Calculation of air volume conforming with safety and hygiene standard 卫生通风计算
+ ~8 ]+ `) H- q$ f/ ?, h0 N+ ^The minimum air volume per minute for 1 kg of consumption of paint or thinner is given in the product technical data sheet. During practical application and drying, the air volume conforming to TLV can be calculated by the following equation:2 a+ f3 ] {5 T" f* U9 x
在产品技术资料中给出了耗用1kg油漆或1kg稀释剂一分钟内所需的最小通风量的数据。在实际施工和干燥过程中,要达到TLV所需要的通风量,可以由下式计算:
' Q- h" w4 z8 \/ F$ v$ YV (TLV) =(P×M)+(Q×N)÷t Where, V (TLV)= air volume conforming to TLV (m3/min)
5 Y" [$ ~# Q$ d1 T: ^式中, V (TLV) ——达到TLV所需的通风量( Z0 n. w" y' o. r+ z
P= consumption of paint (kg)
$ n7 v( F+ v" w* b y 油漆的用量6 c6 p7 T/ w Q' z+ w" k# h7 v! }
Q= consumption of thinner (kg)
+ ]2 J+ I( ]$ Z# m 稀释剂的用量
/ w" |2 j+ t* G; ]- _M= minimum air volume conforming to TLV for 1 kg consumption of paint (m3)) _3 n6 Q9 ^' W/ I* x
用去1kg油漆达到TLV所需的最小通风量
8 n, h& Z( l; R9 G/ l; EN= minimum air volume conforming to TLV for 1 kg consumption of thinner (m3)! d) }% l1 o# n# {2 e( ^
用去1kg稀释剂达到TLV所需的最小通风量5 w& G: V0 J; R: X7 H( y: {
t= time for consuming paint and thinner (min)9 s/ M" R# T' P) J0 Q; v: T9 F
消耗油漆和稀释剂的时间
& Y3 b, e& \/ c# K1 B) JExample, if t is 30 min., P is 50kg, Q is 4kg, Q is 2kg, M is 800m3 (shown in the product technical data sheet) and N is 2200m3 (shown in the product technical data sheet), the air volume conforming to TLV can be calculated by the following equation:
& r' x$ S# h2 F计算举例 在30min.时间内(t),用于50kg油漆(P)和2kg用于稀释油漆的稀释剂(Q),M值为800m3(从产品技术资料中查得),N值为2200m3(从产品技术资料中查得),则施工中要达到TLV所需的实际通风量为: m" E* K4 W8 v6 |4 j: m1 T
V (TLV) =(50×800)+(2×2200)÷30=1480m3/min. 5 S3 J# z7 ]! Z* c2 e
以上内容摘自下面链接
5 D$ b! G1 I) I我看了后,感觉应该是涂装的安全通风量。 |
