查看: 1655|回复: 4
[已解决] NX 4 高级仿真计算结果后,出现一个错误
发表于 2007-10-27 04:20:44 | 显示全部楼层 |阅读模式 来自: 德国
NX 4 高级仿真计算结果后,出现一个错误,以前都没有过的' ^3 n* [/ P% {* S
下面是我的Info$ @7 r2 Q  |6 e
      Solution Model Setup Check Error Summary
! y  |8 r1 y6 x( C+ q; [* ~/ U1 R7 t( l) y, B
7 f0 S! h, {6 U, E
7 L1 p1 z5 Y9 l6 M& A, ?Solver ist NX NASTRAN
5 b* \) B  x& i+ c) L0 Y! B" J3 J7 V/ ]$ T# m
Umgebung: NX NASTRAN - Strukturell! }0 T& b7 M, _
2 h2 _. i5 T+ l8 [6 v1 \
Lösung ist SESTATIC 101 - Einzelne Zwangsbedingung
. Q( s) C& j7 _3 E: f1 m. r% O4 U* u# f% w  w  z+ {
- `! m- i4 {% h, c- N- M2 C" w
% o  ]: D$ [. n+ j# b) d$ MMesh-Based Errors Summary
0 {: K% z6 M) l0 ~5 T+ l# ?5 f-------------------------
1 F1 w5 T1 Q5 {: l9 t! a
* [1 i9 e1 r  U; u/ ?* gTotal: 0 error and 0 warning
( R! K- Z. Z0 d0 n6 w& V* a1 j) Q* f+ x: R6 ~% \& T
) T$ o( Y% i) Q0 z4 YMaterial-Based Errors Summary% k9 Y7 v% U9 R6 ]; h+ c4 y
; v% v+ V6 _; c. `: H5 j
5 u/ h8 \- V2 ]9 _2 m" {Total: 0 error and 0 warning
8 e7 N% p* l- G( Z+ k# b. l% P$ y3 c4 ^! B
) ~/ P6 C& u( I6 }& v
Solution-Based Errors Summary9 z* `' C4 [0 I0 F
-----------------------------; A) V8 R# O1 a: b. M8 L# B1 b
' \0 N, d% o# c. N% v* M% A$ BERROR in step "Subcase - Static Loads 1"8 I2 u* M# P; R9 A! t/ L1 C
This step requires loads, enforced motion constraints or external pre-loads to be9 l; y$ U7 L  |5 T) W# Z/ m2 X% g
applied.  None have been assigned for this step.) r, {  L$ p8 [9 q
) P/ ^5 A- p+ E, o  a
Total: 1 error and 0 warning
. O/ k8 V5 F8 a- c6 R0 q1 t8 l6 c0 i" M9 F1 x+ Q# j+ l. v
  C1 T/ C3 [/ [, T: A) u
Load/BC-Based Errors Summary* L* Y0 a! h; l# n7 H5 e
----------------------------* k3 g0 ~3 J8 k0 a6 b5 \$ S' {
3 c5 J) ?! @- n$ [0 v! C  b: W# X
Total: 0 error and 0 warning, b3 c8 ~: M4 e) C
* c5 w* j. Y: ^  }2 G& n* ^# \
NASTRAN Model Setup Check completed9 _. O# B8 ]  j1 M* I9 ]9 i
/ A' q% _1 G) S9 t  O. ^, I2 B* H* m5 l8 ^7 y/ s" O
谢谢大家解答
发表于 2007-10-27 07:13:52 | 显示全部楼层 来自: 中国江苏南京
This step requires loads, enforced motion constraints or external pre-loads to be, C+ d/ H/ {' ~! g
) D" v6 z9 G! n该子步需要添加载荷,位移约束或者外部预加载
发表于 2007-10-27 08:05:20 | 显示全部楼层 来自: 中国山东潍坊
你可能没有安装解算器或者你的设置有问题!
 楼主| 发表于 2007-10-27 15:09:30 | 显示全部楼层 来自: 德国
thanks
版主好,最奇怪的是,我之前运行得很好啊4 @; S& e; d* f+ z; F
9 |  Q0 V9 \9 D4 h你说,有没有可能正常运行情况下,内部设置就被损坏了??
 楼主| 发表于 2007-10-27 15:11:44 | 显示全部楼层 来自: 德国
谢谢你
原帖由 心野 于 2007-10-27 07:13 发表 http://www.3dportal.cn/discuz/images/common/back.gif
" I% v3 p) {/ O0 ?- N: ]8 \7 FThis step requires loads, enforced motion constraints or external pre-loads to be1 T6 \2 K  \) |
applied.  None have been assigned for this step.7 O9 [  Q" ?* J' y
8 G' J  i7 u; Z. s* B
( k- ?4 O7 P/ i' a# n9 ]4 s1 L9 n" \: u4 f! u) ?
; P  |9 l7 j: z6 h* j2 [) }) f' i( w
9 K3 L5 i* h3 L- Y' @
+ A1 ]4 h. q: n# O- X谢谢a ,可是我之前没出现过这种情况
3 @* A/ K0 l' a* S# [& \! g" y. `  m! V) s
而且载荷和力,我都已经加过了
