发表于 2007-9-8 19:59:04
来自: 中国重庆
你可以去国内外标准数据库:http://www.bxkj-standards.org/standards/index.htm中去找* T3 a* V$ e7 D6 K5 O) C1 v
这是它ASTM 美国材料标准目录一:# S- z. E3 c8 q) M2 D* R5 [0 [
ASTM-A1-2000(R05) STANDARD SPECIFICATION FOR CARBON STEEL TEE RAILS; p8 O; n5 {+ z8 v+ p" S
ASTM-A2-2002 STANDARD SPECIFICATION FOR CARBON STEEL GIRDER RAILS OF PLAIN, GROOVED, AND GUARD TYPES0 b1 l$ O4 ^# N. Y
ASTM-A3-2001(R06) STANDARD SPECIFICATION FOR STEEL JOINT BARS, LOW, MEDIUM, AND HIGH CARBON (NON-HEAT-TREATED)- B* c K2 M& O7 p7 O6 V3 C
ASTM-A6/A6M-2005A STANDARD SPECIFICATION FOR GENERAL REQUIREMENTS FOR ROLLED STRUCTURAL STEEL BARS, PLATES, SHAPES, AND SHEET PILING' Z# a! y2 _, c7 j4 P. @8 |& V
ASTM-A20/A20M-2005 STANDARD SPECIFICATION FOR GENERAL REQUIREMENTS FOR STEEL PLATES FOR PRESSURE VESSELS* a) t, ]( \. ?( `& P
ASTM-A27/A27M-2005 STANDARD SPECIFICATION FOR STEEL CASTINGS, CARBON, FOR GENERAL APPLICATION
3 P7 \5 e* y6 y) tASTM-A29/A29M-2005 STANDARD SPECIFICATION FOR STEEL BARS, CARBON AND ALLOY, HOT-WROUGHT, GENERAL REQUIREMENTS FOR0 W/ t! I$ ^1 t9 f- Z/ J4 ]1 v- U
ASTM-A31-2004 STANDARD SPECIFICATION FOR STEEL RIVETS AND BARS FOR RIVETS, PRESSURE VESSELS" ]) |4 U' R- l6 c* A8 q
ASTM-A34/A34M-2001 STANDARD PRACTICE FOR SAMPLING AND PROCUREMENT TESTING OF MAGNETIC MATERIALS9 T" i) n6 O. N8 T* J: b
ASTM-A36/A36M-2005 STANDARD SPECIFICATION FOR CARBON STRUCTURAL STEEL! A5 D$ g8 @! p
ASTM-A47/A47M-1999(R04) STANDARD SPECIFICATION FOR FERRITIC MALLEABLE IRON CASTINGS
2 \4 i. o: i# h- s0 NASTM-A48/A48M-2003 STANDARD SPECIFICATION FOR GRAY IRON CASTINGS
' b9 {, d" {( E1 T* v9 V. B( J2 UASTM-A49-2001(R06) STANDARD SPECIFICATION FOR HEAT-TREATED CARBON STEEL JOINT BARS, MICROALLOYED JOINT BARS, AND FORGED CARBON STEEL COMPROMISE JOINT BARS
' @( S! O7 v7 R3 U! ~0 k, ZASTM-A53/A53M-2005 STANDARD SPECIFICATION FOR PIPE, STEEL, BLACK AND HOT-DIPPED, ZINC-COATED, WELDED AND SEAMLESS' W' M1 [+ i: ~. W
ASTM-A65-2001 STANDARD SPECIFICATION FOR STEEL TRACK SPIKES
) n8 R9 X$ S# K$ i4 d1 u8 sASTM-A66-2001 STANDARD SPECIFICATION FOR STEEL SCREW SPIKES2 C( h" p+ X; q& L2 ?8 R
ASTM-A67-2000(R05) STANDARD SPECIFICATION FOR STEEL TIE PLATES, LOW-CARBON AND HIGH-CARBON-HOT-WORKED
7 |8 r+ g& [6 b+ {ASTM-A74-2005 STANDARD SPECIFICATION FOR CAST IRON SOIL PIPE AND FITTINGS - AASHTO NO.: M263-77
& Z2 P/ ~: m5 e. o& r; aASTM-A82/A82M-2005A STANDARD SPECIFICATION FOR STEEL WIRE, PLAIN, FOR CONCRETE REINFORCEMENT - AASHTO STANDARD AASHTO NO. M 32! h, z& |# g6 i6 z5 s# F" _
ASTM-A90/A90M-2001 STANDARD TEST METHOD FOR WEIGHT [MASS] OF COATING ON IRON AND STEEL ARTICLES WITH ZINC OR ZINC-ALLOY COATINGS5 ]5 p h* s/ |) n
ASTM-A99-2003 STANDARD SPECIFICATION FOR FERROMANGANESE
, g% q# A( w7 D/ ]. `1 j5 {. _ASTM-A100-2004 STANDARD SPECIFICATION FOR FERROSILICON
& ~. T% E% }" r( w" _- p$ sASTM-A101-2004 STANDARD SPECIFICATION FOR FERROCHROMIUM
' Y0 K {) B+ n FASTM-A102-2004 STANDARD SPECIFICATION FOR FERROVANADIUM
7 h) z, M0 d5 \8 s9 u: lASTM-A105/A105M-2005 STANDARD SPECIFICATION FOR CARBON STEEL FORGINGS FOR PIPING APPLICATIONS
6 T5 K. I9 P; v, Q6 A( Q* `1 vASTM-A106/A106M-2006 STANDARD SPECIFICATION FOR SEAMLESS CARBON STEEL PIPE FOR HIGH-TEMPERATURE SERVICE% r* }* [$ }7 k# h
ASTM-A108-2003(E) STANDARD SPECIFICATION FOR STEEL BAR, CARBON AND ALLOY, COLD-FINISHED
# @ V4 h+ A/ ^2 O& i) Q- @/ V$ XASTM-A109/A109M-2003 STANDARD SPECIFICATION FOR STEEL, STRIP, CARBON (0.25 MAXIMUM PERCENT), COLD-ROLLED
" D" h. q6 Z6 K- ^1 O) YASTM-A111-1999A(R04)(E) STANDARD SPECIFICATION FOR ZINC-COATED (GALVANIZED) G牵IRONG钎 TELEPHONE AND TELEGRAPH LINE WIRE# E$ | V0 m4 C1 A' k6 o! }' j
ASTM-A116-2005 STANDARD SPECIFICATION FOR METALLIC-COATED, STEEL-WOVEN WIRE FENCE FABRIC
' a! h$ f2 t2 b4 ZASTM-A121-1999(R04) STANDARD SPECIFICATION FOR METALLIC-COATED CARBON STEEL BARBED WIRE2 _0 _7 q7 D# f! D, `) ?
ASTM-A123/A123M-2002 STANDARD SPECIFICATION FOR ZINC (HOT-DIP GALVANIZED) COATINGS ON IRON AND STEEL PRODUCTS: e+ o& y& I, Y! K$ U( U v/ C
ASTM-A125-1996(R01) STANDARD SPECIFICATION FOR STEEL SPRINGS, HELICAL, HEAT-TREATED( k2 r% a% Z5 M* x1 i6 f
ASTM-A126-2004 STANDARD SPECIFICATION FOR GRAY IRON CASTINGS FOR VALVES, FLANGES, AND PIPE FITTINGS. I' `9 N' u2 }, O0 b
ASTM-A128/A128M-1993(R03) STANDARD SPECIFICATION FOR STEEL CASTINGS, AUSTENITIC MANGANESE
4 h* S- V9 M4 HASTM-A131/A131M-2004(E) STANDARD SPECIFICATION FOR STRUCTURAL STEEL FOR SHIPS
2 C# \% P" A" z0 g' nASTM-A132-2004 STANDARD SPECIFICATION FOR FERROMOLYBDENUM \- F$ F1 l5 I c( j
ASTM-A134-1996(R05) STANDARD SPECIFICATION FOR PIPE, STEEL, ELECTRIC-FUSION (ARC)-WELDED (SIZES NPS 16 AND OVER)
% Y. n& Y w* n) @ASTM-A135/A135M-2006 STANDARD SPECIFICATION FOR ELECTRIC-RESISTANCE-WELDED STEEL PIPE
2 K) a& c5 e& `2 ^ G1 s, M7 YASTM-A139/A139M-2004 STANDARD SPECIFICATION FOR ELECTRIC-FUSION (ARC)-WELDED STEEL PIPE (NPS 4 AND OVER). F, m) E4 |+ z: q: ^& ^
ASTM-A143/A143M-2003 STANDARD PRACTICE FOR SAFEGUARDING AGAINST EMBRITTLEMENT OF HOT-DIP GALVANIZED STRUCTURAL STEEL PRODUCTS AND PROCEDURE FOR DETECTING EMBRITTLEMENT7 l2 U0 w9 G$ l. G# `9 Y/ f& u
ASTM-A144-2004 STANDARD SPECIFICATION FOR FERROTUNGSTEN: `) A8 _& a p5 I- |
ASTM-A146-2004 STANDARD SPECIFICATION FOR MOLYBDENUM OXIDE PRODUCTS8 X& s+ M t( u: n. G% ~, o+ `
ASTM-A148/A148M-2005 STANDARD SPECIFICATION FOR STEEL CASTINGS, HIGH STRENGTH, FOR STRUCTURAL PURPOSES0 d( I- A. `* I2 H
ASTM-A153/A153M-2005 STANDARD SPECIFICATION FOR ZINC COATING (HOT-DIP) ON IRON AND STEEL HARDWARE - AASHTO NO.: M232
7 l% t) k, i# _! ^' Q4 ?9 Y% gASTM-A159-1983(R01) STANDARD SPECIFICATION FOR AUTOMOTIVE GRAY IRON CASTINGS
9 @7 i. z/ g) v% N2 ^ I- ]2 ~6 e8 cASTM-A167-1999(R04) STANDARD SPECIFICATION FOR STAINLESS AND HEAT-RESISTING CHROMIUM-NICKEL STEEL PLATE, SHEET, AND STRIP
% T3 o. G! J! R! e1 JASTM-A176-1999(R04) STANDARD SPECIFICATION FOR STAINLESS AND HEAT-RESISTING CHROMIUM STEEL PLATE, SHEET, AND STRIP; J- h9 v, [5 v$ R5 J
ASTM-A178/A178M-2002 STANDARD SPECIFICATION FOR ELECTRIC-RESISTANCE-WELDED CARBON STEEL AND CARBON-MANGANESE STEEL BOILER AND SUPERHEATER TUBES8 y. K4 l$ ]( M$ t* P& g3 F
ASTM-A179/A179M-1990A(R05) STANDARD SPECIFICATION FOR SEAMLESS COLD-DRAWN LOW-CARBON STEEL HEAT-EXCHANGER AND CONDENSER TUBES
5 N& h1 n. D8 }1 r/ N9 x8 nASTM-A181/A181M-2001 STANDARD SPECIFICATION FOR CARBON STEEL FORGINGS, FOR GENERAL-PURPOSE PIPING
6 O D7 t! v; T8 S7 f# V. T, aASTM-A182/A182M-2005A STANDARD SPECIFICATION FOR FORGED OR ROLLED ALLOY AND STAINLESS STEEL PIPE FLANGES, FORGED FITTINGS, AND VALVES AND PARTS FOR HIGH-TEMPERATURE SERVICE
$ g; G# f* G) d& |# |. ~ASTM-A183-2003 STANDARD SPECIFICATION FOR CARBON STEEL TRACK BOLTS AND NUTS
; `' f+ M; N( p" D2 l9 h$ y- HASTM-A184/A184M-2006 STANDARD SPECIFICATION FOR WELDED DEFORMED STEEL BAR MATS FOR CONCRETE REINFORCEMENT
. a9 d$ v3 ^9 k8 RASTM-A185/A185M-2006 STANDARD SPECIFICATION FOR STEEL WELDED WIRE REINFORCEMENT, PLAIN, FOR CONCRETE' K" ~" t- c: @4 Z* p, O
ASTM-A192/A192M-2002 STANDARD SPECIFICATION FOR SEAMLESS CARBON STEEL BOILER TUBES FOR HIGH-PRESSURE SERVICE
' E* N% {: F+ S3 c1 e+ j: fASTM-A193/A193M-2006A STANDARD SPECIFICATION FOR ALLOY-STEEL AND STAINLESS STEEL BOLTING MATERIALS FOR HIGH TEMPERATURE OR HIGH PRESSURE SERVICE AND OTHER SPECIAL PURPOSE APPLICATIONS
& @3 b, f0 h+ R5 bASTM-A194/A194M-2006 STANDARD SPECIFICATION FOR CARBON AND ALLOY STEEL NUTS FOR BOLTS FOR HIGH PRESSURE OR HIGH TEMPERATURE SERVICE, OR BOTH
0 |# w' r( o! Z: r9 C' r5 iASTM-A197/A197M-2000(R06) STANDARD SPECIFICATION FOR CUPOLA MALLEABLE IRON
0 |! P+ {* Z. A4 Z) cASTM-A203/A203M-1997(R03) STANDARD SPECIFICATION FOR PRESSURE VESSEL PLATES, ALLOY STEEL, NICKEL& `" X; b4 m; `2 T1 ?
ASTM-A204/A204M-2003 STANDARD SPECIFICATION FOR PRESSURE VESSEL PLATES, ALLOY STEEL, MOLYBDENUM, u/ G5 H1 ~6 P
ASTM-A209/A209M-2003 STANDARD SPECIFICATION FOR SEAMLESS CARBON-MOLYBDENUM ALLOY-STEEL BOILER AND SUPERHEATER TUBES
" U9 b& W" O8 a' KASTM-A210/A210M-2002 STANDARD SPECIFICATION FOR SEAMLESS MEDIUM-CARBON STEEL BOILER AND SUPERHEATER TUBES! t' |: Y# _/ M* f- n8 V
ASTM-A213/A213M-2006 STANDARD SPECIFICATION FOR SEAMLESS FERRITIC AND AUSTENITIC ALLOY-STEEL BOILER, SUPERHEATER, AND HEAT-EXCHANGER TUBES
" a, j0 T( o1 _ASTM-A214/A214M-1996(R05) STANDARD SPECIFICATION FOR ELECTRIC-RESISTANCE-WELDED CARBON STEEL HEAT-EXCHANGER AND CONDENSER TUBES8 S8 p! e3 q8 j4 k9 l8 ~
ASTM-A216/A216M-2004 STANDARD SPECIFICATION FOR STEEL CASTINGS, CARBON, SUITABLE FOR FUSION WELDING, FOR HIGH-TEMPERATURE SERVICE
* ^" C0 t5 K: }: H8 w. R' oASTM-A217/A217M-2004 STANDARD SPECIFICATION FOR STEEL CASTINGS, MARTENSITIC STAINLESS AND ALLOY, FOR PRESSURE-CONTAINING PARTS, SUITABLE FOR HIGH-TEMPERATURE SERVICE
' e9 Q8 D/ R! r2 YASTM-A220/A220M-1999(R04) STANDARD SPECIFICATION FOR PEARLITIC MALLEABLE IRON, E! K% c7 }% P, M
ASTM-A225/A225M-2003 STANDARD SPECIFICATION FOR PRESSURE VESSEL PLATES, ALLOY STEEL, MANGANESE-VANADIUM-NICKEL7 Q% k! \8 u. K' j
ASTM-A227/A227M-2006 STANDARD SPECIFICATION FOR STEEL WIRE, COLD-DRAWN FOR MECHANICAL SPRINGS
9 X# t" ^, S/ g! k; N; iASTM-A228/A228M-2002 STANDARD SPECIFICATION FOR STEEL WIRE, MUSIC SPRING QUALITY
2 I& ^. t0 j2 Y9 ?4 r* F. {9 F* bASTM-A229/A229M-1999(R05) STANDARD SPECIFICATION FOR STEEL WIRE, OIL-TEMPERED FOR MECHANICAL SPRINGS
% r Y; {* n9 `* JASTM-A230/A230M-2005 STANDARD SPECIFICATION FOR STEEL WIRE, OIL-TEMPERED CARBON VALVE SPRING QUALITY4 \, }4 Q9 [( H5 [
ASTM-A231/A231M-2004 STANDARD SPECIFICATION FOR CHROMIUM-VANADIUM ALLOY STEEL SPRING WIRE
3 A+ C1 e( r! s& j7 J3 sASTM-A232/A232M-2005 STANDARD SPECIFICATION FOR CHROMIUM-VANADIUM ALLOY STEEL VALVE SPRING QUALITY WIRE
# Q# y# V5 N6 K/ A* ?ASTM-A234/A234M-2005A STANDARD SPECIFICATION FOR PIPING FITTINGS OF WROUGHT CARBON STEEL AND ALLOY STEEL FOR MODERATE AND HIGH TEMPERATURE SERVICE
& o2 r( j+ H$ k% YASTM-A239-1995(R04) STANDARD PRACTICE FOR LOCATING THE THINNEST SPOT IN A ZINC (GALVANIZED) COATING ON IRON OR STEEL ARTICLES5 W& Q" d, ]/ [+ ^8 T" ~$ T
ASTM-A240/A240M-2006 STANDARD SPECIFICATION FOR CHROMIUM AND CHROMIUM-NICKEL STAINLESS STEEL PLATE, SHEET, AND STRIP FOR PRESSURE VESSELS AND FOR GENERAL APPLICATIONS
! M2 f* S9 D P# e8 d( J, bASTM-A242/A242M-2004(E) STANDARD SPECIFICATION FOR HIGH-STRENGTH LOW-ALLOY STRUCTURAL STEEL - AASHTO NO.: M 161
9 A. l5 f6 ]- r7 D" Q1 gASTM-A247-1967(R98)(E) STANDARD TEST METHOD FOR EVALUATING THE MICROSTRUCTURE OF GRAPHITE IN IRON CASTINGS* F3 G: c/ w' O( D- A
ASTM-A249/A249M-2004A STANDARD SPECIFICATION FOR WELDED AUSTENITIC STEEL BOILER, SUPERHEATER, HEAT-EXCHANGER, AND CONDENSER TUBES
5 @; s. c! w- c8 [8 p+ b t# B% tASTM-A250/A250M-2005 STANDARD SPECIFICATION FOR ELECTRIC-RESISTANCE-WELDED FERRITIC ALLOY-STEEL BOILER AND SUPERHEATER TUBES
& Z; r7 S- v6 }" r- U, C) R1 eASTM-A252-1998(R02) STANDARD SPECIFICATION FOR WELDED AND SEAMLESS STEEL PIPE PILES
a) E% g8 \* B2 \/ M8 qASTM-A254-1997(R02) STANDARD SPECIFICATION FOR COPPER-BRAZED STEEL TUBING
$ x% z# |0 ]; g! ~ASTM-A255-2002(E) STANDARD TEST METHODS FOR DETERMINING HARDENABILITY OF STEEL
+ O& r6 \" q% h+ C% p* g1 VASTM-A262-2002(E) STANDARD PRACTICES FOR DETECTING SUSCEPTIBILITY TO INTERGRANULAR ATTACK IN AUSTENITIC STAINLESS STEELS
* w2 M) J2 t5 TASTM-A263-2003 STANDARD SPECIFICATION FOR STAINLESS CHROMIUM STEEL-CLAD PLATE
7 l; n* Q& a' [ a% \% |" s. hASTM-A264-2003 STANDARD SPECIFICATION FOR STAINLESS CHROMIUM-NICKEL STEEL-CLAD PLATE
8 ?1 ^7 Q9 ~/ Y6 G! ~% OASTM-A265-2003 STANDARD SPECIFICATION FOR NICKEL AND NICKEL-BASE ALLOY-CLAD STEEL PLATE& U1 K9 |0 G2 ^/ S/ h
ASTM-A266/A266M-2003A STANDARD SPECIFICATION FOR CARBON STEEL FORGINGS FOR PRESSURE VESSEL COMPONENTS3 x+ P# s5 s5 Y+ O( z' Y
ASTM-A268/A268M-2005A STANDARD SPECIFICATION FOR SEAMLESS AND WELDED FERRITIC AND MARTENSITIC STAINLESS STEEL TUBING FOR GENERAL SERVICE
: A: A8 |7 W4 L. F, l$ w' rASTM-A269-2004 STANDARD SPECIFICATION FOR SEAMLESS AND WELDED AUSTENITIC STAINLESS STEEL TUBING FOR GENERAL SERVICE+ S" D2 N9 A0 S- |1 A. R
ASTM-A270-2003A STANDARD SPECIFICATION FOR SEAMLESS AND WELDED AUSTENITIC AND FERRITIC/AUSTENITIC STAINLESS STEEL SANITARY TUBING, s+ W h$ z3 Y# w9 M2 q/ T
ASTM-A275/A275M-1998(R03) STANDARD TEST METHOD FOR MAGNETIC PARTICLE EXAMINATION OF STEEL FORGINGS
! ? F2 b0 F: O3 M% u- J省略了很多,太长发布不了! |
