查看: 1440|回复: 0
[太阳能] Space-based measurements of elemental
发表于 2007-12-4 23:54:43 | 显示全部楼层 |阅读模式 来自: 中国山东德州
Space-based measurements of elemental abundances and their relation to solar abundances
. B8 |) j, _' Z
& L; r1 A$ \5 U, T3 C6 q6 L# s
3 M& ~- ?: f7 I6 a1 U8 F3 CM. A. COPLAN
% w2 K% d$ o. t  qInstitute for Physical Science and Technology, University of Maryland, MD 20742-2431, U.S.A.' W3 }+ F: ]! I1 l( d% k
K. W. OGILVIE
1 P, q: q, f& z) e1 ~- s, mLaboratory for Extraterrestrial Physics, NASA/Goddard Space Flight Center, U.S.A.& O* P$ V" r" U6 ~( s+ L
P. BOCHSLER andJ. GEISS) ~- W; k6 ?+ H; J. k
Physikalisches lnstitut, University of Bern, Switzerland
1 c# n3 b; s; T3 t, s6 s(Received 14 August, 1989; in revised form 14 November, 1989)
1 _% l. y: f- T
) p( q! l/ y5 j: p        Abstract:The solar wind provides a source of solar abundance data that only recently is being fully exploited.The Ion Composition Instrument (ICI) aboard the ISEE-3/ICE spacecraft was in the solar wind continuously from August 1978 to December 1982. The results have allowed us to establish long-term average solar wind abundance values for helium, oxygen, neon, silicon, and iron. The Charge-Energy-Mass (CHEM)instrument aboard the CCE spacecraft of the AMPTE mission has measured the abundance of these elements in the magnetosheath and has also added carbon, nitrogen, magnesium, and sulfur to the list. There is strong evidence that these magnetosheath abundances are representative of the solar wind. Other sources of solar wind abundances are Solar Energetic Particle (SEP) experiments and Apollo lunar foils. When comparing the abundances from all of these sources with photospheric abundances, it is clear that helium is depleted in the solar wind while silicon and iron are enhanced. Solar wind abundances for carbon,nitrogen, oxygen, and neon correlate well with the photospheric values. The incorporation of minor ions into the solar wind appears to depend upon both the ionization times for the elements and the Coulomb drag eerted by the outflowing proton flux.
/ T, S3 |) p7 V: {
* |3 @* P1 Q5 w! r% z[ 本帖最后由 清风明月008 于 2007-12-5 08:06 编辑 ]
abbr_329a46a68d31d4f74cbfe640797f9c08.pdf
424.11 KB, 下载次数: 5
