TOOL CHANGE: FIRST:
- [& A. N; N6 ]9 J Y' I ^ SET_ON SPIN_SPEED SPIN_DIR ;
, `( i) m3 J4 |; C$ u*-----save first tool number ' S! Y) c# i# g j- B
FirstTool = CURR_TOOL ;
. p6 m6 I' ~3 f LastTool = CURR_TOOL ; ) U8 l, S: g( a1 ^: z
4 M0 }* A- b. Y+ O
*-----tool cutter compensation register number
) n. J" H' [$ @) A. A5 E$ r CutterComp = CURR_TOOL + DiaComp ; 0 ~: W# H% L/ Z1 h$ o( i
3 v2 s# v! J4 b. w1 H*-----assuming 1st tool is in the spindle, there is no need
6 u0 a8 i3 | {7 |; F! Z3 \4 z* for tool change) ' L' `* T U( A. c$ z
* OUTPUT $ " T" CURR_TOOL ; 6 s1 c2 D) k4 J, A
*-----more then one tool in this run of the Post Processor
$ G( @8 q( ~9 j IF_SET (NEXT_TOOL _NE_ CURR_TOOL)
! v( _- i' d( ]2 U4 E" F OUTPUT $ " T" NEXT_TOOL ;
1 Z1 L6 l" i) O" \ END_IF ;
2 {) V6 t7 B5 X5 k6 U* f( l5 B*-----standard tool change commands. (assuming 1st tool is in 3 l D* {" f4 W8 ]3 w
OUTPUT $ " G90 G80 G00 G17 G40 G54" ; $ E6 W1 Z; z* w" r3 d
OUTPUT $ " Z" Zhome " S" SPIN_SPEED " " SPIN_DIR ; W, g. e8 |3 B! Q% a- p# `& p
OUTPUT $ "( 刀具名称---" CURR_NAME "×" CLEAR_LENG ")";
/ ~1 ?6 v4 p8 H; M OUTPUT $ "( 曲面偏移=" PART_OFST "曲面公差=" PART_TOL" 轮廓偏移=" CONT_OFST " )";
, h- {0 k$ P% s9 W OUTPUT $ "( 程式名称=" TP_NAME "本程式由" USER_NAME "编制 )";
: a; P$ X, D: e) s, P
* g! s1 X1 s7 H$ W8 ^2 D( N9 j+ C
3 v% d6 l( b6 x6 f% F; b 说明:1、*注释或代表不执行此内容;: t" j' v q% R2 R
2、 引号里内容则按实输出;
1 b; f( [1 p' [9 V, N( K0 ` 3、修改保存完毕执行主菜单--NC--DFEXF--输入后处理名--回车即可。 |
