8天前
查看: 1222|回复: 0
[环境科学] VOC的CMB来源解析[英]
发表于 2007-12-16 21:18:58 | 显示全部楼层 |阅读模式 来自: 中国天津
Title:Review of volatile organic compound source apportionment by chemical mass balance, f6 Z2 U& k* G  B
Author:John G. Watson, Judith C. Chow, Eric M. Fujita- I* G& ~4 G# U
) q( j. f1 @7 f( h; a! _6 AAbstract:The chemical mass balance (CMB) receptor model has apportioned volatile organic compounds (VOCs) in more than 20 urban areas, mostly in the United States. These applications di!er in terms of the total fraction apportioned, the calculation method, the chemical compounds used in the calculation, the apportionment units, and the source profiles applied. Nevertheless, they show similar results for VOC fractions contributed by different sources. Gasoline vehicle exhaust, liquid gasoline, and gasoline evaporation contribute up to 50% or more of the ambient VOCs in many of these3 C  m: i: B) Q  A
studies. Relative motor vehicle source contributions determined by CMB were similar to or larger than their proportions in emissions inventories. Coatings and solvent contributions from CMB were much lower than the proportions attributed to these sources in current emissions inventories. Several measurement and reporting conventions would facilitate CMB analyses of VOC data sets. 3 L% b' ?6 E; m- b7 H9 q& x/ m% q
" q7 T2 k) N& Q; GKeywords: Receptor model; Volatile organic compounds; Ozone; Emissions; Source profiles; Emissions inventory; NARSTO
Review of VOCs source apportionment by CMB.pdf
177.29 KB, 下载次数: 3
清风明月008 + 5 好资料,感谢对论坛的支持!
