发表于 2007-12-14 15:03:43
来自: 中国安徽芜湖
http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif5 [ M+ N0 D1 x4 e7 z1 x' m5 g
8 } y' W" j K0 r; Z" S5 w |
& L% Z0 k& M- K; Z, h& Q0 Y- B" x) G8 x9 S7 N: s
http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif* q9 L7 s9 \5 G, v* p7 Y. x
化学成分 (%)
9 o7 p. u& _3 ?0 z& [+ U3 H8 | | http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif. j1 Q* Z! U7 o( ~1 I2 l
| 元素 | 最小 | 最大 | 近似的 | | Cu | 99.9000 | ) w$ i1 c2 R! q; g; `) u: e: k
2 B2 {1 [. T. K9 D: O1 z) p( \ | | Total oth. |
: @1 |0 ^2 [$ e9 A$ j | 0.0500 |
% G9 _% n" G. }5 K | | O | ( R+ l+ e! L" |+ a" o
| 0.1000 |
| 4 B; i1 H! F+ h. e' T
| http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif! P$ `+ d8 ~& Q0 c3 w
化学成分 (%)
) R+ t. L! |+ i4 s0 o1 J | http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif, r, ?6 C5 T6 r4 c! r
; b/ l; m5 H7 Z1 { G/ C* X |
1 V' U/ o v0 @2 C9 q$ ~* s3 K | | Pb | " B' k4 n+ d- i! ~. L
| 0.0050 |
; ~$ K; ?9 U* @. t | | Bi | 4 L4 _6 z! y) D% m: @+ p
| 0.0005 |
$ }6 M3 R3 K# w- D" H- y0 L | | Total oth. |
4 }2 r- w7 n7 e& y% s | 0.0300 | % E0 N/ K4 o7 z! v# i5 i5 Q7 ~
| | P | 0.0050 | 0.0130 |
& j+ A# q* _' O$ { | http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif
* H* Z: E. F4 u; P; _http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif
: i7 S1 [9 B& {. ~/ }$ M+ n5 D. J( Q8 p* O/ j: p
| 6 z- y' J+ U, T2 C1 T8 L- `
+ n# H3 Y, D' D' D* u( W& |$ c0 Y: R' ]
6 k* I1 I0 O1 S H8 J/ t$ L
9 N: w5 j; {9 p/ |2 Zhttp://www.key-to-nonferrous.com/cn/img/nav/spacer.gif" i" I( K( {8 B6 u; Q) D4 u
化学成分 (%)
! D+ W1 p+ q. O. h( G | http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif
; ^9 k5 q* ~/ v" V| 元素 | 最小 | 最大 | 近似的 | | Cu |
( I0 {; _. r0 P" s4 \ | 0.0200 |
3 F# e' Z, F1 }3 {% Z( ~ | | Mn | 0.5000 | 1.3000 | $ G; [, @8 d* r" N$ P, M7 H2 g
| | Mg (*) | + \2 q1 ?# P% T% V
; w6 d) d# r2 X$ c/ E/ w3 ?: l | 4 n+ z( _: ~6 k/ T$ c/ }, p3 {' h
| | Ni | 9 g8 l) j h% Y# z' K$ }2 d
| 0.0010 |
9 D9 {5 n( v8 |! t | | Al | / G. p- _6 x- T2 j! t
| 0.0100 | ; l0 F- d8 X/ H/ Q2 Z
| | Fe | 0 |3 e& D/ \- ^0 [$ h# _
| 0.0300 |
4 W; {! d. b% b5 H | | Total Others | ( `4 m8 [0 O7 K L/ f$ n0 M7 @
| 0.3000 |
" k# x5 W( F* Y3 f, e& U; V | | Each oth. | 6 {. I6 Y8 @, Y( j* ^
| 0.0500 |
5 P( Y6 v# J: Z( O. H |
| $ v' U7 }, {$ P/ P
' L" j. D3 {4 x# L9 @. o o
) k, b' `+ R# r! e
, v) V- c" |: v6 _% f: i6 D4 N* H2 ^' z- A7 c2 Z" q4 n! f j
4 r. f$ `3 m! g1 b化学成分 (%)
" P4 e* H! s, u' P. k0 F- [% }' W | http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif0 p& ]/ k x' V ~
| 元素 | 最小 | 最大 | 近似的 | | Si | , \1 z$ ?/ ?0 B( W+ m
| 0.0500 | 9 V6 y$ H; u4 {, o! G% U
| | Cu |
- \' M/ Y7 i$ a. l: O | 0.0060 | ! w- a# v. p3 Y& t# ?7 B
| | Mn | 0.2000 | 1.5000 |
8 i) Z6 q- i% f' s" B% }9 ] | | Mg (*) | " f! E% p" X3 e# z" a* T2 k
! y3 @+ g" B; h/ [. ]0 { | * v% H. b1 f# x" I$ \
| | Zn | 0.7000 | 1.3000 |
3 p& V" g; f- u( V1 g/ j+ n9 j, p( | | | Ni | ) R! @+ W$ Y& I2 ~+ N& s
| 0.0010 | + T1 d$ Z6 k/ F( t8 b [
| | Al | 2.5000 | 3.5000 | $ s5 Z( ?# K) d) _$ s$ M
| | Fe |
# \9 b& }; g! z2 W s8 Y. n7 S3 g | 0.0030 |
" r7 e8 Z4 @3 a0 E- i! r) S" B% Z | | Total Others |
, y; n3 \0 B- c- F& {8 @8 S | 0.1000 |
7 ?0 B- |1 }& f6 e' F8 n- c |
0 }2 G3 [+ [7 b6 V( @1 [5 E; Hhttp://www.key-to-nonferrous.com/cn/img/nav/spacer.gif* Y7 }, {( O+ D8 A
7 d9 n* D3 W, V7 w |
: ^" Y6 p! K/ O; i I8 h2 x& O, q" ]$ V
| 8 K$ h4 Z! f8 o- Q2 ^3 M
М1ф; М1р,是不是直径和匝数?) Y2 O, k) G2 l* C* C X
Copper pipes drawn in coils 线圈用拔制铜管,
/ a O9 t. N& GCopper pipes drawn in rings 铜环用拔制铜管。% K+ J8 |( n7 k
- j( q0 |- u- [ x e
М1; М1ф; М1р; М2; М2р; МЗ; МЗр这些好像是俄国的写法:“Трубы медные М1, М1ф, М1р,М2 различных диаметров, другой прокат “。
- q4 |& A$ g2 s) |
7 i' u% T$ Q2 G# `- r% p+ @
5 i8 B: }! W# V% i! k[ 本帖最后由 hourpp 于 2007-12-14 15:30 编辑 ] |
