查看: 1952|回复: 0
[分享] AIAG CQI-9热处理系统评估HTSA(Heat Treat System Assessment) 审核表格-中英文
发表于 2007-12-22 20:27:22 | 显示全部楼层 |阅读模式 来自: 中国上海
AIAG CQI-9热处理系统评估HTSA(Heat Treat System Assessment) 审核表格-中英文.pdf9 L7 V, F  X$ r5 y2 G4 _; G+ A% m
Heat Treat System Assessment (HTSA) Update 4 G: p4 ]8 |+ L0 V, Y
热处理系统评估(HTSA)更新 / j5 B" P: ~+ ~% F* ?
* V7 {1 |+ n) n. T0 k! p
3 l: g4 n) `2 n: ^The International Automotive Oversight Bureau (IAOB) has recommended that Heat Treat System Assessment (HTSA) auditors become familiar with CQI-9 and include verification of supplier compliance when conducting these audits.This verification should be included in audit plans by the end of 2006. , m! C. W/ l( [$ w; P/ F
国际汽车监督局(IAOB)建议,热处理系统评估(HTSA)审计员熟悉CQI-9包括核查供应商履约进行时,这些审计结果. 这项核查工作应列入审计计划,2006年年底前结束. / C  ^2 l0 L3 M+ k
7 \% Z$ F; ^4 U/ Y$ }; S) y6 T  k4 a2 x: u
The goal of HTSA is to develop a heat treat management system that provides for continual improvement, emphasizes defect prevention and the reduction of variation and waste in the supply chain.HTSA provides a common approach to a heat treat management system for automotive production and service part organizations.
/ q% C% U/ E& N% |- UHTSA的目标是制订热处理工艺管理体系,为持续改进强调缺陷预防,减少变异及浪费的供应链. HTSA提供了一个共同的方式,以热处理工艺管理系统,用于汽车生产和服务组织的一部分.
- L% s6 f& D6 B* ^& D" M# F2 p. J9 ~7 i  Q3 ^; ], w& j  Q9 f
Unless otherwise specified by customers, future requirements indicate that assessments must be conducted annually to re-examine the continuing compliance with the HTSA.As part of the on-going surveillance audit cycles, corrective actions are required for any unsatisfactory areas. 2 }6 Y8 p$ g0 I
除非法律另有规定,客户未来的要求表明,评估工作必须每年进行一次重新审核继续遵守.作为上持续监视审计周期,纠正行动所需的任何不理想的地方. * e  g- F$ t! F- v
% o; V" i- ?# \! ?
Many North American Original Equipment Manufacturers (OEMs) consider this to be a "Customer-Specific Requirement" and expect compliance from any ISO/TS 16949 registered companies. % I4 w' }$ j$ m: y) l
许多北美原始设备制造商(OEM)认为这是一种"以客户的具体要求",并期望从遵守任何ISO/TS 16949注册公司.- w/ v! J$ `5 w
. l: x+ n2 \" T  F: p" _/ e
[ 本帖最后由 daviddzj 于 2007-12-23 10:20 编辑 ]
324.65 KB, 下载次数: 99
