查看: 13527|回复: 2
[求助] 1215MS和12L15是一样的牌号吗?
发表于 2007-12-11 10:56:36 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
发表于 2007-12-11 11:12:38 | 显示全部楼层 来自: 中国安徽芜湖
材料牌号:12L15
标准:AISI
国家与地区:USA
钢组:结构钢
次级类别:AISI 12L15 Steel
注释:Resulfurized and Rephosphorized Carbon Lead Steel - Free Cutting Steel
用途:This grade is a free cutting rephosphorized and resulfurized carbon steel composition applicable to semi-finished products for forging, hot rolled and cold finished bars, wire rods, and seamless tubing.
+ a; O$ K" ~7 C' A% Z( g' T/ L
http://www.key-to-steel.com/cn/img/nav/content-bgf.gif
http://www.key-to-steel.com/cn/img/nav/spacer.gif
http://www.key-to-steel.com/cn/img/nav/spacer.gif& W4 M( A) D0 U/ c
化学成分 (%)# H5 y- C1 K) e& w) ^# M
  \3 `  ^0 \- @2 w
元素最小最大近似的
C 2 A9 S( [9 U1 J$ V: ~
0.0900
5 [! @: i& t* ^- C
Mn 0.7500 1.0500 + `/ D3 N% [1 S3 C" m
P 0.0400 0.0900
2 l/ A  W8 @3 y" e+ }  ^
S 0.2600 0.3500
# h# Q) N3 ?* y# W! p: h
Pb 0.1500 0.3500
5 ]. g) U1 n& g: B. ?" o4 u2 W+ I8 X' B; P+ V$ {
! i( v: U. w, Y8 J
* j8 N. S" j, T+ e/ z
, j% t0 O/ y0 j5 @% `
没有找到1215MS
, y1 Z9 ]+ M$ d1 P& s0 K( [
9 N& k% w/ g9 H
材料牌号:1215
标准:AISI
国家与地区:USA
钢组:结构钢
次级类别:AISI 1215 Steel
注释:Resulfurized and Rephosphorized Carbon Steel
用途:Typical applications are frequently rolled into rods, then drawn into wire. This wire is straightened, cut to length, and used in screw machine operations. This steel series are both rephosphorized and resulfurized.
) q5 S3 N; o6 X
http://www.key-to-steel.com/cn/img/nav/spacer.gif( ~4 m, d( `% n% k* o4 b( A( s  X
化学成分 (%)9 O" `+ d. |& |; _5 D; @  ~
http://www.key-to-steel.com/cn/img/nav/spacer.gif2 ~& u0 r& w7 r. |5 ~1 z
元素最小最大近似的
C
. c; t) a* J1 v/ x9 J: V
0.0900
: O  \8 H' a- K
Mn 0.7500 1.0500
; P3 u5 C- h9 e0 L( w
P 0.0400 0.0900 , I9 z) J$ Y; Y4 w3 a' l, k- _
S 0.2600 0.3500
1 ^; U9 u" ]1 J) [5 z! G# L
材料属性 ) N5 X; K0 s5 h! @! `: \8 Y
- J3 o& ^3 [1 s. Y, V* @
最小最大近似的
圆钢; 冷拔; > 19 <= 38 mm
屈服强度 Rp0,2 (MPa)415--
抗拉强度 Rm (MPa)540--
伸长率 A5 (%)10.0--
硬度167 HB
圆钢; 冷拔及磨光; > 19 <= 38 mm
屈服强度 Rp0,2 (MPa)470--
抗拉强度 Rm (MPa)525--
圆钢; Turned and polished; > 19 <= 38 mm
屈服强度 Rp0,2 (MPa)230--
抗拉强度 Rm (MPa)385--
伸长率 A5 (%)25.0--
硬度121 HB
% }; v  J% b& W
% D% A: p3 g9 [5 D* G$ k' Z[ 本帖最后由 hourpp 于 2007-12-11 11:15 编辑 ]
发表于 2007-12-11 12:19:44 | 显示全部楼层 来自: 中国浙江舟山
带L的应属于易切钢类,应该注意有些会有环保限制的
