查看: 4719|回复: 3
[求助] H62的机械性能在哪个标准里能查到?
发表于 2007-12-6 11:35:25 | 显示全部楼层 |阅读模式 来自: 中国江苏南京
请各位老大帮忙!
发表于 2007-12-6 13:22:31 | 显示全部楼层 来自: 中国安徽芜湖
材料: H62
% g( `' h5 q8 n3 N) }* D& V4 e; x标准: GB  & L, W- `- [- x* @* a. f! m
国家与地区: China
0 w* L8 N3 o0 ~" w+ [金属类别: Copper Alloy
* e# v! K% x$ z+ ~; D9 k7 y7 @次级类别: GB 13808 Wrought copper and copper alloys ' S, P! _) s( P" q& M9 E" I
http://www.3dportal.cn/discuz/viewthread.php?tid=186593&highlight=GB%2B13808
6 g$ h( T  Z4 X(此标准已作废)见http://www.3dportal.cn/discuz/viewthread.php?tid=191164&highlight=GB%2B13808
9 ^. z. ?4 [8 P2 J, u2 c6 G7 b2 Q' z% ~3 S4 ]+ g. ^. }; _. l( M
材料属性
" z! k6 A% t1 b; f! y- ^3 a2 S% k8 G9 s
3 b: K6 }7 P7 |+ C6 K9 M2 H
        Min.      Max.    Approx.
" @6 u! z7 e3 f- @0 d4 n# R( qHeat treated ; Bars, rods; > 10 <= 160 mm 2 g3 V6 A4 ?0 o3 V+ g+ h0 W
Tensile Stress, Rm (MPa):                                      295
( ^. f- v# _$ b; y4 ^# O) p1 \- [Elongation, A (%):                                                     30# [6 Y, U5 [0 k! k" Z* x
* \+ i) }* j/ V* W- w5 ]$ }+ z' X
7 I! l/ K  _. Q8 ]$ e1 A! |: t
% X0 E, l) C* d5 M# v, H
机械性能
http://www.key-to-nonferrous.com/cn/img/nav/content-bgh.gif
材料:H62
标准:GB
国家与地区:China
金属类别:Copper Alloy
次级类别:GB/T 2059 Strips of copper and copper alloys
( E( u! d2 n# Uhttp://www.3dportal.cn/discuz/viewthread.php?tid=186850&highlight=GB%2FT%2B2059, B& _5 h+ l2 o
4 F, J5 N/ c! }. d9 \8 c
材料属性 4 d/ N1 P. y, \" K0 e5 a
0 M, Y& p1 r; [. a# F. uhttp://www.key-to-nonferrous.com/cn/img/nav/spacer.gif
. ~% }+ P) J4 ^3 P
  Min.Max.Approx.
Soft ; Strips; 0.3 mm
Tensile Stress, Rm (MPa):  290
Elongation, A (%):  35
Half hard (1/2H) ; Strips; 0.3 mm
Tensile Stress, Rm (MPa):  350470
Elongation, A (%):  20
Hardness:  > 85 <= 145 HB
Hard ; Strips; 0.3 mm
Tensile Stress, Rm (MPa):  410630
Elongation, A (%):  10
Hardness:  > 105 <= 175 HV
Heat treated ; Strips; 0.3 mm
Tensile Stress, Rm (MPa):  585
Elongation, A (%):  2.5
Hardness:  145 HV
# u- F, r7 A9 I0 B* I  s- c
' d) k) u/ i) v1 a8 D
) }% [- B* x" q
; Z) R; \. K8 x1 N[ 本帖最后由 hourpp 于 2007-12-6 13:36 编辑 ]
tdragonfu + 2 应助
发表于 2007-12-6 13:30:19 | 显示全部楼层 来自: 中国陕西西安
Cu——60.5~63.5%
3 r3 E, o# d2 d- K  G+ J% IFe——≤0.15%
- C+ g5 J2 }; c) UPb——≤0.08% 0 B' C5 H6 n$ ?3 g
Sb——≤0.005%
5 b( [) _2 C! E9 MBi——≤0.002%
, ?# z; p; p1 N" iP——≤0.01%
. }. k* D$ t9 E# P5 s4 h3 DZn——余量 - j/ e6 m: T0 ~% Q% ]
杂质总和:≤0.5%
$ n' k1 R1 A/ y+ Q- U' U参考资料:GB/T5232-85
tdragonfu + 2 应助
发表于 2007-12-6 13:54:57 | 显示全部楼层 来自: 中国上海
看你的H62是什么形状的了,这些标准里都有H62,拉制棒<φ40时是370MPa,≥φ40是335MPa,板材软硬程度不一样相差蛮大的。
! @' e! W( Y; C& Z$ Q, N' ZGB-T1527-2006铜及铜合金拉制管, m  z) I' b; @3 v7 f8 _8 Y
GB-T1528-1997铜及铜合金挤制管, }8 X2 Z# \+ a
GB-T2040-2002铜及铜合金板材
4 T; z# }3 Z0 a3 LGB-T2059-2000铜及铜合金带材" U( P+ }( I' y6 v4 C$ C
GB-T4423-2007铜及铜合金拉制棒) e  F" p9 V4 ]( E; C
GB-T13808-1992 铜及铜合金挤制棒  h9 X) a: R( U2 X5 L
GB-T13812-1992黄铜磨光棒
- `  n# J8 G8 d' I! QGB-T14954-1994黄铜线
tdragonfu + 3 应助
