3天前
查看: 1601|回复: 0
[分享] 关于cimatron后置处理
发表于 2007-12-14 17:18:02 | 显示全部楼层 |阅读模式 来自: 中国山东烟台
TOOL CHANGE: FIRST:
: {" V# J3 ^/ [3 |+ r      SET_ON  SPIN_SPEED SPIN_DIR ; 8 Y; h( V: Y9 N  h6 l
*-----save first tool number
7 F5 C) `, n9 D  E1 A3 ^4 G2 C      FirstTool = CURR_TOOL ;
/ n" r$ ]" c3 o8 w- }. [# ~! H      LastTool  = CURR_TOOL ;
2 U* `2 k& T( I
- e) W: Y3 `2 T: U* i' ~*-----tool cutter compensation register number 3 w# s0 K; F) d) T2 A7 |* h
      CutterComp = CURR_TOOL +  DiaComp ;
( s* p6 e. |& U, D4 u( d! K3 h6 w+ P# H, O0 i
*-----assuming 1st tool is in the spindle, there is no need
% s$ Q% e# P) C( S- F*     for tool change) / B' e  g9 R3 a9 L' `) j5 A
*     OUTPUT $ " T" CURR_TOOL ; # Q- ~" R3 I0 n! C6 L1 a) a0 T
*-----more then one tool in this run of the Post Processor
: ]7 k( V3 ?* D5 }, D' z7 p2 g      IF_SET (NEXT_TOOL _NE_ CURR_TOOL) $ e1 h9 U3 u- }0 {7 g/ }& t
         OUTPUT $ " T" NEXT_TOOL ; % A) U( W) l; x7 l  E
      END_IF ; / Z0 H, Y+ \, g, m7 t. V5 q+ j6 W
*-----standard tool change commands. (assuming 1st tool is in 0 a* I  M7 C- ?
      OUTPUT $ " G90 G80 G00 G17 G40 G54" ; - K. `7 n6 b4 n5 C$ A- L# p
      OUTPUT $  " Z" Zhome " S" SPIN_SPEED " " SPIN_DIR ;
  ^4 ]+ L! v, S7 Z' l% o" F( n      OUTPUT $ "( 刀具名称---" CURR_NAME "×" CLEAR_LENG ")";
3 A" m5 A' c7 T      OUTPUT $ "( 曲面偏移=" PART_OFST "曲面公差=" PART_TOL" 轮廓偏移=" CONT_OFST " )";4 U5 \/ O2 X+ n* M' `! M4 C
      OUTPUT $ "( 程式名称=" TP_NAME "本程式由" USER_NAME "编制 )";
) F8 R( ~# Q) \$ n
1 ~% |& c: `4 M% R, T$ j5 I7 ^2 m6 m2 R5 I3 F
   说明:1、*注释或代表不执行此内容;+ k7 `0 ~" b6 V. K0 c: n5 J
       2、 引号里内容则按实输出;
* N1 S7 n+ o/ \/ `& P       3、修改保存完毕执行主菜单--NC--DFEXF--输入后处理名--回车即可。
