发表于 2008-8-9 23:57:12
来自: 中国湖北武汉
1. Install Solidworks with serial 9916 5719 6888 1432 57K7 Q892.; \* x2 {' {, ]
2. Install update packages*
! b7 y% G/ U% I8 t/ E Dismiss any prompts to add a license server." Y7 j! J7 U% n" }& Z, `
3. Copy <platform> files to windows directory (except for .reg file).' X' Y( {. ]/ H
4. Import <platform>\lz0-sw2008.reg to registry.! t- V( R$ |2 B) p. w
5. Copy sw2008.lic to C:\Program Files\Solidworks\: x+ p P: f4 a a* k- j* c4 P
6. Enjoy! v4 a" C6 ^" s
* - If you have SP1.0 installed, use the 1.0-4.0 installer, SP2.1, use 2.1-4.0, etc., otherwise use 0.0-4.0 for main SW2008. All other installs are the same either way. |
