发表于 2007-10-9 09:16:59
来自: 中国江苏苏州
CF STEEL 中 CF是指Cold Finished,是钢材的交货形式的一种,) S6 Q5 i+ e! j% f+ I9 ^- \
The general term for steels that are otherwise finished are "CF" for cold finished. CF steels include cold drawn steels, centerless ground and "pickled and cold rolled steel" and sheared and edge rolled steel. Most steel service centers use the CF as a general indication of the steel's finish as their inventory often varies between different processing methods.$ }0 [* B b* f" j
: ~1 @9 m& P' J& C" F& H3 `与之相对应的是HR steel ,就是hot roll steel,
/ g3 n, r: |* b- l; yAny steel, alloy, low carbon or high that is rolled at the mill and left with the scaled finish and in the "as rolled" condition (not heat treated) is "hot roll steel",HR Steel or HR bar. In the past "mild steel" HR bar was SAE 1018-1020 but today common HR mild steel is structural grade ASTM A36 or similar. |
