查看: 1650|回复: 3
[分享] 钢的英语名称
发表于 2007-11-2 09:56:25 | 显示全部楼层 |阅读模式 来自: 中国湖南长沙
metallic material金属材料
/ s0 y5 n6 P2 e, D. Xferrous material黑色金属9 `9 y- w$ q8 S2 V, ~
steel钢
% r9 E6 A5 ~1 p1 I: p- B/ fstainless steel不锈钢
7 P9 I$ O: M. X% @% {: R) E% {low carbon steel低碳钢
4 \, o! S/ O" z) ohigh-alloy steel高合金钢
* v' |6 x" {9 v- z7 _( v1 n+ x8 Phigh-grade fine steel高级优质钢. }1 k2 U, X# G: h- ]
high-grade fine carbon steel高级优质碳素钢
- h, f' R, u1 W% Vhigh-manganese steel高锰钢
* Q8 n$ M. ~$ A  u- h, xhigh-speed steel高速钢6 @+ d  P/ f/ @% W; i! l% Y6 E0 D3 Y
high-speed tool steel高速工具钢9 s  F9 r- r, L
high-carbon steel高碳钢
9 z! u# Z/ y. U* Wtool steel工具钢
; |; Z' l7 P  z3 M4 P6 Sball bearing steel滚动轴承钢9 O( y* t1 @, G* T7 v
alloy steel合金钢
2 z* u  `* A0 @4 u6 p% Htool alloy steel合金工具钢8 u6 H  A, s) q: n3 ?8 B, Y
structure alloy steel合金结构钢
' y$ |1 y7 b! m# |structure steel结构钢8 m' z* r9 q- e) [7 ~
oxidation-resistant steel抗氧化钢
: `" W, z4 r$ c/ ^, l" H1 B7 Vcold-work mould steel冷作模具钢
! P9 O) d# r6 O5 E- ygauge and cutter steel量具刃具钢2 f3 X0 O+ J: V( g* z
shock-resistant steel耐冲击工具钢
, e- Q( q0 B6 v$ y( |wear-resistant steel耐磨钢. m5 O# r* l/ n) R
heat-resistant steel耐热钢6 f# P/ O0 ^9 P; e, ]
plain carbon steel普通碳素钢( z5 g( L/ [7 w3 A- o
hot-work mould steel热作模具钢) x; q5 Y/ P# L6 F% U
heat-resisting steel热强钢
: \+ h; K3 l, g6 s$ |: rcarburizing steel渗碳钢' R; s7 K' C/ e2 |/ S5 l
spring steel弹簧钢
  d2 x! K1 ^1 Ncarbon steel碳钢
& ~% k, L1 @( r" O% u8 o) V( ttool carbon steel碳素工具钢
- b5 x! c. s& F: O' e/ Nstructure carbon steel碳素结构钢5 i# |7 W- [( y6 @3 t. j
special steel特殊性能钢- y8 n" ]% s! c& S- o
quenched and tempered steel调质钢; U  y4 B& j9 R& R: O: [
fine carbon steel优质碳素钢
- Q2 K1 s6 N: G& j* X! irolled steel轧钢9 i& m% _% v, o( w0 \( e
medium carbon steel中碳钢
发表于 2007-11-3 08:02:18 | 显示全部楼层 来自: 中国浙江宁波
steel 和 iron 是什么区别?
发表于 2007-11-3 09:37:16 | 显示全部楼层 来自: 中国重庆
大晕,钢和铁的区别很大的吧。& a  @) k: U# Y2 i  f) i
2 N8 l6 i, {7 k$ v& M
原帖由 xiaolaogong 于 2007-11-3 08:02 发表 http://www.3dportal.cn/discuz/images/common/back.gif' ~5 H1 r, U$ [4 t1 T+ l! F) c
steel 和 iron 是什么区别?
发表于 2007-11-3 11:00:18 | 显示全部楼层 来自: 中国北京
钢和铁的区别很大的吧!不太大,就是加点碳或其他元素,归根揭底都是一个娘,就是价格相差大典! :lol:
