刘瑞玲 王丽娟 魏情 李志勇
摘 要 介绍了一种以漂珠、附加保温材料和水玻璃粘结剂混制而成的保温冒口套。验证结果表明:该冒口套具有保温效果好,寿命长,价廉,制作工艺简单,是进口冒口套的替代品,具有推广应用价值。0 k0 P f1 t# `$ K$ l+ ]: l& f
关键词: 保温冒口套 金属型 铝活塞
Research on Insulating Sleeve for Aluminium Alloy Piston by Permanent Mold
Liu Ruiling Wang Lijuan' I" a; R- R* }: G9 @
(Hebei University of Science and Technology)
5 Q# l3 B7 J- Y$ A4 R u6 L! [Wei Qing Li Zhiyong m- W# m& {, n
(Shijiazhuang Internal Combustion Engine Parts General Factory)
ABSTRACT A kind of insulating sleeve combined with hollow particles, added insulating material and sodium silicate adhesive is introduced. Test results show that it has the advantages of good insulation effect, long life, low cost and simple making process. It is the substitutor of import insulating sleeve and has widely applied prospect.1 U3 U: T) ]: ?/ q1 z
Key Words:Insulating Sleeve, Permanent Mold, Aluminium Alloy Piston
用金属型铸造铝活塞时,以往我们采用活塞头部朝下,上抽芯等方法,其工艺出品率仅为40%左右。河北某厂引进德国马勒公司的浇注机生产铝活塞,采用的是下抽芯方法,活塞头部朝上,并使用保温冒口,工艺出品率高达82%。但进口保温冒口套价格昂贵,且常因供应中断而影响生产。为此研制出了一种新型金属型保温冒口套,它不仅具有良好的保温性能,且寿命长,有足够的耐火度和一定的韧性,材料来源广,成本低,使用方便,无污染。
