SelMrg As SldWorks.SelectionMgr$ a% ]8 k0 ^  i7 g, T6 J+ Q* X: E
Public Assy As SldWorks.AssemblyDoc2 h1 S/ t2 ~' [- M% e$ @' f
Public SelFace As SldWorks.face2
) i2 [. t# e8 C. `: n6 G) RPublic Body As SldWorks.body2
/ f! R. j2 T8 e" N; E( a% vPublic errors As Long
' C) E5 g2 k# K3 z5 \& O-------------------------------------------------------------------------------------------------7 m# f- E2 M' Q5 t9 Z
Private Sub CommandButton1_Click()8 m/ C; x/ [" |) p( t% ]
Set swApp = Application.SldWorks
! ^/ @. j+ R2 @7 \  uSet swModel = swApp.ActiveDoc; ]( e, s+ F. D2 e' x" L: J
swApp.ActivateDoc2 "mate.SLDASM", True, errors
8 @+ Z: M* D/ C+ I' vModel.SelectByID "zhu-1 @ mate", "COMPONENT", 0, 0, 0# R. ^' r8 {" g) k& n0 v1 E* m
Call SelectFace("face2")4 K2 r; I, ?6 Z$ I
Model.SelectByID "zuo-1@mate", "COMPONENT", 0, 0, 0
7 W. D( A) z; T) Q6 {; A. X1 s8 f) yCall SelectFace("face1"); e# ]; _9 R8 W4 ^/ x: K" {
Assy.AddMate swMateCOINCIDENT, 0, False, 0, 07 H5 `6 K4 g# H; R* C
End Sub
& H' @0 i$ _2 Y: ^-------------------------------------------------------------------------------------------------------------------1 u8 U* r! l# k  k$ \
Public Function SelectFace(FaceName As String)' @' a9 F8 L: E0 f
Dim i As Integer
9 }4 E+ H$ s/ e+ P+ xDim Comp As Component24 _( u# D' B% Q; M$ A
Dim Face As face22 S  n2 x# L8 ~2 g" ]  e- }5 B# ]; s
Dim Body As body20 m- x" o% W. i  d  M
Dim CurFaceName As String3 l( L" _7 ^2 R; S3 {: |: k
Set SelMrg = swModel.SelectionManager0 i* @& Z# J( R  p. b
Set Comp = SelMrg.IGetSelectedObjectsComponent2(SelMrg.GetSelectedObjectCount)
; e* h+ i9 r0 C* `* CSet Body = Comp.IGetBody  y' C* b# c/ m  r- X7 f. m
Set Face = Body.IGetFirstFace+ b4 I% i$ s9 z7 d  B/ M( V5 R
If Body.GetFaceCount = 1 Then& s1 K) F, T* W" q: M/ P1 N& J
   Dim Face As SldWorks.entity6 C* p+ d. ?$ y/ x* o+ \. T
   Face.Select2 True, 0
3 |; w( S. i  M+ s. ZElse
, Z9 x1 w4 t& B" {1 N1 h9 L   For i = 1 To Body.GetFaceCount - 1' `, Q6 Q4 j- q9 T. @9 q2 J% R
     Set CurFaceName = swModel.GetEntityName(Face)
# Q0 S( W* W7 J9 ~( O1 t# l     If (CurFaceNme = FaceName) Then; F( K: s/ ?6 w4 c
+ I4 J: q3 n% s& ~         Face.Select2 True, 0
7 s: `/ R+ u  A     Set Face = Face.IGetNextFace
1 z7 \6 k2 Y" c5 z/ N7 R5 u     End If
* [5 z) I9 C3 R3 iEnd If5 }+ _) Y9 Q7 A) q$ |# P( g
5 P, Y! S; ^1 n- w5 k; LEnd Function8 A$ `! {; `" C
/ i- Z- J; R& ]& A/ D下图是我要装配的零件
我要装配的两个零件
我要装配的两个零件
