查看: 1468|回复: 0
[转帖] 阀门技术英语(1)
发表于 2007-9-12 14:08:29 | 显示全部楼层 |阅读模式 来自: 中国广西桂林
1. 阀门种类术语
8 V  n& l+ \8 _/ k" F$ y& r) W2 }Angle Stop Valves     角式截止阀   & n+ U& x7 a  g+ }( I
Angle Throttle Valves     角式节流阀   " C7 ?) H3 w9 u' Y0 I
Angle Type Globe Valves     角式截止阀   9 J9 I* q' s1 u8 ^# T* ?* L
Butterfly Type Non-slam Check     蝶式缓冲止回阀
0 U" @. O& s8 f, H6 gButterfly Valves with Gear Actuator     蜗轮传动蝶阀
& v2 ~: o0 P$ R  {2 OCock     二通   # f! [$ q% R; H; p
CQ Thread Ball Valves     CQ 螺纹球阀
- h1 Q: k$ W' [% b6 L% N( Z, B9 cDiaphragm Valves     隔膜阀   - {+ I% X, D8 Q& h9 y
Double Disc Flat Gate Valves     双闸板平板闸阀
7 V( k6 l9 s- v$ Y3 w* o3 n4 H; |Double Disk Parallel Gate Valves     明杆平行式双闸板闸板   ) j; S3 T  v( n8 ^3 {- b
Double Opening Exhaust Valves     双口排气球   / y, A. N/ S6 R
Electric Actuated Stop Valves     电动截止阀   8 W5 j- V, C4 b
Electric Actuated Wedge Gate Valves     电动楔式闸阀   3 u0 }4 a8 N. y
Electric Double Disk Parallel Gate Valves     电动平行式双闸板闸板
; |( D- ~# }+ L- |- G& ?; LEmergeny Cut-off Valves     紧急切断阀
: E& K" Z3 E/ w$ d. M# V2 x/ \" LFree Float Type Steam Trap     浮球式疏水阀   " u/ o, Q- ~# Q! l
Flange Ball Valves     法兰球阀   ! w# M% H7 [  H2 U5 ]* H# s
Flange Gate Valves     法兰闸阀
5 ^9 h. x! r; f- y. B! |& IFlange Globe Valves     法兰截止阀   " B7 k, j1 ~7 Y
Gauge Valves     仪表阀   - L: _/ M2 b. M# p8 w9 V
Hard Seal Butterfly Valves     金属密封碟阀   % U- X, p- j# p8 z( A
High Temperature Pressure Power Station Gate Valves     高温高压电站闸阀   6 S$ V3 _% R3 n/ E8 I$ z9 h
High Temperature Pressure Power Station Globe Valves     高温高压电站截止阀
2 s( ]9 \) g, r5 W0 z( ~Lift Check Valves     升降式止回阀   & }# `. j" }% B) U4 d; u. T
' |3 O5 Z1 e1 I/ Q7 x& Q8 JLining Ball Valves     衬里球阀
: S1 O% J; V% Q9 F( _7 ]( }& f' O8 qLining Butterfly Valves     衬里碟阀
: r& U9 F2 U) t/ {) BLining Check Valves     衬里止回阀
( k/ Z5 r8 |" y. s" fLining Cock     衬里二通
7 ?: Y3 k' Y3 DLining Globe Valves     衬里截止阀
  r5 u: A  M3 D9 d# D2 Q) f( Z# {! oLining T-Cock Valves     衬里三通旋塞阀
- c* e8 q2 X% cLiquid Indicator     液位计
& c- g( w! ]& _( R3 J2 C  }/ VLPG Pipe Fitting     液化气管件   7 {$ k" m9 Q9 t5 B
Magnetic Co-operate Globe Valves     磁耦合截止阀
2 M. F' R# M+ ]2 }Magnetism Forle Pumps     磁力泵
9 B1 x7 v  u0 b" q. k% tManual Oil Pumps Valves     手摇油泵 ( 阀 )
9 F) v! {" P( d, k3 B6 A7 TMeter Needle Type Globe Valves     仪表针形截止阀
# ]+ e$ ^9 b! i& y% U' ?0 F* ]0 zOblique Stop Valves     直流式截止阀
6 v0 Z. @) v6 }# Z2 GParallesl Slide Valves     浆液阀   9 s* {' p, e# {5 g+ ~
Piping Centrifugal Pumps     管道离心泵
, i2 o; o1 @- d+ [4 h- }8 ~Piping Pumps     管道泵
" m+ v0 c) a! }" ]5 C- {( f  o1 F! uPiping Safety Valves     管道安全阀
6 F% t# ~/ r! bPlunger Globe Valves     柱塞截止阀
# U) J- ]& i4 m2 F  OQuick Draining Valves     快速排污阀
1 I' h5 E% w) k0 Q, p: QRestrictor Valves     过流阀 ( 或节流阀 )
