查看: 3727|回复: 4
[讨论] 谁能提供Heidenhain tnc530i的UG后处理
发表于 2007-11-23 16:11:18 | 显示全部楼层 |阅读模式 来自: 中国天津
哪位前辈能提供Heidenhain  tnc530i的UG后处理在此先谢谢了
7 p3 D$ ^* s& {! B+ R/ j: ^+ s7 nEmill:j_liu@turwey.com
发表于 2011-12-8 15:14:54 | 显示全部楼层 来自: 中国山西吕梁
到处有UG后处理,为什么就没有米克朗海得汉
发表于 2012-5-22 08:45:17 | 显示全部楼层 来自: 中国山东烟台
0 BEGIN PGM 1 MM2 ?3 n1 X& @1 G: m2 w* O
1 ;Program Name: 1 MM( c+ h3 Y! d5 _  Y4 d
2 ;Create Time: Thu May 10 01:39:25 2012
0 Q9 Z4 p( E" a) v0 G3 ;(Tool Name=D8)
1 Y- X8 r% W$ f4 ;(TD=8.00, TR=0.00)
6 E8 e3 o7 E8 l" S7 J; r/ s: t5 TOOL CALL 0 Z S8500: w( z) ^3 z& w! x6 k  M
6 TCH PROBE 584 TOOL SETTING L,R ~8 L" ]* V' h  @# {6 _
    Q350=+0    ;MEASURING TYPE ~4 ~5 G' O3 T  p
    Q351=+0    ;APPLICATION ~
( S/ h" d& ?3 N4 o, K9 o( R    Q352=+0    ;CUTTING EDGE CONTROL ~
. a, O) V" @7 V% l; B# |0 H  [    Q355=-1    ;MEASURING POSITION ~
/ {9 b( E- Z8 h! G2 g/ F    Q361=+3    ;NUMBER OF MEASURINGS ~5 l* n/ B: I# W7 [: S
    Q362=+0.01 ;SCATTER TOLERANCE ~
# v9 o; [7 ~% N    Q359=+0    ;ADD. LENGTH CORRECT. ~
4 D# q- }: _. \7 U3 s) |' E    Q360=+0    ;ADD. RADIUS CORRECT.
. y1 q" e3 N8 V- _7 M140 MB MAX
. x, E/ q2 l$ \: w+ l8 CYCL DEF 32.0 TOLERANCE
" O/ f9 f3 `. c7 A* `) |9 CYCL DEF 32.1 T0.0052 V$ N) m/ n: g; I7 t
10 CYCL DEF 32.2 HSC-MODE:0; Z/ l  i- z8 t8 c% C, ]* P* u5 @& S
11 L X2.467 Y-16.5 Z9.94 F6000. M3 M8& E# {, q' p4 f7 x. }1 S; j1 u
12 L Z-.01
1 k4 O/ b' I, @13 L Z-.31 F2000.
& Z. s4 w" `. j& O& f1 K. |14 L Y-12.9
2 @  T/ G' n$ l( Z% B! n8 o15 CC X-.533 Y-12.9' p  ~% W% X3 U7 S; X% A( u
16 C X-.533 Y-9.9 DR+! [1 Q4 `! G: W% X2 g
17 L X-26.901 F4500.3 f  b9 V, h6 c. h! j2 t
18 CC X-26.899 Y-7.9) I/ G! K! |' c" k" r4 b' }2 `
19 C X-28.899 Y-7.902 DR-5 o2 s! D/ s4 Z
20 L Y7.902
. I/ h0 v8 a& M0 w" c; z3 y. C- n. c21 CC X-26.899 Y7.94 ~: p0 _6 P. X5 v: a
22 C X-26.901 Y9.9 DR-# u, V) B: q+ k' l; |
23 L X-26.0617 O; ?( z) W' T! S
24 CC X-26.061 Y7.9
; X5 w+ d3 s$ X5 }$ k25 C X-24.272 Y8.794 DR-
2 g& C7 c! N; k5 p; i- f" `+ a26 L X-23. Y6.253 j- a; \2 {8 z+ i( V9 K0 ?
27 CC X-21.211 Y7.145) R6 M2 \( Q7 E7 D
28 C X-22.155 Y5.382 DR+( s& i# x" S3 P: j  M
29 CC X-22.627 Y4.5
0 i3 O  U1 [7 ~30 C X-21.926 Y3.786 DR-! T+ \7 ~( a; A) e. p
# e2 J1 m# P: @$ L8 c1 a7 q^^^
! o: n4 f8 j* j( g' T
* S3 @$ s/ O! @, Y+ I^^^
$ _4 s- @! G; R. V0 z* R8 B+ G1343 L X-1.1 D  g* _6 q( W! z/ `  r- S) R
1344 L X-1.1
5 t' Z: i" G9 c; z1 _7 ?1345 CC X-1.1 Y-11.5! @" l- h( n. Q' B$ X: W3 ~7 v
1346 C X-4.1 Y-11.5 DR+
" b7 x: g$ W! K+ H0 R- B1347 L Z-5.61
) m; Y0 c; Z8 {! U. u: S1348 L Z9.94 F6000.6 A! |( h# v1 I$ Y! c8 ~: z: b; Z
1349 M54 V! |% v& p6 r% H3 W+ F
1350 M9
. |" a8 Q5 ]) y- y: e1351 M140 MB MAX$ l0 i7 a$ F4 i
1352 STOP M30+ I' {. U! \5 E* Y' L% }1 _( A
1353 ;MAXZ: -5.910 MM7 f: H. d. j9 X$ Y8 u6 N8 J
1354 END PGM 1 MM  c- R( t3 h, B" H$ h' ?
;Machine Time: 1.78 min
) C( S2 I. a  N7 [;MAXZ: -5.910 MM
: @. s# |. B  i2 L8 ^;Part Name: Administrator\F:\2011cnc\2yue\0219\A022_12205_1_E2_stp.prt# ]8 `7 r# P% Y' G: N& k! e
;Date: Thu May 10 01:39:25 20122 H; o& }; Y5 l
;MCS error  请确认!!! !!!
完整的后处理mikron.rar
2.94 MB, 下载次数: 167
发表于 2012-5-26 01:25:58 | 显示全部楼层 来自: 中国四川德阳
# `/ Y# m8 V2 z3 _
! G! b" ~* G( [* E6 P#3  694865935- W* u7 I# e" x+ @$ A% ]$ F
求教能不能将螺旋铣的循环208做出来啊?我自己做的后处理出不了,每次都是上机改的。
发表于 2012-12-24 16:51:35 | 显示全部楼层 来自: 中国山西晋城
不错,捡了个便宜
