玻璃漏斗 Glass funnel long stem
9 b8 ?/ ? d" z1 S% P I试管 test tube test tube brush test tube holder test tube rack$ }; g. K% h0 m, W+ r* ?" A
蒸发皿 evaporating dish small) d2 q0 U- e; f7 C
烧杯 beaker! _8 ], F* y" O6 s4 M* n. h
锥形瓶 Erlenmeyer2 \/ Y2 z2 |! }" c
量筒 grad cylinder" _8 l5 X9 j9 }& K: r
洗瓶 plastic wash bottle4 s Y V$ j# S9 u9 A! Q+ d# e# H
勺皿 casserole ,small stoppered flask : x9 u5 I4 _% b! H( `
分液漏斗 separalory funnel# R& }0 M8 \2 Z! a
warter bath/oil bath4 k- {& M/ p' O# m& T7 d
strring bar9 z7 X+ i2 X' t! E% C
magnetic stirrer/ R4 Q- n6 K9 P$ s+ V
冷凝器 condenser
6 [4 ^# `. n" \- PBallast bottle8 F( M# c/ ~/ [. f/ D" A4 P
圆颈烧瓶 Round-bottom flask! `0 _& T' o+ W' e7 f# e
试剂瓶 reagent bottles ; F9 J* x4 S" p; c# S& [
托盘天平 platform balance 台秤. c4 S5 U: v Z3 o- X8 W3 @
0.1g 托盘pan 指针刻度表pointer and scale) K" D: }: V. w6 h. v6 S7 z, p
crossbeams and sliding weights 游码/ d9 w Y6 _% o! W* @7 V# a1 g
分析天平 two-pan/single-pan analytical balance7 r O% x( N/ i1 u5 o
滴定管 burette glass bead(basic) nozzle
4 y2 T+ ?: j% Q; Y移液管 pipette 胖肚 elongated glass bulb ( ?0 b1 w) B. I0 x' |
洗耳球 rubber suction bulb
5 z9 J: |: g: E" `, K玻棒 glass rod
! B$ h5 }& u( b0 Y! I* r1 J: r3 m. \玻璃活塞 stopcock
: c% v8 T+ G4 r! n# X容量瓶 pyknowmeter flasks
- Y! ~4 ]5 B, m比重瓶 (one-mark)volumetric flasks K. J0 ^. j; D' i# o
胖肚吸管 one-mark pipette. }' T+ }1 q8 s. D) c+ _0 E
刻度吸管 graduated pipettes
{9 l9 L4 H* `9 Z# P锥形瓶(conical flask) 250ml×4 药匙(medicine spoon)×1
' k, @/ `8 Y1 J6 B(Erlenmeyer flask) 100 ml×3 滴管(drip tube;dropper)×2
; M& u+ h6 b* X5 q: \% D烧杯(beaker) 500 ml×1 玻棒(Glass stic)×2
6 z, d/ N) Y# W( v250 ml×3 木试管夹(test tube clamp;test tube holder)×1 ( x, B0 k! S3 a4 h2 ~
100 ml×3 胖肚吸管(straws) 25 ml×1
6 u% V7 j( n6 f G' G0 v5 e50 ml×2 10 ml×1. z( s* M; ^) A+ }9 o. g% w
容量瓶(volumetric flask) 100 ml×2 乳钵(morta)×1/ u/ n' G) E# i E. `) ?* E
50 ml×4 洗耳球(ear washing bulb)
+ |' J+ T; r0 Z( }9 m, @' q0 _ R碘量瓶 (Iodine numoe flask; iodine flask) 500 ml×39 O% e/ m. e2 c: R/ ?
试剂瓶 (reagent bottle) (无色)×2: G$ X4 f: G+ p0 `, m" K
(棕色)×2 配洗液:; J! j- k- w8 I& r! O1 J
量筒(cylinder) 100 ml×1 K2Cr2O72g+5ml水→65mlH2SO4
/ W; M; @" g# p. D) }) Y( o# V; J(graduated cylinder)10ml×1 边加边搅拌(stir)。
1 K& ]! j' R% ^9 h3 R- V& c铁支架(siderocradle)+蝴蝶架
Z0 x$ T4 h' U' q1 F; D6 c白瓷板(White Porcelain Board ) (一)清点仪器(to count;to make an inventory)
! Q( t0 D! U7 y( _ k4 Y' z酸式滴定管(Acid burette) 25 ml×1 配洗液 (Lotion)
# W1 Y& O S* |7 B碱式滴定管(Alkali burette)25 ml×1 一般仪器的洗涤
- w5 @6 j1 ?9 P% A% Y直型冷凝器(rectocondensor)×1 容量瓶(volumetric flask)
. ~# O* L$ r9 ^3 N* m) i; h. c漏斗架 (funnel stand) ×2 移液管(pipe)
0 F* n2 Q, ]6 g6 p! @水浴锅(water bath kettle) ×1 7 M* q! Q+ }# l2 x
温度计(Thermometer;hygrometer;hydroscope) ×1
* [! S S1 l9 u) P- I y7 H电炉(electric furnace;electric hot plate;electric stove) 四人一个 6 P, y) ]2 Y! z- g3 ~# W
分析化学:analytical chemistry' L1 m2 n. Z( X, L
定性分析:qualitative analysis+ s% ]/ S5 Q9 p( H5 Q: L
定量分析:quantitative analysis
: Y& R+ n6 M$ [% f+ i物理分析:physical analysis2 {0 H' C, i, e5 m3 h
物理化学分析:physico-chemical analysis
" F; Q+ J3 I4 s; k8 C$ `) `6 e仪器分析法:instrumental analysis
% ?: F: Z0 u: u1 @' d. Y流动注射分析法:flow injection analysis;FIA4 u+ @3 ^4 D5 E U$ w! F
顺序注射分析法:sequentical injection analysis;SIA' z. T2 J: y' J$ l
化学计量学:chemometrics
0 Q- [/ Z7 I4 b1 D" t1 a0 U5 H绝对误差:absolute error
* d! e# [" d$ K0 B. ^8 e3 Q相对误差:relative error
( l4 N9 ?7 V |/ S* @系统误差:systematic error( a! [0 R$ C. _( S
可定误差:determinate error
& T+ z- u0 f4 K" g随机误差:accidental error P" S B$ R! [* |$ \* R
不可定误差:indeterminate error
. d3 e" s/ X$ {: i" n准确度:accuracy/ U1 u5 r( D& G/ x9 x
精确度:precision5 N7 B/ ?+ Z4 A7 m
偏差:debiation,d
; {6 s9 d. {$ ?& ^8 l平均偏差:average debiation
) O N- X( Y& @ F相对平均偏差:relative average debiation5 D l* ?8 {/ F5 R
标准偏差(标准差):standerd deviation;S8 { |! ], D7 N# ]2 v' G
相对平均偏差:relatibe standard deviation;RSD
q+ G! C) v9 F4 l6 k' b7 G" Q变异系数:coefficient of variation
3 o4 E. |7 B# K! Q误差传递:propagation of error; x. t) a' o D+ [9 B8 O4 O
有效数字:significant figure
- v9 E, Y2 b! E) n& ]- l* E置信水平:confidence level: ]& E, Y" ~; x4 }- @
显著性水平:level of significance
$ a- Z6 \ [! U合并标准偏差(组合标准差):pooled standard debiation
# X* Z; C5 H1 o) _7 B& Y舍弃商:rejection quotient ;Q " N% e/ V& @5 N5 H
滴定分析法:titrametric analysis) B, F" U* s- ]9 S0 i# Y! B4 q. Z
滴定:titration
* J# o2 H# D/ i7 y容量分析法:volumetric analysis
1 Y1 G( L5 u i' g7 P化学计量点:stoichiometric point
3 c% H, R) T" {% D) [5 j等当点:equivalent point
" m% {3 p# d7 G2 d3 B电荷平衡:charge balance$ E. U8 S s$ m: N. u
电荷平衡式:charge balance equation
4 {$ x/ L+ _' k7 C& T* P5 l质量平衡:mass balance
2 v7 f6 S# [1 s( @$ U物料平衡:material balance
1 B; O* u) g! ^# q7 q质量平衡式:mass balance equation3 r$ V6 l7 L3 f; U: h" r
酸碱滴定法:acid-base titrations, w- [3 ]1 M' J0 r1 T9 g+ R
质子自递反应:autoprotolysis reaction+ C1 b) V" ?/ P% Q
质子自递常数:autoprotolysis constant$ a9 W; G% ^1 O |
质子条件式:proton balance equation
! N" w; I$ [ e: p酸碱指示剂:acid-base indicator
1 K% p/ r, e3 o5 o指示剂常数:indicator constant4 U" r+ s9 m5 a& u/ r$ N* X7 O
变色范围:colour change interval
% _ o) f/ a1 S混合指示剂:mixed indicator4 r" A3 M. [/ q$ W! A T
双指示剂滴定法:double indicator titration
5 P/ z2 K3 j9 A% r非水滴定法:nonaqueous titrations
. A( N) ^3 c" W/ i6 y4 {质子溶剂:protonic solvent
( b2 d+ Y+ Z0 Z2 G: K( ]酸性溶剂:acid solvent
" a% ^) O6 @7 c. W碱性溶剂:basic solvent
/ `# C4 F, _4 ]- v5 Z% _两性溶剂:amphototeric solvent 8 O, K) E$ m1 ?5 \
无质子溶剂:aprotic solvent
2 |! m5 l1 C) F' v6 r$ H0 t/ A均化效应:differentiating effect
! f2 X; I1 c/ Z3 S7 Y" p区分性溶剂:differentiating solvent p" R% g) ^" K3 ^, |0 y. k
离子化:ionization4 K0 f7 a2 r3 u( H6 b) e. `
离解:dissociation
1 h3 u7 P" E7 u# c5 R结晶紫:crystal violet) ~7 ^. [* Y6 V- W- n
萘酚苯甲醇: α-naphthalphenol benzyl alcohol
5 @5 o+ K$ t' E/ J- t1 n) P奎哪啶红:quinadinered6 Y+ e1 b2 M j* P1 U% E6 T
百里酚蓝:thymol blue
5 u! K7 B# n6 y* W偶氮紫:azo violet+ G- ?5 T g& G: y9 K
溴酚蓝:bromophenol blue
+ s' K; |, {5 n6 e9 O1 ~0 y配位滴定法:compleximetry! I; ^ T* ?% p+ T' j5 e, l
乙二胺四乙酸:ethylenediamine tetraacetic acid,EDTA
$ i, w8 d3 ~5 f1 I2 P5 A( R螯合物:chelate compound
& Z3 U4 i9 r1 Q. J$ k' H金属指示剂:metal lochrome indcator
/ e# U |9 O7 Q8 z/ a3 v氧化还原滴定法:oxidation-reduction titration
; E# s& o1 D" d) U碘量法:iodimetry
$ W- e d! G' b' b. K$ y溴量法:bromimetry ]4 S9 z5 L# z( ^' @1 E* D) Y; Y
溴量法:bromine method6 u7 o+ A+ t. _
铈量法:cerimetry2 g! s* c3 b; \+ ]) O2 g2 Z. h
高锰酸钾法:potassium permanganate method
6 c, E$ D$ X% p7 O- k' W* \7 b# s条件电位:conditional potential
& W5 f0 b; R0 h8 c$ g5 ]. b( ^ X% t溴酸钾法:potassium bromate method' G, |) C& h% ]# b r
硫酸铈法:cerium sulphate method
5 {; F" }4 Q& f2 H- H, ^$ T偏高碘酸:metaperiodic acid% T4 a# n0 Q8 @
高碘酸盐:periodate$ a8 N7 [+ m' x8 Y- Z; J
亚硝酸钠法:sodium nitrite method
$ l6 Y* F: L q' K重氮化反应:diazotization reaction
( ~1 j% [ _* B5 Q$ U3 W重氮化滴定法:diazotization titration# f( {. y k5 C
亚硝基化反应:nitrozation reaction$ g7 z6 {; B$ ~/ x
亚硝基化滴定法:nitrozation titration; {7 e" O% Z+ y! }0 s# b' r/ b
外指示剂:external indicator
: O% `6 S% e" N: P外指示剂:outside indicator
- G8 I9 |: h+ G2 h重铬酸钾法:potassium dichromate method1 g* l. U9 ?; V- `7 m. I o% z
沉淀滴定法:precipitation titration) ?* l9 f7 p9 W# o
容量滴定法:volumetric precipitation method
2 C9 Z( b2 {( S6 }! L银量法:argentometric method$ A8 A5 k7 W u/ r# F
重量分析法:gravimetric analysis
; M4 I4 C# B& X挥发法:volatilization method. h6 z* G9 y1 c4 [6 L7 r
引湿水(湿存水):water of hydroscopicity
, m) [2 \% `7 n( j4 b5 o5 \包埋(藏)水:occluded water
7 P6 M& N7 E" _. ~0 w: W( a吸入水:water of imbibition
. O& f: F! f: K( N# p+ o, x/ i结晶水:water of crystallization! ^) \0 p) t) D8 V
组成水:water of composition' y9 s& P9 b/ _! G
液-液萃取法:liquid-liquid extration
. U* q$ p- _. K0 h3 Z溶剂萃取法:solvent extration
3 z: ^6 M% `3 g% ]! c0 k0 p反萃取:counter extraction+ S2 O2 o* h& M) t
分配系数:partition coefficient3 c& X/ ? A( P$ N, p& _
分配比:distribution ratio
5 F- F! {( [% @ D% |- h离子对(离子缔合物):ion pair
, }, ^7 I. q6 F沉淀形式:precipitation forms
8 J, a# u8 @! P' ~' |. {! u, J称量形式:weighing forms: F0 N* l4 U7 d: \0 f+ J
8 |( b* V! S9 n, m4 D物理化学分析:physicochemical analysis8 ~! Y- ~' ^- y6 y9 b- e
仪器分析:instrumental analysis& ]1 n- ]. G7 e3 m1 J- H9 ^6 E5 O
电化学分析:electrochemical analysis
& N* l. y% V- M( R8 w: } _电解法:electrolytic analysis method& W' ]! k$ O7 u& x# r
电重量法:electtogravimetry6 v* z3 W2 I" w W5 S; z2 I; X
库仑法:coulometry* A* K. ~7 |3 k
库仑滴定法:coulometric titration7 V5 U0 ?6 w/ C3 J+ D0 K+ M3 A
电导法:conductometry
: ~4 Y8 t8 H3 @0 ^电导分析法:conductometric analysis
\" k/ M/ R9 G) q电导滴定法:conductometric titration
9 X& ?+ q0 h& Q% v6 P' ?电位法:potentiometry# [0 a# o% ]2 R# x# e% l) I# K
直接电位法:dirext potentiometry
0 E8 z8 p" S1 k% r# ^* ^电位滴定法:potentiometric titration( E$ E) ?# [ { D; X
伏安法:voltammetry- s, S Y- K* r& j! T* E
极谱法:polarography
% W8 l- K7 U" U溶出法:stripping method
/ N% m+ ?5 Z/ R1 ]( V8 m电流滴定法:amperometric titration
/ P6 i* @2 o4 ~" K y化学双电层:chemical double layer* C" I' n# x7 Z" h5 |" B
相界电位:phase boundary potential9 J; ]( [& v( Y
金属电极电位:electrode potential% Z, Y/ [+ M# l
化学电池:chemical cell
# `- d: \8 ]# D液接界面:liquid junction boundary
2 ^, j0 G: W2 T4 P) @原电池:galvanic cell
6 V- o( S0 H Y, ?6 d电解池:electrolytic cell8 w1 a5 I1 w- A8 C/ `6 y% ?* H
负极:cathrode$ b m2 R0 a1 a/ D( l
正极:anode
8 L; z% u j- e1 M电池电动势:eletromotive force" C. v" @+ Z: S: R
指示电极:indicator electrode2 k$ z. S5 d* e3 V9 } c$ J" p
参比电极:reference electroade# |" W* a5 r% p2 L1 L' ^
标准氢电极:standard hydrogen electrode# j. o7 T7 Z% R& U
一级参比电极:primary reference electrode& i) D2 `3 e& z8 v, }; z! p6 E( q) O
饱和甘汞电极:standard calomel electrode
: |& k7 z$ a, |& @8 L银-氯化银电极:silver silver-chloride electrode
$ B) h) D0 c0 S# G. o2 Q7 O液接界面:liquid junction boundary! I4 L5 V0 w: d# s* T
不对称电位:asymmetry potential! V+ K- F8 f# n% c1 y$ z) \
表观PH值:apparent PH
( e0 \8 y( y9 H- p$ o, Q4 @复合PH电极:combination PH electrode
2 L& A1 {' e. p1 A! r% a离子选择电极:ion selective electrode
2 ~! I6 T' Z5 |+ T敏感器:sensor
& W1 R2 x/ [8 k5 ?4 L' W晶体电极:crystalline electrodes
* Q% ?: v! F# m均相膜电极:homogeneous membrance electrodes
* @" E1 O0 L2 U1 S* E3 _1 d非均相膜电极:heterog eneous membrance electrodes% V- K6 {- z. `' D1 G0 k/ }
非晶体电极:non- crystalline electrodes
- ~5 u" j5 z5 E0 B6 k& E) |5 w2 k* K刚性基质电极:rigid matrix electrode2 J9 J% S# @/ E& z6 S5 E
流流体载动电极:electrode with a mobile carrier
# ]" A7 b" O0 J* ~气敏电极:gas sensing electrodes1 R0 q) e1 q0 q$ f+ k
酶电极:enzyme electrodes' {% L) |) N- S {% a
金属氧化物半导体场效应晶体管:MOSFET V4 b3 {- h( H
离子选择场效应管:ISFET7 W) N6 @0 G6 q3 }! n' v% d9 D& R
总离子强度调节缓冲剂:total ion strength adjustment buffer,TISAB+ G4 a4 ?1 q5 D0 y# r
永停滴定法:dead-stop titration
: \/ t6 b |+ g# s, a双电流滴定法(双安培滴定法):double amperometric titration
$ f; a8 S' s* P. E9 F9 T普朗克常数:Plank constant2 j4 K2 p# v* Y2 D/ p' S/ n( k5 R
电磁波谱:electromagnetic spectrum
: r2 X, Q& ^1 ^! Z+ c4 S% g光谱:spectrum$ b; I, H( Q F3 F. h; {( Z
光谱分析法:spectroscopic analysis7 t- _# k6 g) p# r4 ~% y
原子发射光谱法:atomic emission spectroscopy5 [; E3 {. l4 H" [4 p0 y( K
质量谱:mass spectrum4 Q! L' c+ t7 n& S
质谱法:mass spectroscopy,MS
! J. d7 W: F" G' @0 V% P. S, O+ d紫外-可见分光光度法:ultraviolet and visible spectrophotometry;UV-vis3 E% l, K; Y# l u5 f
肩峰:shoulder peak5 z+ d5 U1 {# `' E6 g2 r
末端吸收:end absorbtion1 K, C/ K- H" G! G5 z, V4 E4 Y
生色团:chromophore8 Z6 K! b b: x& q8 c
助色团:auxochrome( I- ^$ D- o' C9 \
红移:red shift I4 g" @; ^3 W# ~. \4 P
长移:bathochromic shift
; e' o" r5 K5 e短移:hypsochromic shift
1 i4 `7 \# Y' K蓝(紫)移:blue shift
# {6 ]" z3 U+ a/ A* Z增色效应(浓色效应):hyperchromic effect8 Y6 h$ y0 o5 h# k9 L
减色效应(淡色效应):hypochromic effect
* l; q( J& u8 |( c9 g* Z0 `强带:strong band9 |4 d& [# S: y! Z! w7 V/ O% z& M" @
弱带:weak band2 Z! }) u0 V" F; i5 o
吸收带:absorption band
; |& ?/ G4 o) a$ ]8 i: O( ~透光率:transmitance,T
# w! J% G# u, B吸光度:absorbance6 d! `5 Y" v1 O1 A
谱带宽度:band width
8 f) X: G, G# ]0 V7 ~9 p; e6 }杂散光:stray light
8 z: m( \' H& D噪声:noise 8 U) F0 u8 t# U( k5 @; W
暗噪声:dark noise4 [8 e. L/ x; h
散粒噪声:signal shot noise1 `9 h# ~* @- z0 M3 I4 U0 R+ z
闪耀光栅:blazed grating
) Q* `4 U# }/ b! w# O- K! W) p! @全息光栅:holographic graaing+ d1 t; |1 k. b* \. T
光二极管阵列检测器:photodiode array detector
~* i" Y8 I3 V1 M# L Y偏最小二乘法:partial least squares method ,PLS
" C/ U& ~% d. L0 [褶合光谱法:convolution spectrometry
; i4 L) n/ F- A8 d褶合变换:convolution transform,CT \1 Z4 o$ X! s% X" V
离散小波变换:wavelet transform,WT8 j. }0 W) }, f @ j( @
多尺度细化分析:multiscale analysis* ^! @) V& }' ~# q
供电子取代基:electron donating group6 O7 Q; b6 t1 k" W4 d1 _$ p0 T
吸电子取代基:electron with-drawing group! e4 P1 g1 g3 w5 i
荧光:fluorescence, o5 u+ P5 M9 }: F
荧光分析法:fluorometry
; }3 }) l( a* T" `+ n- lX-射线荧光分析法:X-ray fulorometry
, X' O# R8 y9 `原子荧光分析法:atomic fluorometry3 @% {% L5 n8 k6 D
分子荧光分析法:molecular fluorometry+ L- W8 R: h1 E- ]7 d
振动弛豫:vibrational relexation& ^( l& b' e5 l' z! V7 R
内转换:internal conversion
) @( x( Y s; S5 W; x7 M外转换:external conversion5 X6 a/ a+ y& N! E1 ?+ ^" ]- x2 p4 l
体系间跨越:intersystem crossing
. v+ s' z' ?9 f+ P7 I6 @, T激发光谱:excitation spectrum1 V7 e" }/ z# l0 i* `: H. R1 o
荧光光谱:fluorescence spectrum& g }! r8 u$ ^' x2 M: `, _: F* i6 g
斯托克斯位移:Stokes shift
8 W9 D! Y5 ^! f/ A; O/ r4 y/ j; k荧光寿命:fluorescence life time
# T7 A$ g1 _% w荧光效率:fluorescence efficiency* y$ b1 D6 P+ V( [1 o
荧光量子产率:fluorescence quantum yield+ ^" x" K7 p# U0 i
荧光熄灭法:fluorescence quemching method8 O: E% L& s% @9 Y' ~2 u8 y B- Z
散射光:scattering light
* q8 Z: \- r$ @瑞利光:Reyleith scanttering light& J- _- q! q+ z' }( A+ Y
拉曼光:Raman scattering light' T! D4 G: Y9 h
红外线:infrared ray,IR7 }6 V( c4 N6 |1 J. T1 k0 F9 X
中红外吸收光谱:mid-infrared absorption spectrum,Mid-IR0 `% X2 m' z* N4 Z" R' r; q
远红外光谱:Far-IR
, ?3 z; p6 d+ N; u( g微波谱:microwave spectrum,MV
, N. @; k' b" \+ h$ v+ W红外吸收光谱法:infrared spectroscopy
& E3 A* f) m0 A! Q( Q' w( q红外分光光度法:infrared spectrophotometry
! Z, B, u4 L2 p4 z) z振动形式:mode of vibration$ ~+ t3 z4 E) R8 |# G! {$ {- ?. v. P! T
伸缩振动:stretching vibration
6 y( v7 P8 ?8 Y对称伸缩振动:symmetrical stretching vibration
6 b2 f# _, H; U, v1 B/ V; f不对称伸缩振动:asymmetrical stretching vibration9 X9 m! h% d$ N* K. T( p
弯曲振动:bending vibration
. U$ g$ ^+ S! {0 P4 }变形振动:formation vibration- K# \; Q; P1 R6 t F( i
面内弯曲振动:in-plane bending vibration,β: ?- i7 P( {2 }; y Y7 X E
剪式振动:scissoring vibration,δ& d" D. @! b' M5 ]# A1 V( V
面内摇摆振动:rocking vibration,ρ
+ T, W8 x+ w+ N" J# V核磁共振:nuclear magnetic resonance,NMR
, S$ T- l$ A' F核磁共振波谱:NMR spectrum
; J9 [; ]% |* `' x核磁共振波谱法:NMR spectroscopy
# i6 v7 C5 V' o. Z: h c5 H. O7 w扫场:swept field* d) ~, S: J5 F6 z7 ]* g
扫频:seept frequency3 ^1 A) v3 | Q9 k4 f: _
连续波核磁共振:continuous wave NMR,CW NMR
- G$ v5 o4 f% u- d, b7 w+ RFourier变换NMR:PFT-NMR,FT-NMR
' t1 D- c, Z" t% p& b二维核磁共振谱:2D-NMR$ c6 p# R8 e# Y0 ]
质子核磁共振谱:proton magnetic resonance spectrum,PMR5 p; t9 r' r1 @& C' y
氢谱:1H-NMR
9 d0 d5 k& X" s7 V碳-13核磁共振谱:13C-NMR spectrum,13CNMR. Z8 V" y- @$ j& e3 j4 |* j2 G
自旋角动量:spin angular momentum |
