发表于 2007-12-20 09:22:13
来自: 中国安徽芜湖
http://www.key-to-steel.com/cn/img/nav/spacer.gif
' {, L' o1 W& @# j0 a# a( f4 A化学成分 (%)/ H. V8 ~& }- m( |2 P6 h: M) w3 u! V
: H3 ~2 j' k' ~% d6 n) s| 元素 | 最小 | 最大 | 近似的 | | C | 0.1800 | 0.2300 | ! o4 Q ~7 e8 y& J
| | Si | ; F! ?; B5 K3 L3 x2 T( t- U! _
| 0.3000 |
5 a$ o# h1 u0 u' ]5 K | | Mn | 0.9000 | 1.2000 |
5 s7 r1 o( j7 ^7 H$ f | | P | 0 P0 m1 O o8 a; V, V3 F
| 0.0250 |
e3 k) s3 W; m | | S | + k; W( l" _6 t: X X
| 0.0250 |
3 ~+ f4 B) L2 T5 K4 T; b | | Cr |
4 {! t7 K. c" E | 0.3000 | 9 N; P U1 D/ z; M3 K' ?; l4 O
| | B | 0.0008 | 0.0050 |
4 W, N5 E: N. ~& N) z4 f4 {7 R9 X | | Cu |
0 p* z, z0 t: {3 C+ O | 0.2500 |
) i9 n" H) g" S6 b0 h6 I8 N2 b1 X |
| 标准号: | DIN EN 10263-4-2002 | | 中文标题: | 冷镦和冷挤压的钢杆材、棒材和线材.第4部分:淬火和回火钢的交货技术条件 | | 英文标题: | (Steel rod, bars and wire for cold heading and cold extrusion - Part 4: Technical delivery conditions for steels for quenching and tempering; German version EN 10263-4:2001) | $ c! ^4 y$ w' m. V: M' _) n. z
; y6 S: ]8 i. M" U- _
4.
# {5 U( g# O3 y1 u+ K
3 S8 m+ }) ^: ]5 [0 z7 x0 z$ f( n9 d% M! @- v' w" ^% k
http://www.key-to-steel.com/cn/img/nav/spacer.gif; R7 L% _3 O; m0 ]7 H, D1 }" K. ^7 d
化学成分 (%)
; B1 L2 Y' H6 R; |$ C | http://www.key-to-steel.com/cn/img/nav/spacer.gif1 a2 H+ I- l9 a& K _0 i( N9 m7 |
| 元素 | 最小 | 最大 | 近似的 | | C | 0.0600 | 0.1000 |
8 {* Q9 V& E- N9 f5 H Z | | Si | ) b/ P/ A+ a" T) I( Y
| 0.1000 | 1 w. ^8 f1 j/ j% h; t i
| | Mn | 0.2500 | 0.4500 |
9 T6 ~9 d p1 S& }( ` | | P | % U) v) G" {3 u4 @1 U- |/ b# m
| 0.0200 | 9 Q: ~) P4 A: W" ?: K, W+ M
| | S |
9 q# Q- M( i) E8 e3 y | 0.0250 | 1 n& ]) k5 N1 }. U4 n( i
| | Al | 0.0200 | 0.0600 |
| 3 C9 L2 E+ u" t. S8 V6 a
| 标准号: | DIN EN 10263-2-2002 | | 中文标题: | 冷镦和冷挤压的钢杆材、棒材和线材.第2部分:冷处理后不用于热处理的钢的交货技术条件 | | 英文标题: | (Steel rod, bars and wire for cold heading and cold extrusion - Part 2: Technical delivery conditions for steels not intended for heat treatment after cold working; German version EN 10263-2:2001) |
7 ~8 V! r. X$ W- h A- N2 o; N9 \4 J
3.2 {) j; k' d* i0 _1 S
0 h3 n, S, Z3 l) u3 ?6 l: j" s/ O9 W
| 标准号: | DIN EN 754-1-1997 | | 中文标题: | 铝和铝合金.冷拉棒和管.第1部分:交货技术条件 | | 英文标题: | (Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 1: Technical conditions for inspection and delivery; German version EN 754-1:1997) | % q% r3 z% f% u) p" j& n! V# n
| 标准号: | DIN EN 754-2-1997 | | 中文标题: | 铝和铝合金.冷拉棒和管.第2部分:机械性能 | | 英文标题: | Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 2: Mechanical properties; German version EN 754-2:1997 | | 页码: | 24P;A4 | | 外文关键字: | ALUMINIUM ALLOYS;MECHANICAL PROPERTIES;PROPERTIES;TESTING;NON-FERROUS ALLOYS;NON-FERROUS METALS;DRAWN;ALUMINIUM;MALLEABLE MATERIALS;PIPES;WROUGHT ALLOYS;ALUMINIUM WROUGHT ALLOYS | | 中文关键字: | 有色金属合金;机械性能;拉拔;铝合金;铝锻造合金;可锻合金;铝;管;可锻材料;特性;有色金属;试验 |
| 标准号: | DIN EN 754-3-1996 | | 中文标题: | 铝和铝合金.冷拉棒和管.第3部分:圆棒材.极限尺寸和形状公差 | | 英文标题: | Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 3: Round bars, tolerances on dimensions and form; German version EN 754-3:1995 | | 页码: | 4P;A4 | | 外文关键字: | FORM TOLERANCES;ALUMINIUM ALLOYS;LIMIT DEVIATIONS;DRAWN;ROUND RODS;TOLERANCES (MEASUREMENT);DIMENSIONS;ALUMINIUM;ALUMINIUM PIPES;PIPES | | 中文关键字: | 铝管;拉拔;公差;尺寸;铝合金;圆棒材;极限偏差;形状公差;铝;管 | 3 ~% ~6 V' B$ q! V/ T" j6 U1 u0 r
$ S* \9 x5 [) \/ x8 e
1.
6 m& X6 l" K& t1 V& B, |8 h, d
# g+ U6 q; z% ] s+ nhttp://www.key-to-nonferrous.com/cn/img/nav/spacer.gif# J M" z( [7 b/ M) E4 d, a }( G8 [
化学成分 (%)3 X9 `" ]$ a" V2 E( n0 ?' o. B
| http://www.key-to-nonferrous.com/cn/img/nav/spacer.gif8 v/ H: @) _* I. @: Q
| 元素 | 最小 | 最大 | 近似的 | | Si | 0.6000 | 1.4000 | * c3 s8 N6 P$ o; K1 i% b
| | Cu | 0 q0 V, L$ `/ h
| 0.1000 |
5 T. y6 D, n: ^( B3 v. { | | Mn | 0.4000 | 1.0000 | / }. U! O/ W6 n5 `2 I
| | Mg | 0.6000 | 1.2000 | % e4 F' c5 R9 K3 S/ ~3 P
| | Zn |
) F, t4 T; [1 }6 R( k3 d | 0.3000 |
! o7 u0 w5 k: t+ X* O+ `2 ^8 o. b | | Cr | ( W& }1 f+ @) B1 o7 D4 m/ n. ]
| 0.3000 | 6 ~# N; V9 V( O! ^' `2 s
| | Ti | + l/ f5 j( g* O2 s1 f) Y& a
| 0.2000 |
; w$ {, A+ ^. \' U | | Al (*) |
& k4 X9 o3 V4 l9 l2 T- J! k | 3 T4 g$ p0 S1 V
1 l: P& \2 f5 L6 `- P g | | Fe |
. H2 h& c2 E* i4 H/ ?, G | 0.5000 |
' g* P3 X& N7 Q | | Pb | 0.4000 | 2.0000 |
, E( \. P8 C" K, ?' h( u! }; c | | Bi |
% S. h5 }* f; G0 F" C6 s | 0.7000 | ; H7 S0 p0 P p, `6 H" ]! ~
| | Total Each | % x; F0 f/ k! w0 s/ o6 V6 t
| 0.0500 | 3 _$ g8 T3 B4 T
| | Total Others | 1 L8 S! c" ?4 g" P
| 0.1500 | 9 N$ T% V' x- D/ P& m! X
2 f" C6 }/ T& X7 shttp://www.key-to-nonferrous.com/cn/img/nav/spacer.gif- c& x5 p2 j+ [$ ?6 b5 X" ~$ g
7 Y! f% \' N8 ]2 X& ]7 d| 标准号: | DIN EN 573-1-1994 | | 中文标题: | 铝和铝合金.半成品的化学成份和形式.第1部分:编号标识系统 | | 英文标题: | (Aluminium and aluminium alloys - Chemical composition and forms of wrought products - Part 1: Numerical designation system; German version EN 573-1:1994) |
0 |5 ?! d! ~1 C9 U| 标准号: | DIN EN 573-2-1994 | | 中文标题: | 铝和铝合金.半成品的化学成份和形式.第2部分:化学符号的标识系统 | | 英文标题: | (Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 2: Chemical symbol based on designation system; German version EN 573-2:1994) |
3 R* B( y- I6 U. `. F4 T3 p6 O| 标准号: | DIN EN 573-3-1994 | | 中文标题: | 铝和铝合金.半成品的化学成份和形式.第3部分:化学成份 | | 英文标题: | (Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 3: Chemical composition; German version EN 573-3:1994) |
| 标准号: | DIN EN 573-4-1994 | | 中文标题: | 铝和铝合金.半成品的化学成份和形式.第4部分:成品形式 | | 英文标题: | (Aluminium and aluminium alloys - Chemical composition and form of wrought products - Part 4: Forms of products; German version EN 573-4:1994) |
| & O: g( i) y6 n' j9 Q; _! p$ H
你是要我国相对应的材料吧?是要材料牌号还是标准号?9 V/ V8 O0 S1 M0 O; g1 w/ O
而且这几种材料国内没有可替代的!5 G0 d$ Z9 ?% m. ~; \
& X+ J6 i7 e4 Q% r4 C U' _" b
[ 本帖最后由 hourpp 于 2007-12-20 09:46 编辑 ] |
